Get Better Feeds and Speeds
Instantly
We spent years analyzing data from over 250 tooling catalogs and developed a powerful cutting physics engine incorporating advanced algorithms that consider nearly 60 variables.
By integrating AI and machine learning, and collaborating with over 100,000 CNC users, we ensured G-Wizard delivers superior tool life, surface finish, and material removal rates (MRR).
Master your speeds and feeds effortlessly with G-Wizard.
Very helpful: worth the money.
The most useful speeds and feeds tool I have used.
Excellent. I use this almost every day in coming up with feeds and speeds.
Here's How:
Spindle Speed and Feed Rate.
Adjusts to Your Needs
Turning and Lathe Tools
G-Wizard is truly a full-featured Machining Feeds And Speeds Calculator!
Feeds and Speeds for HSM are easy. Chip Thinning, Adaptive Clearing, and Trochoidal Milling are covered.
Giant Material Database
Expert Tips
Tame Chatter in Machining
G-Wizard has a giant database of pre-defined CNC Machines, plus it's super easy to do your own machine definitions. We'll even create new machine profiles upon request, completely free of charge.
Powerful for Experts
The CNC Business can be tough. Get every advantage you can. For example, you paid extra for those special machine options. Programmable Coolant Nozzles. Through Spindle Coolant. High Pressure Coolant. And G-Wizard will take advantage of those powerful coolant options. Why use a Calculator that wouldn't?
Take the Tour
"I'm in my 27th year and seen my share of ‘machinist aid' software and this BY FAR packs the most punch for the dollar. Shop owners would be fools not having a copy." Michael
"I'm a total Newbie on hobby mill and had the crazy idea to jump right in on some plasma cut hardened steel. WOW! I did it and could not have done it without G-Wizard. I completed our very first EVER customer part in about 1 hour." Jeffrey
"I am amazed at all the data that is available when using the G-Wizard. I've been in the business for 43 years and sure wish something like this was around back in the day." Michael
See Our Customer List
Our frustration free CNC Calculator is guaranteed to make your Speeds and Feeds easier
More on Feeds and Speeds Calculators
