Recently updated on September 17th, 2023 at 10:28 am
You’ve seen the ACME Feeds & Speeds Calculator.
It’s based on the G-Wizard Engine. Check out Full G-Wizard:
We obsessed over G-Wizard
Speeds and Feeds Calculator:
Here’s How:
Spindle Speed and Feed Rate.
Adjusts to Your Needs
Turning and Lathe Tools
Giant Material Database
Expert Tips
Tame Chatter in Machining
G-Wizard has a giant database of pre-defined CNC Machines, plus it's super easy to do your own machine definitions. We'll even create new machine profiles upon request, completely free of charge.
Powerful for Experts
The CNC Business can be tough. Get every advantage you can. For example, you paid extra for those special machine options. Programmable Coolant Nozzles. Through Spindle Coolant. High Pressure Coolant. And G-Wizard will take advantage of those powerful coolant options. Why use a Calculator that wouldn't?
Take the Tour
