G-Code and M-Code Reference List for CNC Mills
G-Code and M-Code Reference List for Milling
These are the common g-codes and m-codes for milling that G-Wizard Editor supports for Mills. Code categories are the groupings for the g-code Wizard (type Ctrl+G for the Wizard). Function tells what the g-code does, Notes gives a little more information such as the parameters, and Tutorial is a link (if any) to a tutorial from our Online G-Code Tutorial that uses G-Wizard Editor to teach how to program the g-code.
Pssst! Hey, if you’re here looking up g-codes, maybe you’d like to find an easier way. What could be better than software that tells you exactly what each g-code does in plain English?
That’s what G-Wizard Editor is like.
GCode is complicated. G-Wizard Editor makes it easy.
Code
Category
Function
Notes
Tutorials
G00
Motion
Move in a straight line at rapids speed. XYZ of endpoint G00 and MDI. Linear Motion: G00 and G01
G01
Motion
Move in a straight line at last speed commanded by a (F)eedrate XYZ of endpoint G01 and MDI. Linear Motion: G00 and G01
G02
Motion
Clockwise circular arc at (F)eedrate XYZ of endpoint IJK relative to center R for radius G02 / G03 Tutorial and Examples
G03
Motion
Counter-clockwise circular arc at (F)eedrate XYZ of endpoint IJK relative to center R for radius G02 / G03 Tutorial and Examples
G04
Motion
Dwell: Stop for a specified time. P for milliseconds X for seconds Precise Timing and Speed: Dwell, Exact Stop, Backlash Compensation
G05
Motion
FADAL Non-Modal Rapids
G09
Motion
Exact stop check Precise Timing and Speed: Dwell, Exact Stop, Backlash Compensation
G10
Compensation
Programmable parameter input
G15
Coordinate
Turn Polar Coordinates OFF, return to Cartesian Coordinates G15/G16 Polar Coordinates
G16
Coordinate
Turn Polar Coordinates ON G15/G16 Polar Coordinates Polar Coordinate Calculator
G17
Coordinate
Select X-Y plane CNC G-Code Coordinates
G18
Coordinate
Select X-Z plane CNC G-Code Coordinates
G19
Coordinate
Select Y-Z plane CNC G-Code Coordinates
G20
Coordinate
Program coordinates are inches G20 and G21: Unit Conversion
G21
Coordinate
Program coordinates are mm G20 and G21: Unit Conversion
G27
Motion
Reference point return check G28: Return to Reference Point
G28
Motion
Return to home position G28: Return to Reference Point
G29
Motion
Return from the reference position G28: Return to Reference Point
G30
Motion
Return to the 2nd, 3rd, and 4th reference point G28: Return to Reference Point
G32
Canned
Constant lead threading (like G01 synchronized with spindle)
G40
Compensation
Tool cutter compensation off (radius comp.)
G41
Compensation
Tool cutter compensation left (radius comp.)
G42
Compensation
Tool cutter compensation right (radius comp.)
