The spindle control G-codes control when the spindle is spinning and which direction it spins:
- M03: Start spindle spinning clockwise.
- M04: Start spindle spinning anti-clockwise.
- M05: Stop spindle spinning.
Use the S word to control how many rpms the spindle turns at.
Most M03 and M04 G-codes are issued right after the S word establishes the rpm. For example:
S2000 M03
That G-code will start the spindle running clockwise at 2000 rpm.
Example
Note: For most G-code dialects, the leading 0 is optional. You may refer to M03 as M3, M04 as M4, and M05 as M5 G-code.
