CUSTOMER SUCCESS
TRUSTED BY INDUSTRY LEADERS
CNC Router Features:
Spindle Speed and Feed Rate.
Feeds and Speeds Calculator
Adjusts to Your Needs
Feeds and Speeds for Wood
G-Wizard has over 1000 materials in its Materials Database, including hundreds of species of wood. It individually adjusts feeds and speeds for each wood species you select to get the best results.
Tool Types Especially for CNC Routers
G-Wizard handles more tool types than other software can. Best of all, it has built-in support for the special cutter bits common to CNC Routers such as Downcut, Compression, and Straight Flute cutters.
Turning and Lathe Tools
high speed machining calculator hsm advisor
speeds and feeds chart pdf
machine tool chatter in machining
Tame Chatter in Machining
Expert Tips
cnc machining tips and techniques
Stop Part Pop Off from Vacuum Tables
If you use a vacuum table you know what a pain it is when your parts pop off the table. G-Wizard has the ability to provide feeds and speeds that limit cutting forces based on your part so it won't pop off.
Quit scrapping parts because they pop off your vacuum table!
Powerful for Experts
Learn More
high pressure through spindle coolant feeds and speeds
Easy for Beginners, even with small CNC Routers
G-Wizard is not just for Pros, we've got beginners and hobbyists covered too.
G-Wizard Calculator has machine profiles for the Carbide3D Nomad and Shapeoko already built-in. You can modify these for the specs of your own CNC Router--even DIY Routers. Plus G-Wizard will adjust feeds and speeds to account for the rigidity of
your machine. No more one size fits all feeds and speeds!.
Plus, we offer free training courses, built in Getting Started Tours, Examples, and much more. CNCCookbook is the world's most comprehesive free online information resource for CNC'ers. Take advantage of it with G-Wizard!
make your CNC Router Speeds and Feeds easier
  Start Now, It’s Free!
Show me how to improve feeds and speeds for:
You need G-Wizard Calculator!
