G-Code and M-Code Command List for CNC Mills [ Examples & Tutorials ]
Complete g code list with m-codes for milling in the Fanuc, LinuxCNC, GRBL, and Haas dialects. We give a quick definition for all g code commands along with a link to tutorials and examples of how to use it. Click the g-code link (if any) to visit a tutorial from our popuplar Online Free G-Code Training that shows examples and teaches how to program CNC machines using the g-code.
G Codes
Code
Category
Function
Notes |
| G00 |
Motion
Move in a straight line at rapids speed. | XYZ of endpoint | ||
| G01 |
Motion
Move in a straight line at last speed commanded by a (F)eedrate | XYZ of endpoint | ||
| G02 |
Motion
Clockwise circular arc at (F)eedrate | XYZ of endpoint IJK relative to center R for radius | ||
| G03 |
Motion
Counter-clockwise circular arc at (F)eedrate | XYZ of endpoint IJK relative to center R for radius | ||
| G04 |
Motion
Dwell: Stop for a specified time. | P for milliseconds X for seconds | ||
| G05 |
Motion
FADAL Non-Modal Rapids | |||
| G09 |
Motion
Exact stop check | |||
| G10 |
Compensation
Programmable parameter input | |||
| G15 |
Coordinate
Turn Polar Coordinates OFF, return to Cartesian Coordinates | |||
| G16 |
Coordinate
Turn Polar Coordinates ON | |||
| G17 |
Coordinate
Select X-Y plane | |||
| G18 |
Coordinate
Select X-Z plane | |||
| G19 |
Coordinate
Select Y-Z plane | |||
| G20 |
Coordinate
Program coordinates are inches | |||
| G21 |
Coordinate
Program coordinates are mm | |||
| G27 |
Motion
Reference point return check | |||
| G28 |
Motion
Return to home position | |||
| G29 |
Motion
Return from the reference position | |||
| G30 |
Motion
Return to the 2nd, 3rd, and 4th reference point | |||
| G32 |
Canned
Constant lead threading (like G01 synchronized with spindle) | |||
| G40 |
Compensation
Tool cutter compensation off (radius comp.) | |||
| G41 |
Compensation
Tool cutter compensation left (radius comp.) | |||
| G42 |
Compensation
Tool cutter compensation right (radius comp.) | |||
| G43 |
Compensation
Apply tool length compensation (plus) | |||
| G44 |
Compensation
Apply tool length compensation (minus) | |||
| G49 |
Compensation
Tool length compensation cancel | |||
| G50 |
Compensation
Reset all scale factors to 1.0 | |||
| G51 |
Compensation
Turn on scale factors | |||
| G52 |
Coordinate
Local workshift for all coordinate systems: add XYZ offsets | |||
| G53 |
Coordinate
Machine coordinate system (cancel work offsets) | |||
| G54 |
Coordinate
Work coordinate system (1st Workpiece) | |||
| G55 |
Coordinate
Work coordinate system (2nd Workpiece) | |||
| G56 |
Coordinate
Work coordinate system (3rd Workpiece) | |||
| G57 |
Coordinate
Work coordinate system (4th Workpiece) | |||
| G58 |
Coordinate
Work coordinate system (5th Workpiece) | |||
| G59 |
Coordinate
Work coordinate system (6th Workpiece) | |||
| G61 |
Other
Exact stop check mode | |||
| G62 |
Other
Automatic corner override | |||
| G63 |
Other
Tapping mode | |||
| G64 |
Other
Best speed path | |||
| G65 |
Other
Custom macro simple call | |||
| G68 |
Coordinate
Coordinate System Rotation | |||
| G69 |
Coordinate
Cancel Coordinate System Rotation | |||
| G73 |
Canned
High speed drilling cycle (small retract) | |||
| G74 |
Canned
Left hand tapping cycle | |||
| G76 |
Canned
Fine boring cyle | |||
| G80 |
Canned
Cancel canned cycle | |||
| G81 |
Canned
Simple drilling cycle | |||
| G82 |
Canned
Drilling cycle with dwell (counterboring) | |||
| G83 |
Canned
Peck drilling cycle (full retract) | |||
| G84 |
Canned
Tapping cycle | |||
| G85 |
Canned
Boring canned cycle, no dwell, feed out | |||
| G86 |
Canned
Boring canned cycle, spindle stop, rapid out | |||
