Hss End Mill Speeds And Feeds
Last modified: June 10, 2024
Great news! This page features two Free Online Speeds and Feeds Calculators.
Try Cnc Router Speeds And Feeds Calculator using simple shop formulas and a full-featured, industry-leading calculator (free for a limited time). Trusted daily by thousands of top manufacturers.
They rely on the software because it works and saves them time and money.
Why use the basic free calculator when you can try our full-featured G-Wizard Feeds and Speeds Calculator free for 30 days? Download it now.
It takes just 37 seconds to download and start using G-Wizard. It's free for 30 days, offering excellent feeds and speeds. After that, you can return to our free online calculator if you prefer.
Enjoy the high-performance model while it?s free!
A photograph of an industrial milling machine.
Dark gray CNC router with flat top surface and control panel on solid gray background.
A sepia-toned image of a man sitting in front of a machine, with a workshop background and a "Beginner / Hobbyist" text box overlay.
Spindle Speed Calculator
Tool Diameter
inches
Spindle Speed:
RPM
Feed/Tooth (Chipload):
IPT (inches / tooth)
Number of Flutes (Teeth):
Feed Rate:
IPM (inches / minute)
Material
Surface Speed (SFM)
Aluminum - Wrought (6061)
250
Brass
200
Cast Iron - Ductile
90
Cast Iron - Gray
100
Copper Alloy - Wrought
120
Magnesium Alloy
250
Stainless Steel
30
Steel - Mild
110
Steel - Hard Alloy
60
Steel - Tool
60
500
Material
Surface Speed (SFM)
250
Brass
200
Cast Iron - Ductile
80
Cast Iron - Gray
120
70
Magnesium Alloy
250
Stainless Steel
30
Steel - Mild
110
Steel - Hard Alloy
60
Steel - Tool
60
Material
Chipload (IPT)
0.005 - 0.010
Brass
0.005 - 0.010
Cast Iron - Ductile
0.004 - 0.008
Cast Iron - Gray
0.002 - 0.006
0.004 - 0.008
Magnesium Alloy
0.005 - 0.010
Stainless Steel
0.002 - 0.006
Steel - Mild
0.002 - 0.010
Steel - Hard Alloy
0.002 - 0.006
Steel - Tool
0.002 - 0.006
Hang on: You Deserve Better!
Software that makes anyone a better CNC'er...  Even beginners:
A screenshot of the GWizard Machinist's Calculator tool on a machining website.
