GW Editor Showed Me Exactly Where The Errors Were
“My experience: No formal training. Completed some on-line courses for CAM software. I have been running a VMC on the average of 1x every two weeks since July of 2015. I have been using FeatureCAM as my CAM software and was having intermittent issues with the G-code when I transferred the file to my mill. So I opened the problem files with GW Editor and low and behold it showed me exactly where the errors were in my file. Now I run every file through GW Editor before I ever try to run it on my mill.”
Based on 24 reviews
A G-Code Editor and Simulator with
Everything You Need
Extensive Error Checking
Software that will make anyone a better CNC’er
Proof your g-code faster before running it, make it easier to understand, create quick and easy g-code programs without CADCAM.
It’s that easy. You can install and get results in a matter of minutes.
But cutting “air” is slow as molasses and keeps your CNC machines unproductive. G-Wizard Editor will do a full graphical toolpath simulation, plus it will check a number of nearly invisible conditions that can “alarm out” and stop your CNC machine.
Get your programs running right before they ever get on your CNC machines.
Click here to see how GW Editor can help you test your g-code.
From Scratch
G-CODE
G-Code is Complicated. G-Wizard makes it Easy.
Remember the first time you saw g-code? Scary stuff.
But G-Wizard is filled with features that help you understand and write g-code the easy way. For starters, its “Hints” feature tells you what each line of g-code does in plain English. Plus, there’s a lot more capabilities designed to simplify g-code so it’s easier to learn and use.
Click here to see how GW Editor can help you understand g-code.
Only the best thing since sliced bread. With Conversational Programming, you answer a few simple questions in a Wizard, and it will generate the g-code. No need for complex CAD or CAM. Do all those jobs where you thought you’d rather have a manual machine than a CNC just as easily.
Great for beginners and manual machinists who want to be productive before learning CAD/CAM. And great for experts who don’t want to wait for CAD/CAM to do something simple.
Click here to see Conversational Programming.
From Errors Before
Running it
Generated G-Code
Macro Programming
Macro Programming lets you do things your CAM software can’t. Powerful things that save time and will make you money.
But macros are not the easiest things in the world to wrestle with. Unless you have G-Wizard Editor standing by your side. Check out how it can help you become a Macro Programming virtuoso!
Click here to see how GW Editor helps with macro programming.
