Axial End Mill Speeds And Feeds
Last modified: June 10, 2024
Great news! This page offers two Free Online Speeds and Feeds Calculators.
Explore both HSS Feeds and Speeds with simple shop formulas and a full-featured calculator (free for a limited time) that is the industry leader, trusted by top manufacturers worldwide.
They use this software because it works and saves them time and money.
Why use the simple free calculator when you can try our full-featured G-Wizard Feeds and Speeds Calculator free for 30 days? Get it now.
It takes just 37 seconds to download and start using G-Wizard. It痴 free for 30 days and provides excellent feeds and speeds. After that, you can always return to our free online calculator.
Take advantage of the high-performance model while it痴 free!
A photograph of an industrial milling machine.
Dark gray CNC router with flat top surface and control panel on solid gray background.
A sepia-toned image of a man sitting in front of a machine, with a workshop background and a "Beginner / Hobbyist" text box overlay.
Spindle Speed Calculator
Tool Diameter
inches
Spindle Speed:
RPM
Feed/Tooth (Chipload):
IPT (inches / tooth)
Number of Flutes (Teeth):
Feed Rate:
IPM (inches / minute)
Material
Surface Speed (SFM)
Aluminum - Wrought (6061)
250
Brass
200
Cast Iron - Ductile
90
Cast Iron - Gray
100
Copper Alloy - Wrought
120
Magnesium Alloy
250
Stainless Steel
30
Steel - Mild
110
Steel - Hard Alloy
60
Steel - Tool
60
500
Material
Surface Speed (SFM)
250
Brass
200
Cast Iron - Ductile
80
Cast Iron - Gray
120
70
Magnesium Alloy
250
Stainless Steel
30
Steel - Mild
110
Steel - Hard Alloy
60
Steel - Tool
60
Material
Chipload (IPT)
0.005 - 0.010
Brass
0.005 - 0.010
Cast Iron - Ductile
0.004 - 0.008
Cast Iron - Gray
0.002 - 0.006
0.004 - 0.008
Magnesium Alloy
0.005 - 0.010
Stainless Steel
0.002 - 0.006
Steel - Mild
0.002 - 0.010
Steel - Hard Alloy
0.002 - 0.006
Steel - Tool
0.002 - 0.006
Hang on: You Deserve Better!
Software that makes anyone a better CNC'er...  Even beginners:
A screenshot of the GWizard Machinist's Calculator tool on a machining website.
How to Calculate Material Removal Rate?
Generally, you want to find the highest Material Removal Rate that will keep reasonable tool life.? Our G-Wizard Calculator automates much of that process.? But, if you are using the free calculator above, you may want to click through this article to find the Material Removal Rate Formula.
How to Calculate Feed Rate?
Wondering how to calculate feed rate?? Perhaps so you can create your own spreadsheet?
The basic feed rate formulas for milling are simple, but getting real-world feeds and speeds are quite a bit harder.? We give you all the basic formulas in our free online Feeds and Speeds Course.
