Free GD&T Calculator?
Yes, and a whole lot more essential tools for CNC’ers.
Take the free 30-day trial of our G-Wizard CNC Calculator,
try all the features, and when the trial is done,
everything but the Feeds and Speeds features will keep working.
Forever. It’s one of the best deals around.
Here’s How:
Spindle Speed and Feed Rate.
Adjusts to Your Needs
Turning and Lathe Tools
Giant Material Database
Expert Tips
Tame Chatter in Machining
G-Wizard has a giant database of pre-defined CNC Machines, plus it's super easy to do your own machine definitions. We'll even create new machine profiles upon request, completely free of charge.
Powerful for Experts
The CNC Business can be tough. Get every advantage you can. For example, you paid extra for those special machine options. Programmable Coolant Nozzles. Through Spindle Coolant. High Pressure Coolant. And G-Wizard will take advantage of those powerful coolant options. Why use a Calculator that wouldn't?
Take the Tour
