Welcome to the Feeds & Speeds Master Class!
Welcome to Free CNCCookbook Feeds & Speeds Master Class!
We’re here to teach you all about Feeds & Speeds, from the basics all the way through to the most advanced cutting edge techniques (pardon our pun).
Each week on Friday, we’ll send you an email with the current week’s lesson.  Each lesson will take maybe 15 minutes to cover, so it’s not a big time commitment and the lessons are bite-sized and easy to understand.
But, you’ll find your knowledge builds fast, and there’ll be a link on each lesson that lets you jump ahead to the next lesson if you want to move through the course more quickly.  We recommend you use the jump-ahead links whenever you find a lesson was particularly easy or something you already knew.
Course Pre-Requisite
BTW, all of these concepts are built into our G-Wizard Feeds and Speeds software.  If you don’t have it already, either as a customer or as a free trial, you’ll need to sign up for the free 30-day trial so you can experiment with the new concepts as you learn them in the course.
It’s a pre-requisite for the course, but it’s easy to sign up and the trial is free:
feeds and speeds calculator
If it turns out you already did the trial at some time in the past and it expired, just send a note to support@cnccookbook.com asking for the trial to be renewed.
Bookmark this page as it will serve as our course syllabus.  As each lesson is available, I will add a link to it below.
Thanks for joining!
Course Lessons & Syllabus
Beginning Lessons
Lesson 1:  Feeds & Speeds Sweet Spots
Lesson 2:  How to Use a Feeds & Speeds Calculator
Lesson 3:  Chip Thinning & Rubbing
Lesson 4:  Tool Deflection
Lesson 5:  Cut Depth & Cut Width
Lesson 6:  Cutting Speed Formulas + How to CNC’ers Calculate Feeds & Speeds
Intermediate Lessons
Lesson 7:  Surface Finish, Finish Cuts, and Tortoise-Hare Slider
Lesson 8: Solid Carbide Endmill Grades & Coatings
Lesson 9:  Drilling Speeds and Feeds
Lesson 10:  The Role of Coolant
Lesson 11: High Speed Machining
Lesson 12: Climb vs Conventional Milling
Advanced Lessons
Lesson 13: Fine Tuning for Machine, Tool, & Task
Lesson 14: Chatter When Milling or Turning
Lesson 15: Deep Hole Drilling
Lesson 16: Micromachining
Lesson 17: CAM Toolpath Tips & Techniques
Lesson 18: Deep Pocket Milling
Lesson 19: Minimal Quantity Lubrication and Dry Machining
