GD&T Symbols Reference Guide - CNCCookbook
Last modified: March 15, 2024
This is your convenient guide for Geometric Dimensioning and Tolerancing (GD&T) symbols.  Click on any link below to lean more about each GD&T symbol or concept. You can also download a PDF version of this information by clicking the button:
Download GD&T Symbols PDF
Control Type
Characteristic
GD&T Symbol
Notes
Form
Flatness
An oblong metal rectangle with slight size variation.
Controls form (shape) of size and non-size features.
Datum reference is not allowed
Straightness
Simple blue line on white background.
Circularity (Roundness)
Blue circle outline on white background.
Controls form (shape) of size features only.
Cylindricity
Blue line drawing of a circle with diagonal measuring line.
Orientation
No relation between features
Perpendicularity
Blue line with two perpendicular extensions.
Controls orientation (tilt) of surfaces, axes, or median planes for size and non-size features.
Datum reference required.
Optional: Angularity symbol may be used for all orientation controls.
Parallelism
Two diagonal lines perfectly aligned.
Angularity
Two intersecting lines forming a corner with a longer top line.
Location
Position
Blue target symbol with intersecting horizontal lines.
Locates center points, axes and median planes for size features. Can also control orientation.  See also True Position.
Profile of a Surface
Half dome metal surface with rounded edges and smooth finish against a white background.
Locates surfaces by describing a tolerance zone around the surface or line.
Can also be used to control size, form, and orientation based on datum reference.
Profile of a Line
Simple blue line graph with single curved line, varying y-axis values and visible x-axis is not marked.
Runout
Total Runout
Blue arrow pointing upwards, set against a light grey background with a subtle blue gradient effect.
Controls surface coaxiality
Can also control form and orientation of surfaces
Circular Runout
A blue arrow with tip on the left, pointing to the right.
Location of derived median points.
Concentricity
Blue concentric circle icon.
Locates derived median points of a feature
Not common, consider position, runout, or profile instead
Symmetry
Horizontal Equal Sign Symbol
Feature Control Frames: Modifiers
Symbol
Modifier
Notes
Black "F" within a white circle on a light grey background.
Free State
Only applies if part is otherwise restrained.
Black circle containing lowercase "L", thin white border.
Least Material Condition (LMC)
Useful to maintain minimum wall thickness
Circular icon with bold M.
Maximum Material Condition (MMC)
Provides bonus tolerance only for a feature of size
Black P in a circular symbol.
Projected Tolerance Zone
Useful on threaded holes for long studs
Black and white logo featuring bold sans-serif letter G within incomplete circular border.
Regardless of Feature Size (RFS)
Not part of the 1994 standard
Capital T letter in a black and white circle.
Tangent Plane
Useful for interfaces where form is not required
White circle with black border containing off-center small white rectangle with two narrow vertical lines.
Unilateral
Appears in the 2009 version and refers to unequal profile distribution
A Feature Control Frame describes the conditions and tolerances of a geometric control on a part’s feature.
Notes:
"RFS" means regardless of feature size.  It simply means that whatever GD&T callout you make, it is controlled independently of the size dimension of the part.  RFS is the default condition of all geometric tolerances (by rule #2 of GD&T) and requires no callout.
These GD&T symbols are provided as a reference for CNCCookbook's free GD&T Tutorial. To learn what they mean, clicks the links, read on or check the Table of Contents for more information.
GD&T Tutorial Home          GD&T Symbols
