G-Wizard CNC Router
Speeds and Feeds Calculator
and we worked with over 100,000 CNC'ers
like yourself to make sure you'd have
[ Sign Up ]
"I've been asking for this for 30 years from the CAM guys. This program is the ‘go-to' source for feeds and speeds" Ed
How much do you spend on cutters in a year? If each one lasted 56% longer, you'd save 56% of that. Plus what's the value of your time saved and time saved on jobs?
G-Wizard pays for itself very quickly-you'll see in the 30-day Free Trial.
CNC Router Features:
Spindle Speed and Feed Rate.
Adjusts to Your Needs
Feeds and Speeds for Wood
G-Wizard has over 1000 materials in its Materials Database, including hundreds of species of wood. It individually adjusts feeds and speeds for each wood species you select to get the best results.
Tool Types Especially for CNC Routers
G-Wizard handles more tool types than other software can. Best of all, it has built-in support for the special cutter bits common to CNC Routers such as Downcut, Compression, and Straight Flute cutters.
CADCAM Wizards will do that for you automatically in a matter of seconds and without asking too many questions. It's like having a machining expert sitting at your shoulder telling you the right combination for the win-another G-Wizard first!
Turning and Lathe Tools
Tame Chatter in Machining
Expert Tips
Stop Part Pop Off from Vacuum Tables
If you use a vacuum table you know what a pain it is when your parts pop off the table. G-Wizard has the ability to provide feeds and speeds that limit cutting forces based on your part so it won't pop off.
Quit scrapping parts because they pop off your vacuum table!
Powerful for Experts
Easy for Beginners, even with small CNC Routers
G-Wizard is not just for Pros, we've got beginners and hobbyists covered too.
G-Wizard Calculator has machine profiles for the Carbide3D Nomad and Shapeoko already built-in. You can modify these for the specs of your own CNC Router-even DIY Routers. Plus G-Wizard will adjust feeds and speeds to account for the rigidity of
your machine. No more one size fits all feeds and speeds!.
Plus, we offer free training courses, built in Getting Started Tours, Examples, and much more. CNCCookbook is the world's most comprehesive free online information resource for CNC'ers. Take advantage of it with G-Wizard!
Take the Tour
](/g-wizard-calculator-tour/)
"I'm in my 27th year and seen my share of ‘machinist aid' software and this BY FAR packs the most punch for the dollar. Shop owners would be fools not having a copy." Michael
"I'm a total Newbie on hobby mill and had the crazy idea to jump right in on some plasma cut hardened steel. WOW! I did it and could not have done it without G-Wizard. I completed our very first EVER customer part in about 1 hour." Jeffrey
"I am amazed at all the data that is available when using the G-Wizard. I've been in the business for 43 years and sure wish something like this was around back in the day." Michael
See Our Customer List
Our frustration free CNC Calculator is guaranteed to make your Speeds and Feeds easier
