Want to be a better CNC'er?
Get our weekly newsletter plus a package of greatest hits, special tips, and more, all for free.
I'm Ready to Be a Better CNC'er, Hook Me Up!
Tips for Getting the Best CNC Milling or Turning Surface Finish
Introduction
We've given tons of tips and information for CNC feeds and speeds throughout this Cookbook. This article is about the little tricks focused expressly on creating a better surface finish. It assumes you're following all the other tips but want to do something even more for surface finish.
Understand How Surface Finish Will Be Measured
Surface Finish Chart
If your concern for surface finish is based on the requirements placed on a particular part, understand how the Surface Finish will be measured. Which Surface Finish Measurement system will be used--RA, RZ, or some other? The link will take you to our page on Surface Finish Measurement which will help you understand the ins and outs of these systems as well as provide handy conversion between the different systems.
Use the Right Feeds and Speeds
It's absolutely critical to have the right feeds and speeds for finishing work--no guessing!
Use a proper feeds and speeds calculator like G-Wizard--most finish work needs to take radial chip thinning, ballnose compensation, and a host of other sophisticated factors into account.
Keep the rpms up where surface speed says they should be and back off the feedrate for a finer finish. G-Wizard has its "Tortoise and Hare" slider to do this adjustment. Move it all the way left. That's its special "Fine Finish" setting which puts the chipload as close to rubbing as you want to go for best possible finish.
Tortoise Hare slider for improved surface finish
Move the Tortoise and Hare lever all the way left when finishing...
Don't allow the chipload to go too low or you'll be rubbing the tooling instead of taking clean cuts.
Use a Finish Pass With a Light Cut
Keep a low cut width (or cut depth if you're talking the floor of a pocket or surfacing with a Face Mill) and do a separate finish pass. The depth of cut has to be larger than the chipload, or you can get rubbing. Usually something like 2-3x chipload will be right for the finish pass. I do a lot of finish passes in the 0.015" neighborhood. The lighter pass will reduce cutting force and keep things smoother for a better finish.
Clear the Chips!
Chips down in the work will scratch it up as your cutter slides them around in the hole. With work hardening materials like stainless, you may as well scatter a handful of hardened steel chips to scratch up your work. Use your coolant or air blast to get the chips completely out of the way of the hole. Hurco calls this out as one of the first and most important things to attend to in order to improve your surface finish.
Keep the chips clear so they won't scratch the workpiece or dull your cutter...
The chips won't clear of their own accord, although the tendency for gravity to help the process along is one reason horizontal mills can be more productive than vertical mills (or lathes too for that matter). Either Flood Coolant or an air blast with mist if needed will do the job if properly set up. See our article on the role of coolant for more.
Use the Most Rigid Possible Workholding
Rigidity in all areas is key to a fine surface finish and any vibration of flex is going to be bad for your surface finish.
The primary impact of workholding on surface finish is vibration. In the worst case vibration will turn into chatter, which is a harmonic effect that will be very visible in your surface finish. Clearly, the more solid you can make your workholding, the less likelihood of vibration there will be. Make sure your workpiece is supported and clamped over as much area as possible surrounding the cut while still leaving room for the cutter to get in there and do its job. Remember that as you are removing material during the machining process, you are in some sense weakening the workpiece. You may weaken it to the extent that the vise or other workholding fixtures can start to deform the part.
For example, suppose you've firmly clamped a relatively thin piece of aluminum plate flat in the vise. You intend to machine away the middle so it's like a picture frame. The initial slotting pass may relieve enough material that the slot pinches against the cutter with poor results.
Plates are some of the most difficult pieces to machine because they often want to vibrate like gongs. The thinner and more poorly supported the plate, the greater the tendency. Here are some things to consider when machining plates:
- Glue the plate to a subplate with super glue. It releases with heat (careful, the fumes are toxic!) when done. You can also use double sided tape and various commercial products for machinists that are intended for the purpose. Jeweler's wax (sometimes called "Dop Wax") is also good for securing parts as is hot glue. For all of these adhesives, make sure they will stand up to your coolant!
