G-Wizard Speeds and Feeds Calculator:
Beginner & Hobbyist’s Best Friend
We’ve been teaching folks how to be Better CNC’ers for years.
I’ve personally spoken to and helped thousands of them along the way. Every time I helped someone out with a problem, I asked myself:
How can G-Wizard have helped them to help themselves? How could it help avoid problems before they start? How can it teach? How can it give tips that experts take years of experience to learn?
It wasn’t easy, but we’ve built all that into G-Wizard, making it the Beginner and Hobbyist’s Best CNC Friend and Mentor.
There’s even a special pricing plan that’s easy on the hobbyist’s pocketbook. G-Wizard can serve you on your CNC journey from the beginning until you’re an Expert too.
“Haven’t wasted a tool since GWizard. I’m still a rookie at machining and have made lots of mistakes. In contrast to my experience before GWizard, it’s a weird feeling cutting something new or using a new tool or doing something particularly aggressive—pressing the start button and waiting for something terrible to happen, and the tool just starts gliding through the workpiece. ” Aaron
Over 300 of the best schools and CNC programs in the country use G-Wizard to help teach their students CNC. It will help you too!
How much do you spend on cutters in a year? If each one lasted 56% longer, you’d save 56% of that. Plus what’s the value of your time saved and time saved on jobs?
G-Wizard pays for itself very quickly–you’ll see in the Free Trial.
Better Tool Life. Less Frustration.
Feeds & Speeds The Easy Way.
Spindle Speed and Feed Rate.
How do you know when you’ve got the best Cut Depth and Cut Width? These two parameters matter more than almost any other for best Speeds and Feeds. Experts take years of experience to learn the right combinations, and even then, G-Wizard can do it better.
G-Wizard will find the best combination to keep tool deflection under control while maximizing Material Removal Rate. No other software does that.
Adjusts to Your Needs
How often do you get to experiment with hundreds of different feed and speed combinations to find the best one for your job? As a Beginner, where would you even start.
CADCAM Wizards will do that for you automatically in a matter of seconds and without asking too many questions. It gives you a complete recipe for roughing and finishing. It’ll even tell you the best tool for the job. It’s like having a machining expert sitting at your shoulder telling you the right combination for the win–another G-Wizard first!
Extensive Tool Coverage & Visual Menus
G-Wizard Calculator handles more different kinds of tooling than any other Speeds and Feeds Calculator. For example, it covers the specialized cutters used by CNC Routers, which the other popular calculators don’t.
Even better–it has extensive Visual Menus. Even if you don’t know all the right terminology, you can still tell when you’ve chosen the right tool. Check the comprehensive Line-Up:
CNC Router Bits: Upcut, Downcut, Compression, Straight Flute, Spoilboard Surfacing, V-Bits, and more!
Turning and Lathe Tools
Tours, Videos, Glossaries: Best Training Anywhere
G-Wizard includes built-in Tours, Training Videos, Glossaries, and so much more. Plus, it’s backed by CNCCookbook, the Internet’s best CNC Training Resource. There are literally hundreds and hundreds of articles and videos on how to use G-Wizard for every possible situation. Everything you need to go from Beginner to Advanced.
Let’s admit it–they were confusing and hard to use anyway.
G-Wizard’s cutting physics engine considers nearly 60 variables. No chart will ever do that!
Beyond that, G-Wizard’s defaults are conservative. You don’t have to look up anything in those manufacturer’s catalogs until you’re ready to unleash every last iota of performance.
Giant Material Database
Plus, we add new materials on request. As a Beginner, you want to know that the Material you’ll be cutting is in the database so there’s no guesswork. We’ve got you covered!
Tips for Beginners from the Experts
When to use climb vs conventional milling. When to start peck drilling or switch to parabolic flute?
And what about the simple stuff too, that the Experts take for granted so you never hear them?
G-Wizard will remember all of that for you. It even has a comprehensive Cheat Sheet to help you bend Feeds and Speeds to your special needs.
Support for Small, Entry, and Hobby-Level Machines
What, you don’t have a 5000lb industrial CNC machine in your garage? Hey, we understand totally–few hobbyists do!
But the simple truth is that small machines cut differently than big ones. You have to adjust your feeds and speeds accordingly. We have more experience doing that than anyone else on the planet.
Tormach sells G-Wizard because of it. We’re also buddies with Carbide3D and the Shapeoko people.
There are literally thousands of G-Wizard customers with small machines, and we’ll walk you through exactly how to set up G-Wizard to take best advantage of your machine, without going overboard.
Special Pricing for Hobbyists and Beginners
We call it “G-Wizard Lite”, but it’s the exact same software. But, the deal is, after the initial subscription expires, G-Wizard adds a spindle power limit. Everything else keeps working for life, including all updates and tech support. Guess what? As a Hobbyist, your machine doesn’t have a 30 Horsepower spindle. It has a spindle with 1-3 Horsepower.
So, pay for a 1 year subscription and you have Feeds and Speeds for 1 Horsepower for life. Buy a 3 year subscription and you get 3 Horsepower for life. We invented that pricing scheme and were the first to offer it because we knew we had to keep the price within a hobby budget.
Take the Tour
See Our Customer List
