Solve Dozens of CNC Related Problems with our Free CNC Calculator
Try our G-Wizard for Speeds and Feeds, but even if you don’t choose to buy, keep using dozens of free CNC Calculators–everything but the Feeds and Speeds!
Here’s the deal:
We obsessed over G-Wizard
Speeds and Feeds Calculator
we built a powerful cutting physics engine with advanced algorithms
that consider almost 60 different variables,
and we worked with over 50,000 CNC’ers
  Start Now, It’s Free!
[ Sign Up ]
“I’ve been asking for this for 30 years from the CAM guys. This program is the ‘go-to’ source for feeds and speeds” Ed
How much do you spend on cutters in a year? If each one lasted 56% longer, you’d save 56% of that. Plus what’s the value of your time saved and time saved on jobs?
G-Wizard pays for itself very quickly–you’ll see in the 30-day Free Trial.
Mill Features:
Speeds and Feeds. Super simple for Beginners, powerful and flexible for Pros. Plus, the best training materials anywhere free with the product.
How do you know when you’ve got the best Cut Depth and Cut Width? These two parameters matter more than almost any other for best Speeds and Feeds.
Adjusts to Your Needs
G-Wizard makes it easy to dial in
exactly
CADCAM Wizards will do that for you automatically in a matter of seconds and without asking too many questions. It’s like having a machining expert sitting at your shoulder telling you the right combination for the win–another G-Wizard first!
Import and Export tables from CSV files, use Manufacturer’s Recommended Data, define tool geometry, and use dozens of tool types for Mills, Routers (special router cutters handled) and Lathes.
Geometry, Threads and More:
Free for Life
G-Wizard isn’t just Speeds and Feeds, it has the most comprehensive reference resources available in any software package. And everything but the Feeds and Speeds is yours for free–just for trying G-Wizard.
G-Wizard works for Mills, Lathes, and Routers.
Take the Tour
Over 60,000 machinists from hundreds of companies
See our Customer List
Our frustration free software is guaranteed to make your Speeds and Feeds easier
