Software Trusted by Engineers at NASA, Tesla, and over 20,000 CNC'ers worldwide!
CUSTOMER SUCCESS
Essential Software for CNC Routers
“I’ve been asking for this for 30 years from the CAM guys. This program is the ‘go-to’ source for feeds and speeds”
Based on 73 reviews
CNC Router Features
Get Speeds and Feeds in Seconds
Getting good Speeds and Feeds is quick and easy: Fill in the blanks left to right, top to bottom and G-Wizard instantly returns the best Spindle Speed and Feed Rate.
Improve My CNC Router Speeds and Feeds
Quick setup. Free for 30 days.
Adjusts to Your Needs
Feeds and Speeds for Wood
G-Wizard has over 1000 materials in its Materials Database, including hundreds of species of wood. It individually adjusts feeds and speeds for each wood species you select to get the best results.
Tool Types Especially for CNC Routers
G-Wizard handles more tool types than other software can. Best of all, it has built-in support for the special cutter bits common to CNC Routers such as Downcut, Compression, and Straight Flute cutters.
Spoilboard Cutters: Built right in
Speaking of Tool Types for Routers, G-Wizard has built-in support for the most popular spoilboard cutters used with CNC Routers.
Turning and Lathe Tools
But figuring HSM feeds and speeds can also take magic, unless you have G-Wizard CNC Router Feeds and Speeds Calculator.
Tame Chatter in Machining
Expert Tips
Stop Part Pop Off from Vacuum Tables
If you use a vacuum table you know what a pain it is when your parts pop off the table. G-Wizard has the ability to provide feeds and speeds that limit cutting forces based on your part so it won't pop off.
Quit scrapping parts because they pop off your vacuum table!
Powerful for Experts
Easy for Beginners, Even With Small CNC Routers
G-Wizard is not just for Pros, we've got beginners and hobbyists covered too.
G-Wizard Calculator has machine profiles for the Carbide3D Nomad and Shapeoko already built-in. You can modify these for the specs of your own CNC Router--even DIY Routers. Plus G-Wizard will adjust feeds and speeds to account for the rigidity of
your machine. No more one size fits all feeds and speeds!.
Plus, we offer free CNC Router training courses, built in Getting Started Tours, Examples, and much more. CNCCookbook is the world's most comprehesive free online information resource for CNC'ers. Take advantage of it with G-Wizard!
G-Wizard has a giant database of pre-defined CNC Machines, plus it's super easy to do your own machine definitions. We'll even create new machine profiles upon request, completely free of charge.
Our frustration free CNC Calculator is guaranteed to make your CNC Router Speeds and Feeds easier