- If you stand a plate on end in the vise or other fixture in order to machine the edge, support the plate as much as possible up to the edge. A pair of 2-4-6 blocks make a great strengthening sandwich around a plate standing on end:
Providing a little extra support for the plate with 2-4-6 blocks...
- Move the vise jaws to the outside so the plate is supported in the middle by the vise:
- In general, keep the unsupported workpiece overhang as little as possible for all machining operations.
- Make a set of "Vise Jaws of Doom" as I did to support long workpieces with two vises:
- Use edge clamps (such as Mitee Bites) or make use of holes in the workpiece to clamp to a fixture plate.
- Beware over torquing any workpiece lest it deform, pinch the cutter, or destroy the accuracy of the work.
- A relatively new development is vibration dampening workholding.
Use Different Tools for Roughing and Finishing
Don't finish with the same tool you used for roughing. Keep brand new sharp tools for finish passes and rotate them to roughing work after they've done a brief tour finishing. If you're using an indexable tool, like a facemill, use two different sets of inserts.
Reduce Depth of Cut Slightly for Finish Pass on wall
For the finish pass on a feature with a floor, reduce your depth of cut versus the roughing pass by a few thousandths. This means you'll only be using the side and not the bottom of the cutter, which results in a better surface finish.
Minimize Deflection and Chatter, Maximize Tool Rigidity
You can't get good surface finish if your tool is deflecting excessively or chattering. You'll see every bit of that in the finish on the cut sidewalls.
Minimize tool deflection for best surface finish and to minimize chatter!
A tool that is deflecting wants to act like a tuning fork. It will neither leave a good surface finish, nor be accurate. How much deflection is too much? Ingersoll's ballnose catalog talks about just one thousandth of an inch leading to a chatter-prone tool. It's surprising how easy it is to get that little bit of deflection with small diameter or long reach tooling. In fact, the ratio of diameter to length of the tool is a great place to start talking about reducing deflection.
Reducing length to diameter ratio by 25% makes the tool more than twice as stiff so it deflects less than half as much. Deflection is directly proportional to length to the third power (a tool twice as long will deflect 2*2*2 = 8 times as much, all other things being equal!) and inversely proportional to diameter to the fourth power (a tool half the diameter will deflect 2*2*2*2 or 16 times more, all other things being equal!). In other words, use the shortest, fattest tooling possible.
Rather than worry about all those estimates, use G-Wizard Calculator not only to figure your tool deflection, but to help you choose the optimal parameters to minimize deflection:
Tool deflection
Use G-Wizard Calculator to Optimize Away Tool Deflection...
Consider a toolchange between roughing and finishing. Instead of using the largest tool that fits the smallest radius of the tool path, use an even larger tool for roughing and let the finishing pass deal with the smaller radii. Roughing is where you're hogging the deep chatter-prone cuts anyway.
Never use a longer tool than necessary. Any length more than 3x the tool's diameter starts to be chatter-prone and by 5x you're wishing for all the help you can get to control the chatter.
Choke up the tool in the chuck as much as you can to reduce stickout.
By the way, the part of the endmill that is fluted is weaker than the solid shank. Use the shortest possible endmills with the shortest possible fluted lengths for maximum rigidity.
Solid carbide cutters are much more rigid than HSS cutters. Hence, even if you're not running them at flat out carbide speeds, they may still produce a better finish. This will be especially true for longer reaches, smaller diameters, and so forth. Incidentally, carbide generally takes a smaller chipload than HSS, but it runs at so much higher rpm that it still comes out ahead.
Use G-Wizard's Cut Optimizer to minimize deflection, avoid chatter on finish passes, and do what you can to increase rigidity and minimize vibration of any kind. Chatter is the worst kind of vibration and will be very visible in the finish. Check out our chapter on chatter for more tips on how to get rid of it. Our G-Wizard Calculator even has a chatter calculator to help you determine the optimal spindle rpms to minimize chatter:
G-Wizard includes a Chatter Pitch Calculator that can give you optimal spindle rpms to minimize chatter...
Minimize Overhang For Workpieces and Boring Bars When Turning
The more overhang, the less rigidity. The rule of thumb is less than 3-4x diameter for HSS Boring bars and less than 7-8x diameter for solid carbide bars. For workpieces, if it hangs out more than 3x diameter you should probably be using a tailstock or steady rest to keep deflection to a minimum and improve surface finish.
