Improve My Tool Life, Surface Finish,
and Cycle Times on My CNC Mill
We obsessed over G-Wizard
Speeds and Feeds Calculator for You:
Feeds and Speeds Calculator
“I’ve been asking for this for 30 years from the CAM guys. This program is the ‘go-to’ source for feeds and speeds” Ed
better tool life faster cycle time feeds and speeds
How much do you spend on cutters in a year? If each one lasted 56% longer, you’d save 56% of that. Plus what’s the value of your time saved and time saved on jobs?
G-Wizard pays for itself very quickly–you’ll see in the 30-day Free Trial.
The Easy Way.
Spindle Speed and Feed Rate.
How do you know when you’ve got the best Cut Depth and Cut Width? These two parameters matter more than almost any other for best Speeds and Feeds.
Adjusts to Your Needs
CADCAM Wizards will do that for you automatically in a matter of seconds and without asking too many questions. It’s like having a machining expert sitting at your shoulder telling you the right combination for the win–another G-Wizard first!
Import and Export tables from CSV files, use Manufacturer’s Recommended Data, define tool geometry, and use dozens of tool types for Mills, Routers (special router cutters handled) and Lathes.
Turning and Lathe Tools
high speed machining calculator hsm advisor
High Speed Machining. It’s almost magic the way it increases productivity while saving tool life.
G-Wizard’s cutting physics engine considers nearly 60 variables. No chart will ever do that!
speeds and feeds chart pdf
tungsten feeds and speeds cobalt chrome graphite
Giant Material Database
Expert Tips
cnc machining tips and techniques
machine tool chatter in machining
Tame Chatter in Machining
Powerful for Experts
Learn More
high pressure through spindle coolant feeds and speeds
Easy for Beginners
G-Wizard is not just for Pros, we’ve got beginners and hobbyists covered too.
Plus, we offer free training courses, built in Getting Started Tours, Examples, and much more. CNCCookbook is the world’s most comprehesive free online information resource for CNC’ers. Take advantage of it with G-Wizard!
Take the Tour
See what else people are saying about G-Wizard
have used our software.  We hope you will too.
cnccookbook customers
See Our Customer List
  Start Now, It’s Free!