| G87 |
Canned
Back boring canned cycle | |||
| G88 |
Canned
Boring canned cycle, spindle stop, manual out | |||
| G89 |
Canned
Boring canned cycle, dwell, feed out | |||
| G90 |
Coordinate
Absolute programming of XYZ (type B and C systems) | |||
| G90.1 |
Coordinate
Absolute programming IJK (type B and C systems) | |||
| G91 |
Coordinate
Incremental programming of XYZ (type B and C systems) | |||
| G91.1 |
Coordinate
Incremental programming IJK (type B and C systems) | |||
| G92 |
Coordinate
Offset coordinate system and save parameters | |||
| G92 (alternate) |
Motion
Clamp of maximum spindle speed | S | ||
| G92.1 |
Coordinate
Cancel offset and zero parameters | |||
| G92.2 |
Coordinate
Cancel offset and retain parameters | |||
| G92.3 |
Coordinate
Offset coordinate system with saved parameters | |||
| G94 |
Motion
Units per minute feed mode. Units in inches or mm. | |||
| G95 |
Motion
Units per revolution feed mode. Units in inches or mm. | |||
| G96 |
Motion
Constant surface speed | |||
| G97 |
Motion
Cancel constant surface speed | |||
| G98 |
Canned
Return to initial Z plane after canned cycle | |||
| G99 |
Canned
Return to initial R plane after canned cycle | |||
Get a Powerful G-Code Simulator and Editor to Simplify G-Code Work
M Codes
Code
Category
Function
Notes |
| M00 |
M-Code
Program Stop (non-optional) | |||
| M01 |
M-Code
Optional Stop: Operator Selected to Enable | |||
| M02 |
M-Code
End of Program | |||
| M03 |
M-Code
Spindle ON (CW Rotation) | |||
| M04 |
M-Code
Spindle ON (CCW Rotation) | |||
| M05 |
M-Code
Spindle Stop | |||
| M06 |
M-Code
Tool Change | |||
| M07 |
M-Code
Mist Coolant ON | |||
| M08 |
M-Code
Flood Coolant ON | |||
| M09 |
M-Code
Coolant OFF | |||
| M17 |
M-Code
FADAL subroutine return | |||
| M29 |
M-Code
Rigid Tapping Mode on Fanuc Controls | |||
| M30 |
M-Code
End of Program, Rewind and Reset Modes | |||
| M97 |
M-Code
Haas-Style Subprogram Call | |||
| M98 |
M-Code
| M99 |
M-Code
Return from Subprogram | |||
Bonus: Check Out our Other CNC Cookbooks for More In-Depth CNC Information!
If you’re a CNC Beginnner, check out our CNC Beginner’s Cookbook. It’ll get you up to speed with a solid CNC foundation fast.
We also have Cookbooks for Feeds and Speeds, G-Code Programming, CNC Manufacturing and Shop Management, DIY CNC, and don’t forget the CNC Cookbook Blog–with over 4 million visitors a year it’s the most popular CNC blog by far on the web.
More Resources
G Code Commands FAQ
How many G codes are there?
There are about 100 g code commands, give or take. There are many dialects of g-code, and some have proprietary g-codes.
What are G Codes in CNC Machines?
This page lists all the G code commands and tells what they do and also gives a link to tutorials and examples. G codes are single letter commands that tell the CNC machine what to do. They may command motion (i.e. tell the machine where to cut) or do things like turn the spindle on or off.
Is learning G-Code hard?
Learning g-code isn’t very hard. We have a complete free online g-code tutorial to teach you as well as a g-code simulator that makes learning easy.
Why are G Codes used?
G Codes make CNC Machines programmable, which gives them the flexible to make almost any part.
What is the difference between G codes and M codes?
G-Codes are about Geometry while M-Codes are about Machine functions.
Do all CNC machines use G-code?
Not all CNC machine use G-Code. Some may have both g-code and other ways of programming, for example alternate languages such as Mazak’s Mazatrol or Conversational Programming. Others, may have an alternate language and no ability to execute g-code at all.
