CNC Reference Data
Useful Reference Data Links
ACME Tap Information: Which drill do I use for an ACME tap? ChipBlaster : Makers of High Performance Coolant Systems. Data on feeds & speeds when used with such a system together with data on the cooling system capacities needed to achieve these levels. Collets: Great source of data on collet dimensions. CNC Plastics: Lots of data on plastics. End Mills: Hanita’s tech info page. Lots of data on end mills, troubleshooting, and how to select the proper one for your application. Geometric Dimensioning and Tolerancing How to Use a Lathe: Lots of detailed basic information, including how to grind your lathe tools. Imperial Socket Head Cap Bolt Dimensions Marv Klotz’s Utilities: Software for people that make things. Milling Machine Tapers: Lots of data and dimensions on milling machine tapers. MyYellowCoat: Sandvik’s great information site. Lots of good machining articles. Niagara New Concepts in Milling Handbook: Niagara’s guide to selecting milling cutters and their use. NIST G-Code Standard: A definition of the CNC g-code language (RS274). Notes on Tapers: Specs for many common tapers. O-Rings: Great chart for finding the proper o-ring size. Steel Data: Information and articles about steel. Thread Milling Handbook: By Vargus. Tons of good info. Tools & Gizmos Taper Specs: Ridiculously complete! Tribology: Tons of interesting information, articles, and calculators pertaining to friction, lubrication, and wear. US Army’s Fundamentals of Machine Tools G-Wizard For Feeds and Speeds, Threads, Fasteners, Trig Calculations, and More: G-Wizard Be sure to check out G-Wizard! Bearing Data R8 Collet Dimensions 5C Collet Dimensions Capacities: Round: 1 1/16″ Square: 3/4″ Hex: 29/32″ Carbide Insert Dimensions Inscribed Circle: ¼” Thickness: 3/32″ Nose Radius: 1/64″ Insert Hole Diameter: 0.110″ Tip Angle: 80 degrees / 100 degrees Side Length: 0.248″ Max Depth of Cut = ½ to ¼ the inscribed circle TPGB 21 |