Use Balanced Tooling to Reduce Vibration
Another way to reduce vibration is to use balanced tooling. The higher the rpms, the more important this can be.
Set Boring Bars at an Angle in the Bore, Not Parallel
It improves the cutter geometry and the rigidity, both of which go to better surface finish. The more angle the better, but it will limit your reach.
Surface Finish With Facemills
Facemills are a staple for most shops. They're great for squaring blocks and facing large areas. Here are some things to keep in mind when facemilling:
- One of the challenges for surface finish when face milling is that each insert differs in cut depth by just a little bit--they're not all cutting at exactly the same depth. More expensive facemills let you adjust each insert individually. If you can get them adjusted to a couple tenths or less, finish will be greatly improved. Failing that, try a flycutter. A big adjustable flycutter can cover the most territory in the fewest passes, and will often leave the most pleasing finish. However, you can convert even a regular facemill into a flycutter simply by removing all but one insert.
- The best efficiency occurs when 2/3's of the facemill engages the workpiece at a time (67% stepover). This also results in a better surface finish. Full engagement of the cutter keeps the forces on either side of the centerline fighting each other (leads to vibration) as well as starting chips out at zero thickness. Chip formation should start thick and end thin for best surface finish. See the note below on Entering the workpiece ("rolling in") for more on starting thick and ending thin.
- Climb mill with this 2/3's cut ratio. Conventional milling with a face mill causes the chip to start out thin, which sometimes leads to rubbing at the outset of chip formation that is bad for surface finish and can lead to BUE. The best finishes start the chip out fat and then thin it out before the chip releases.
- Take a light cut when finishing: 0.003 - 0.010"
- Keep an eye on the horsepower required for your cut. Facemilling uses a lot of it with surprisingly low depth of cut because the cutter is so wide. A wide cutter relative to the workpiece produces a more pleasing finish (fewer "mow" bands), but too much horsepower can be injected into the cut and will lead to vibration problems. Your horsepower used (or a load meter on your VMC) is telling you how much of this tendency there is.
- Roll into cuts with a face mill as described below under Toolpath Considerations.
- If you don't need a square shoulder, a 45 degree lead angle facemill will often leave a better finish than a 90 degree. Chips are also about 30 percent thinner versus a 90 degree facemill so faster feedrates are possible.
- Where surface finish is the major consideration, use the extra sharp finishing inserts, they make a big difference.
- Recutting or back cutting occurs when the surface that was already cut is cut again by the back edge of the facemill. A perfectly trammed machine cuts on the leading edge only, but perfection only occurs in theory. Slight tramming errors and deflection can make back cutting a reality, and it usually results in a poorer finish. Some machinists will put their machines very slightly out of tram so that the cut is always made on the leading edge of the path. This also helps to prevent chips being dragged around the circumference of the cut which further degrades the finish. Obviously you'd only want to cut travelling in one direction as well. The bias in tram needs to be very slight lest the angle cutter create scallops that are too pronounced. Larger diameter cutters will magnify the scalloping effect.
- "Wiper" inserts can be used to great effect for improved surface finish. A wiper is a flat ground on the insert. It cuts with the leading edge of the flat (which is parallel to the workpiece) and then the "wiper" burnishes the work as it passes underneath. The width of this wiper flat must be greater than the advance per revolution to allow the cutting edges to overlap. Spindle tilt such as was discussed around back cutting is critical when using wipers. Due to the sharp ends on the insert, excessive spindle tilt can cause dig-in.
Use a PCD Flycutter for Aluminum
PCD inserts are supposed to leave the most amazing finish possible on aluminum. Some machinists keep a PCD-equipped flycutter in their tooling arsenal just for area finishing aluminum.
For a lot more data on using fly cutters, see our Fly Cutter page from our Feeds and Speeds Cookbook.
Use a Radius and Try Round Inserts
Try round inserts for a better finish...
A bullnose or endmill with a radius will leave a finer finish than a flat endmill. If we're talking insertable tooling, use a radius.
Round inserts are most prone to chatter (but if they are not chattering, the big radius leaves a great finish!), while those with a 45 degree lead angle are least prone to vibration and chatter.