G43
Compensation
Apply tool length compensation (plus)
G44
Compensation
Apply tool length compensation (minus)
G49
Compensation
Tool length compensation cancel
G50
Compensation
Reset all scale factors to 1.0
G51
Compensation
Turn on scale factors
G52
Coordinate
Local workshift for all coordinate systems: add XYZ offsets
G53
Coordinate
Machine coordinate system (cancel work offsets)
G54
Coordinate
Work coordinate system (1st Workpiece)
G55
Coordinate
Work coordinate system (2nd Workpiece)
G56
Coordinate
Work coordinate system (3rd Workpiece)
G57
Coordinate
Work coordinate system (4th Workpiece)
G58
Coordinate
Work coordinate system (5th Workpiece)
G59
Coordinate
Work coordinate system (6th Workpiece)
G61
Other
Exact stop check mode Precise Timing and Speed: Dwell, Exact Stop, Backlash Compensation
G62
Other
Automatic corner override
G63
Other
Tapping mode
G64
Other
Best speed path
G65
Other
Custom macro simple call Subprograms and Macros
G68
Coordinate
Coordinate System Rotation G68 and G69 Tutorial and Examples
G69
Coordinate
Cancel Coordinate System Rotation G68 and G69 Tutorial and Examples
G73
Canned
High speed drilling cycle (small retract)
G74
Canned
Left hand tapping cycle
G76
Canned
Fine boring cyle
G80
Canned
Cancel canned cycle
G81
Canned
Simple drilling cycle
G82
Canned
Drilling cycle with dwell (counterboring)
G83
Canned
Peck drilling cycle (full retract)
G84
Canned
Tapping cycle
G85
Canned
Boring canned cycle, no dwell, feed out
G86
Canned
Boring canned cycle, spindle stop, rapid out
G87
Canned
Back boring canned cycle
G88
Canned
Boring canned cycle, spindle stop, manual out
G89
Canned
Boring canned cycle, dwell, feed out
G90
Coordinate
Absolute programming of XYZ (type B and C systems)
G90.1
Coordinate
Absolute programming IJK (type B and C systems)
G91
Coordinate
Incremental programming of XYZ (type B and C systems)
G91.1
Coordinate
Incremental programming IJK (type B and C systems)
G92
Coordinate
Offset coordinate system and save parameters
G92 (alternate)
Motion
Clamp of maximum spindle speed S
G92.1
Coordinate
Cancel offset and zero parameters
G92.2
Coordinate
Cancel offset and retain parameters
G92.3
Coordinate
Offset coordinate system with saved parameters
G94
Motion
Units per minute feed mode. Units in inches or mm.
G95
Motion
Units per revolution feed mode. Units in inches or mm.
G96
Motion
Constant surface speed G96: Constant Surface Speed
G97
Motion
Cancel constant surface speed G96: Constant Surface Speed
G98
Canned
Return to initial Z plane after canned cycle  G98 G-Code and G99 G-Code: Canned Cycle Return or Feedrate Modes
G99
Canned
Return to initial R plane after canned cycle  G98 G-Code and G99 G-Code: Canned Cycle Return or Feedrate Modes
M-Codes
Code
Category
Function
Notes
Tutorials
M00
M-Code
Program Stop (non-optional)
M01
M-Code
Optional Stop: Operator Selected to Enable
M02
M-Code
End of Program
M03
M-Code
Spindle ON (CW Rotation) M03 and MDI.
M04
M-Code
Spindle ON (CCW Rotation)
M05
M-Code
Spindle Stop M05 and MDI.
M06
M-Code
Tool Change
M07
M-Code
Mist Coolant ON M07 and MDI.
M08
M-Code
Flood Coolant ON M08 and MDI.
M09
M-Code
Coolant OFF M09 and MDI.
M17
M-Code
FADAL subroutine return
M29
M-Code
Rigid Tapping Mode on Fanuc Controls
M30
M-Code
End of Program, Rewind and Reset Modes
M97
M-Code
Haas-Style Subprogram Call Subprograms and Macros
M98
M-Code
M99
M-Code
Return from Subprogram Subprograms and Macros
Bonus: Check Out our Other CNC Cookbooks for More In-Depth CNC Information!
If you’re a CNC Beginnner, check out our CNC Beginner’s Cookbook. It’ll get you up to speed with a solid CNC foundation fast.
We also have Cookbooks for Feeds and Speeds, G-Code Programming, CNC Manufacturing and Shop Management, DIY CNC, and don’t forget the CNC Cookbook Blog–with over 4 million visitors a year it’s the most popular CNC blog by far on the web.
More Resources
Mazatrol Training Classes
Fanuc CNC Training Classes
4 (79.38%) 32 votes
  Thread Calculator
CNC Programming / GCode
  Free Training
  G-Code Simulator
  G-Code / M-Code List
Feeds & Speeds
     Calculator
     Free Calculator
     Free Calculators
