You’ve seen the GARR TOOL Feeds & Speeds Calculator.
It’s based on the G-Wizard Engine. Check out Full G-Wizard:
We obsessed over G-Wizard
Speeds and Feeds Calculator:
Feeds and Speeds Calculator
Here’s How:
Spindle Speed and Feed Rate.
Adjusts to Your Needs
Turning and Lathe Tools
high speed machining calculator hsm advisor
speeds and feeds chart pdf
tungsten feeds and speeds cobalt chrome graphite
Giant Material Database
Expert Tips
cnc machining tips and techniques
machine tool chatter in machining
Tame Chatter in Machining
high pressure through spindle coolant feeds and speeds
Powerful for Experts
The CNC Business can be tough. Get every advantage you can. For example, you paid extra for those special machine options. Programmable Coolant Nozzles. Through Spindle Coolant. High Pressure Coolant.  And G-Wizard will take advantage of those powerful coolant options.  Why use a Calculator that wouldn't?
Learn More
Take the Tour
See what else people are saying about G-Wizard
have used our software.  We hope you will too.
cnccookbook customers
See Our Customer List
  Start Now, It’s Free!