Use Sharp Inserts, Lead Angle, and Positive Rake
All things considered, sharper inserts, more lead angle, and positive rake all lead to better surface finish. A 45 degree face mill produces a much nicer finish than a 90 degree square shoulder face mill.
Positive rake cutting geometries will typically require lower cutting forces (resulting in less deflection), and they will produce a finer surface finish. The positive geometry bites into the material's shear planes with less force.
- Prefer sharper inserts. These are often more expensive ground inserts rather than pressed or molded inserts.
Ground CCGT insert with sharp edges...
High Helix and Variable Helix Cutters Can Leave a Better Finish
High helix cutters leave a better finish. Variable helix cutters break up chatter vibrations because the varying helix keeps the vibration from settling on a single frequency.
More Flutes are Equivalent to a Higher RPM for Surface Finishes
More flutes or inserts are equivalent to a higher rpm. Many older mills are limited on their spindle's rpm. Being able to employ more flutes or inserts can restore some of the advantage. Be sure to consider chip clearance. You shouldn't use a 4 flute cutter when slotting in aluminum (there isn't enough chip clearance), but you can use a 3 flute to slot and it is equivalent to 50% more rpm than the 2 flute. Even better, if you are milling around the outside profile (peripheral milling), there may be plenty of clearance for chips to fall away and you could use a 4 flute cutter on aluminum.
A counter argument to using more flutes or inserts is that fewer flutes/inserts are less prone to chatter.
Remove an Insert to Reduce Chatter
You can sometimes break up chatter on a facemill or other indexable tooling by removing an insert. It is the regular striking of the inserts against the workpiece that feeds the vibration. Taking out an insert means that every so often that regular pattern is broken up.
Run a Cutter Backwards to Burnish the Material
Be careful with this technique--it's the fastest way to dull a cutter and if you move the tool into the material much you'll break the tool. However, if you can get a tool you don't care about dulling (just endmills, no indexable tooling!), and you control the tool well enough, it leaves a burnished finish on the workpiece that may be just the ticket for your job.
Climb vs Conventional Milling: Assume Nothing About Which is Best for Finish
This is a complex topic. Climb milling reduces cutting forces and ordinarily that would be the best answer for finish. But, climb deflects into the wall and conventional does not. Read our Climb vs Conventional Milling Page to decide which will be best for your needs.
Climb vs Conventional Milling...
Entering and Exiting the Cut
Roll into and out of your cuts for better surface finish. See our Toolpath page for more info on this technique.
Don't Dwell
Every time the tool stops while in contact with the workpiece it'll leave a mark. Never dwell (stop the tool against the workpiece) when surface finish matters.
Avoid Cutting Down the Centerline
Cutting down the centerline will slap an insert or flute flat against the edge of the material, which creates burrs and generally makes it hard to get great surface finish. Instead of a 50/50 cut down the centerline, choose about 70/30 for a better result.
Tram Your Mill Carefully, or Put it Out of Tram Intentionally
We're talking about facemilling and fly cutting here, or area finishing. When it comes to area finishing, there are two schools of thought on tram and surface finish--either get your mill trammed near perfectly or put it out of tram just a little bit. The considerations are largely aesthetic. If your mill is well trammed, you'll see equal tooling marks on both sides. If the spindle "leans" into the cut a bit, you'll only see one tooling mark. Some folks prefer the symmetry of two marks and some prefer the one. Either way, if finish matters and your mill is trammable, you'll want to retram just before critical finish work is done.
Use the Largest Endmill whose Radius is Less Than the Corner Radius for Finish
The endmill can't cut a corner any smaller than it's own radius, but when the endmill and corner radii are the same, it's particular likely to cause problems. Make the endmill slightly smaller. You may have to increase the corner radius if you customer will allow it, or do something sneaky, like use a metric size if it is closer than the next smaller Imperial size (or vice versa).
If there are no inside corners, use the biggest tool you have that will produce a fine finish. It's size will contribute to rigidity and a smoother finish.
On Lathes, Increase Your Speed to Reduce Edge Buildup
This tip is from Hurco. Basically, the faster you can go, the less likely you'll get edge buildup. Any edge buildup will severely reduce the quality of your surface finish.
