Get Better Feeds and Speeds
Instantly
Working with GWC
Very helpful: worth the money.
The most useful speeds and feeds tool I have used.
Excellent. I use this almost every day in coming up with feeds and speeds.
Here’s How:
Spindle Speed and Feed Rate.
Feeds and Speeds Calculator
Adjusts to Your Needs
Turning and Lathe Tools
G-Wizard is truly a full-featured Machining Feeds And Speeds Calculator!
high speed machining calculator hsm advisor
speeds and feeds chart pdf
tungsten feeds and speeds cobalt chrome graphite
Giant Material Database
Expert Tips
cnc machining tips and techniques
machine tool chatter in machining
Tame Chatter in Machining
high pressure through spindle coolant feeds and speeds
Powerful for Experts
The CNC Business can be tough. Get every advantage you can. For example, you paid extra for those special machine options. Programmable Coolant Nozzles. Through Spindle Coolant. High Pressure Coolant.  And G-Wizard will take advantage of those powerful coolant options.  Why use a Calculator that wouldn't?
Take the Tour
See what else people are saying about G-Wizard
have used our software.  We hope you will too.
A collection of logos on a clean white background.
See Our Customer List
  Start Now, It’s Free!
Recently updated on June 21st, 2024 at 07:58 am
