Awesome! This page offers two Free Online Speeds and Feeds Calculators.
Use Cutting Speeds And Feeds Calculator with simple shop formulas and access a full-featured, industry-leading calculator (free for a limited time). Thousands of top manufacturers rely on it daily.
They trust the software because it saves them time and money.
Why use the basic free calculator when you can try our full-featured G-Wizard Feeds and Speeds Calculator free for 30 days? Get it now.
It takes only 37 seconds to download and start using G-Wizard. It?s free for 30 days, providing excellent feeds and speeds. After that, you can switch back to our free online calculator if you prefer.
Make the most of the high-performance model while it?s free!
Easy Speeds And Feeds
Spindle Speed Calculator
Tool Diameter
inches
Spindle Speed:
RPM
Feed/Tooth (Chipload):
IPT (inches / tooth)
Number of Flutes (Teeth):
Feed Rate:
IPM (inches / minute)
Material
Surface Speed (SFM)
Aluminum - Wrought (6061)
250
Brass
200
Cast Iron - Ductile
90
Cast Iron - Gray
100
Copper Alloy - Wrought
120
Magnesium Alloy
250
Stainless Steel
30
Steel - Mild
110
Steel - Hard Alloy
60
Steel - Tool
60
500
Material
Surface Speed (SFM)
250
Brass
200
Cast Iron - Ductile
80
Cast Iron - Gray
120
70
Magnesium Alloy
250
Stainless Steel
30
Steel - Mild
110
Steel - Hard Alloy
60
Steel - Tool
60
Material
Chipload (IPT)
0.005 - 0.010
Brass
0.005 - 0.010
Cast Iron - Ductile
0.004 - 0.008
Cast Iron - Gray
0.002 - 0.006
0.004 - 0.008
Magnesium Alloy
0.005 - 0.010
Stainless Steel
0.002 - 0.006
Steel - Mild
0.002 - 0.010
Steel - Hard Alloy
0.002 - 0.006
Steel - Tool
0.002 - 0.006
Hang on: You Deserve Better!
Software that makes anyone a better CNC'er... Even beginners:
Milling Speeds and Feeds Calculator
Chip Load Calculator
Simple Feeds and Speeds Calculator
Tapping Feeds and Speeds Calculator
Next Feeds and Speeds Calculator
Prev Feeds and Speeds Calculator
Master Feeds and Speeds Calculator List