On Lathes, Pay Particular Attention to the Tool Nose Radius and It's Relationship to Cut Depth
A larger tool nose radius will be able to accommodate faster speeds before they start leaving a thread-like helix. Inserts are capable of feeding at approximately one half the TNR per revolution, and still produce good results. If this TNR to IPR ratio is exceeded the tool will be creating more of a “thread-like” surface finish, and not the shiny smooth finish that you desire. Therefore, the larger the TNR, the faster the feedrate it can accommodate and still produce the desired results. HOWEVER, using very large TNR’s can produce chatter – do to the increase in cutting pressures - so be careful and consider the speeds required for the materials that you are cutting - use a tool with the TNR that fits your needs.
It is also worth mentioning that the use of a larger tool nose radius will mean that you must leave more material for your finish pass. To ensure that the tool is behaving properly, you must leave equal to, or more than, the TNR for your finish tool to remove. This tip was courtesy of Hurco.
When Using Indexable Tooling on Mills and Lathes, Try a "Wiper" Insert
Wiper Inserts have a small flat area adjacent to the tool nose radius that actually burnishes the finish smooth. The resulting finishes can be pretty sweet.
Use Higher Lead Angles for Milling and Turning, and Prefer Positive Rake
Both will produce a better surface finish. See our article on 45 vs 90 degree Face Mills for more.
Minimize Runout
With runout, your tool (or workpiece on a lathe) spins in an eccentric path instead of a true circle. This is very bad for surface finish. The more runout, the worse the finish. If you know some cutter and toolholder combinations have less runout, prefer them when finishing. For example, an ER collet chuck will amost always have less runout than a setscrew-style endmill holder. Use the collet chuck when finishing.
DFM Tips for Surface Finish
How fine a finish should you spec? If you ask for too much, you drive up the cost to manufacture. Too little and you reduce the quality of your product. If you want the finish that's cheap and cheerful to hit with most CNC machines, specify no finer than a 64 µ" finish. A 32 µ" finish won't add much cost, and a 16 or even an 8 µ" finish can be done, but now you'll be looking at increasing costs. Thanks to ProCNC.com for these tips!
Here is a discussion of the cost of excessive tolerances, which is also applicable to excessive finish requirements.
Toolholders and Surface Finish
Obviously the toolholder has a lot to contribute to the rigidity and vibration dampening of the system. A CAT40 holder is much stiffer than the Bridgeport's R8. Even an NMTB30 has a lot more mass to it than the R8:
I read a fascinating analysis of toolholder efficacy in a graduate thesis out of the University of British Colombia ("Mechanics and Dynamics of the Toolholder Spindle Interface") that raised some good data I hadn't seen before:
- HSK toolholders are as much as 4x stiffer than equivalent sized CAT40 holders. This is mainly due to the dual-face contact of the HSK design.
- The thesis compared the performance of milling chucks, shrink fit, hydraulic chucks,and collet chucks. The most important characteristic for finishing operations is modal stiffness. In order of best to worst performance, here is how the different toolholders ranked:
Tool Holder Type
Modal Stiffness
Dyamic Stiffness
Shrink-fit
0.89
0.065
Collet Chuck
0.75
0.155
Hydraulic
0.53
0.196
Milling Chuck
0.52
0.184
Surprising that the lowly collet chuck performed nearly as well as finicky shrink fit tooling and quite a bit better than more expensive hydraulic and power chuck-style holders!
However where roughing is concerned, the Dynamic Stiffness is important for suppressing chatter. For maximum material removal rates, we want to maximize Dynamic Stiffness. Here the Collet Chuck also performs pretty darned well, and it is in hogging out lots of material that the hydraulic and milling chuck style holders start to come into their own. The shrink-fit performs poorly because the shrink fit doesn't dampen the vibrations, it just holds the tool very very tightly. Makes you wonder if it doesn't make it more likely to ring like a bell when held so tight?
Other toolholder thoughts:
- Consider balancing your toolholders. It's a requirement for rpms over 10K, but it will smooth vibrations even at lower rpms. Obviously tools like flycutters are inherently unbalanced to start with, or must they be? Perhaps a design that is balanced will produce a smoother result.
