We obsessed over G-Wizard
Speeds and Feeds Calculator for Lathes:
“I’ve been asking for this for 30 years from the CAM guys. This program is the ‘go-to’ source for feeds and speeds” Ed
How much do you spend on cutters in a year? If each one lasted 56% longer, you’d save 56% of that. Plus what’s the value of your time saved and time saved on jobs?
G-Wizard pays for itself very quickly–you’ll see in the 30-day Free Trial.
Lathe Features:
Getting good Speeds and Feeds is quick and easy: Fill in the blanks left to right, top to bottom and G-Wizard instantly returns the best Spindle Speed and Feed Rate.
Feeds and Speeds Calculator
How do you know when you’ve got the best Cut Depth and Cut Width? These two parameters matter more than almost any other for best Speeds and Feeds. G-Wizard will find the best value for your insert based on its size, shape, and lead angle.
Adjusts to Your Needs
CADCAM Wizards will do that for you automatically in a matter of seconds and without asking too many questions. It’s like having a machining expert sitting at your shoulder telling you the right combination for the win–another G-Wizard first!
G-Wizard Calculator handles more different kinds of tooling than any other Speeds and Feeds Calculator. Import and Export tables from CSV files, use Manufacturer’s Recommended Data, define tool geometry, and use dozens of tool types for Mills, Routers (special router cutters handled) and Lathes. End Mill Speed and Feed: Coatings (including PCD) & Geometry (Ballnose, Upcut, Downcut, Compression, and more) Drill Feeds and Speeds: Carbide, HSS, and Parabolic Turning and Lathe Tools Reamers, Saws, Woodruff Cutters, Corner Rounders, Tapping, Thread Mills, and Boring Heads
tungsten feeds and speeds cobalt chrome graphite
Giant Material Database
G-Wizard’s cutting physics engine considers nearly 60 variables. No chart will ever do that!
speeds and feeds chart pdf
G-Wizard has a giant database of pre-defined CNC Machines, plus it’s super easy to do your own machine definitions.  We’ll even create new machine profiles upon request, completely free of charge.
Expert Tips
When to start peck drilling or switch to parabolic flutes.
cnc machining tips and techniques
Take the Tour
See what else people are saying about G-Wizard
have used our software.  We hope you will too.
cnccookbook customers
See Our Customer List
  Start Now, It’s Free!
