Gear Design Software for CNC Machines
Last modified: July 16, 2024
Interested in Machining Gears or Gear Design?
Then you need Gearotic Gear Design Software.
It's a specialized CAD/CAM program designed for gears by Art Fennerty, the creator of Mach 3.
Close-up photograph of three interlocking wooden or plastic gears with a smiley face carved into the center gear.
Powerful for Experts, Simple for Beginners
Green arrow pointing right.Gear Design Software
Gears are modeled as full mathematical involutes. Design spur gears, escapements, ratchets, elliptical gears, heck design gears with arbitrary shapes that were imaginary, until you create them.
Seriously cool features like point and click spoke design with hundreds of spoke patterns.
Green arrow pointing right.Gear Simulation
Design a gear train and simulate how it will perform.
Green arrow pointing right.CAD Output
DXF, 3D DXF, and STL's supported. Paper printouts at 1:1 scale are also available.
Green arrow pointing right.G-code Output
2 1/2D machining and 4th axis machining of gears. Not all gear types support 4th axis if their tooth model isn't compatible with tangential machining.
Gears on a worktable.
Stylized illustration of a 3D gear with a blue circle at its center on a black background.
Our Guarantee
After purchase, if you're not completely satisfied, tell us within 30 days for a full refund.
If Gearotic alone is not enough, how about a special deal?
You know, a deal deal!
Gearotic normally sells for $120, but we've got some special deals for you. Just click the button to see what they are:
A green rounded rectangle with white text "Buy Gearotic".
Gearotic Purchasing FAQ
Sound Good? It's as Easy as 1, 2, 3:
1. Download the Gearotic demo.
2. Play with it and decide if you like Gearotic.
3. If you like it, purchase using one of our deals.
Want more information? Art has a whole raft of it on the Gearotic web site.
Metal object with a curved shape.
Light-colored metal gear with teeth on a dark workbench.
Golden-colored gear on light purple background with 12 rounded teeth and notched tips, featuring minor surface imperfections.