- Consider runout. A holder with a lot of runout injects a lot of vibration that will ruin surface finish and ultimately break cutters. Smaller cutters are more sensitive to runout. A thousandth of an inch is a lot of runout for a 1/8" cutter to deal with as it is effectively jerking the cutter around in the cut as it rotates.
- Collets often have less runout than setscrew holders. Some complain they don't hold as well. A compromise would be to use set screw holders for larger shanked tooling (say anything over 1/2") and collets for smaller shanks. OTOH, for those that claim the collets don't hold (tools are getting sucked out), others are claiming the toolholder and collet aren't clean, or the nut isn't torqued down tightly enough. The specs for ER collet nut torque are pretty high, so be sure to give the spanner wrench a good tug. Alternatively, I have been using ball bearing nuts which take surprisingly less torque because they have a ball bearing interface with the ER collet instead of trying to spin against the collet as it tightens.
- Integral shanks are almost always stiffer than inserting a shanked tool into a toolholder.
- Various specialized holders are available such as flatback drives that seat the toolholder against a precision spindle face for more support than the taper alone could provide.
Ball nosed cutters: slow nose speed
The biggest challenge with ball nosed end mills of various kinds is slow nose speed. As you get closer to the tip, the diameter on the ball gets smaller and smaller, finally going to zero. As a result, the cutter must perform over a wide range of surface speeds and chiploads at different depths in the cut. Be sure to keep this in mind when using one. If possible, use a feeds and speeds calculator or CAM program that properly accounts for these effects.
Balance the diameter of a ball end cutter versus the rigidity. Remember, the part of the ball near the axis moves slowly. A smaller ball interpolated exposes more of the surface to a faster moving cutter, leading to a better finish. But, the smaller cutter can flex more. Hence the need to balance these two factors.
If you have a 4th axis or 5-axis mill, you can try "Sturz" milling to combat the slow moving tip. See below for details.
Ballnosed Cutters, Surface Finish, and Stepover
Choosing the right stepover for your ballnose is critical for efficient 3D profling. Check out our article on how to choose Stepover for details.
Set Your CAD and CAM Software Up Right for Good Surface Finishes
Our article 7 Software Excuses for Bad Surface Finish can help.
Faceting on part from CADCAM setup issues.
Facets on this part are due to CADCAM issues...
The Truth About "Mirror" Finishes
Anyone who frequents the machining boards online has seen countless threads where someone is asking after how to get a "mirror" finish from their mill or lathe. While it is easier to come close on a lathe, the truth about mirror finishes is that they largely do not exist. Yes, there are machine tools capable of doing optical quality finishes. These are extremely rigid machines that largely use diamond tooling. But, those are not the machines most of us will have access to, and they are not the machines most people are talking about as they ask after a mirror finish.
Have you ever noticed how most photographs of a so-called mirror finish have the workpiece tilted at an extreme angle? Have you ever seen the highway mirage where it looks like there is a pool of water on the road far ahead of you that vanishes as you get closer? Same principle. Even asphalt will apparently have a "mirror" finish (that water you saw in the mirage was a reflection of the sky) if the angle of incidence is right. Ask to see the mirror finish looking straight down on the part and you'll see more clearly what these finishes are all about.
This is not to say that a fine milled finish cannot be extremely attractive, its just that it doesn't really look like a mirror when viewed straight on. The tooling marks will still be visible, but they will be extremely faint grooves. In the best case, you'll see rainbows created by diffraction effects acting on the grooves. It's a look that has been called "prismatic". The closest thing to it is the back of a CD where all the rainbows are, but the milled finish will be a more subtle effect.
That's what you're looking for to decide you have achieved a great finish. If you need to do better, it's time to go to some abrasives of some kind and either user vibratory polish or a buffing wheel.
Next Article: Feeds and Speeds for Fly Cutters and Manual Mills
Featured Articles
CNC Router Cutter Types
Step and Servo Motor Sizing
Feeds and Speeds Guide
CNC Cutter Guide
Feeds and Speeds By Material
Sales, and Special Deals
GCode is complicated.
makes it easy.
Try It!
Feeds and Speeds:
Made Easy.
Try G-Wizard
