Awesome! This page offers two Free Online Speeds and Feeds Calculators.
We provide Hss End Mill Feeds And Speeds with simple shop formulas, and a full-featured, industry-leading calculator available for free (for a limited time). It?s used daily by thousands of top manufacturers worldwide.
They know what they?re doing and wouldn?t waste time or money if the software didn?t work.
Why use the simple free calculator when you can get our full-featured G-Wizard Feeds and Speeds Calculator free for 30 days? Try it now.
It takes just 37 seconds to download and start using G-Wizard. It?s free for 30 days, and you?ll get great feeds and speeds. After that, you can always switch back to our free online calculator.
Take advantage of the high-performance model while it?s free!
Spindle Speed Calculator
Tool Diameter
inches
Spindle Speed:
RPM
Feed/Tooth (Chipload):
IPT (inches / tooth)
Number of Flutes (Teeth):
Feed Rate:
IPM (inches / minute)
Material
Surface Speed (SFM)
Aluminum - Wrought (6061)
250
Brass
200
Cast Iron - Ductile
90
Cast Iron - Gray
100
Copper Alloy - Wrought
120
Magnesium Alloy
250
Stainless Steel
30
Steel - Mild
110
Steel - Hard Alloy
60
Steel - Tool
60
500
Material
Surface Speed (SFM)
250
Brass
200
Cast Iron - Ductile
80
Cast Iron - Gray
120
70
Magnesium Alloy
250
Stainless Steel
30
Steel - Mild
110
Steel - Hard Alloy
60
Steel - Tool
60
Material
Chipload (IPT)
0.005 - 0.010
Brass
0.005 - 0.010
Cast Iron - Ductile
0.004 - 0.008
Cast Iron - Gray
0.002 - 0.006
0.004 - 0.008
Magnesium Alloy
0.005 - 0.010
Stainless Steel
0.002 - 0.006
Steel - Mild
0.002 - 0.010
Steel - Hard Alloy
0.002 - 0.006
Steel - Tool
0.002 - 0.006
Hang on: You Deserve Better!
Software that makes anyone a better CNC'er... Even beginners:
How to Calculate Material Removal Rate?
To find the highest Material Removal Rate while maintaining tool life, use our G-Wizard Calculator. If you're using the free calculator, check out the Material Removal Rate Formula.
How to Calculate Feed Rate?
Need to calculate feed rate or create a spreadsheet?
Basic feed rate formulas for milling are simple, but real-world feeds and speeds are more complex. Find all the basic formulas in our free online Feeds and Speeds Course.
Milling Speeds and Feeds Calculator
Chip Load Calculator
Simple Feeds and Speeds Calculator
Tapping Feeds and Speeds Calculator
Next Feeds and Speeds Calculator
Prev Feeds and Speeds Calculator
Master Feeds and Speeds Calculator List
