Iscar Feeds and Speeds Calculator vs G-Wizard
Last modified: July 24, 2024
Here is a feature comparison chart that shows the relative functionality of Iscar vs G-Wizard Feeds and Speeds Calculator:
Feature
G-Wizard
Iscar
Machine Types
Mill
Y
Y
Lathe
Y
Y
CNC Router
Y
Metric and Imperial Units, Selectable by Field
Y
FEEDS & SPEEDS FEATURES
Automatic Tool Selection for CAM op
Y
Automatic Tool Selection for CAM op using Tool Tables
Y
Optimized Cut Depth for MRR
Y
Y
Optimized Cut Width for MRR
Y
Y
Optimal Combination of Cut Width and Cut Depth
Y
Tool Rubbing Warning
Y
Compute Slowest Feeds and Speeds without Rubbing
Y
Chip Thinning Compensation
Y
Y
Calculates both Roughing and Finishing Passes
Y
Slider Adjustment from Roughing to Finishing
Y
Recommends Entry Method for CAM Toolpath (Plunge, Ramp, Helix)
Y
Computes Entry Method Feeds & Speeds (Plunge Ramp Helix)
Y
Recommends Coolant or Mist by Material
Y
Y
Automatically Scales Back if you exceed machine HP limits
Y
Y
Can adjust to a spindle power curve
Y
Can optimize to a spindle power curve
Y
Can automatically scale back if you exceed machine's rigidity limits
Y
Can automatically scale back if you exceed machine's max feedrate
Y
Y
Adjusts for Material Alloy and Condition
Y
Y
Material DB Entries
1232
13
Can Calculate a Chamfer Pass
Y
Can Optimize to Control Tool Deflection
Y
Cut Width
Y
Cut Depth
Y
Stickout
Y
Tortoise Hare Slider
Y
Will recommend stickout and warn of excessive stickout
Y
Cut Depth warning when too deep for slitting saws
Y
Can adjust Feeds and Speeds for Helical and Circular holes and bosses
Y
Can adjust Feeds and Speeds for Ramping
Y
Can adjust feedrate to minimize vacuum pop-off
Y
Can compensate for HSM and Trochoidal tool paths
Y
Can adjust for Through Spindle, High Pressure, and Programmable Coolant Nozzles
Y
Cheat Sheet will recommend which parameters to change to achive desired outcome
Y
Will tell you whether to use Climb Milling or Conventional Milling
Y
Will warn if your spindle's minimum rpm is too high for the cut and will suggest work arounds to the problem.
Y
Wiill tell you when you need a peck cycle or parabolic drill based on hole depth.
Y
Will tell you the best twist drill point angle for your material
Y
Will tell you if the material is not compatible with PCD tooling
Y
Will tell you when you should drill a pilot hole
Y
Will tell you when material is too hard to form tap
Y
Will recommend a peck depth
Y
Will tell the best drill size for a reamer
Y
Will warn when you should’nt use the centerline of your cutter
Y
Will warn to use less than 4 flutes in non-ferrous metals
Y
Will compensate for effective diameter on ball noses and such.
Y
Will compute Feeds & Speeds for Plunge Roughing
Y
TOOL TYPES
Carbide Tools
Y
Y
HSS Tools
Y
Y
Cobalt Tools
Y
PCD Tools
Y
Tool Coatings Handled
9
End Mill Tip Types
Normal
Y
Y
Serrated (Corncob) Rougher
Y
Y
Ballnose End Mills
Y
Y
Lolipop End Mills
Y
Chamfers and Countersinks
Y
Corner Rounders
Y
V-Bits
Y
Dovetails
Y
Router Downcut End mIlls
Y
Router Compression End mIlls
Y
Router Straight Flute  End mIlls
Y
Indexable Mill Tip Types
Normal
Y
Y
Y
Y
Ballnose End Mills
Y
Y
Lolipop End Mills
Y
Y
Corner Rounders
Y
V-Bits
Y
Dovetails
Y
Y
Y
Y
Twist Drills
Y
Y
Parabolic Drills
Y
Y
Indexable Drills
Y
Y
Spot Drills
Y
Center Drills
Y
Spade Drills
Y
Gun Drills
Y
Reamers
Y
Form Taps
Y
Cutting Taps
Y
Thread Mills
Y
Y
Boring Bars
Y
Saws & Woodruff Cutters
Y
Annular Cutters (Rotabroach)
Y
Turning Tools
OD Turning
Y
Y
Boring Bar for ID Turning
Y
Y
Parting Off
Y
Y
Single-Point Threading
Y
Y
Grooving Tools
Y
Y
THREAD CALCULATOR
Includes Full Featured Thread Calculations and Data for UN and ISO Threads
Y
Optional Full-Featured Thread Calculator that adds many more thread families
Y
Tap Drill Sizes by Thread %
Y
OTHER FEATURES
Includes Tool Inventory management features
Y
Will manage your ToDo list for you using Pomodoro time management
Y
Includes a full range of Geometry Calculators
Right Triangle
Y
Oblique Triangle
Y
Bolt Circles
Y
Dovetails:  Measurement with pins
Y
Tapers:  Includes a list of standard tapers you can plug in
Y
Chamfer/Drill:  With special calculators for center drill, spot drill, twist drill, and countersink
Y
Circle Chords
Y
GD&T True Position
Y
Distance Between Points
Y
Polar / Rectangular Coordinate Conversion
Y
Turner’s Cube Dimensions:  Fun one!
Y
Fits and Tolerances:  Sliding Fits, Press Fits, and all the rest.
Y
Gage Block / Sine Bar:  Tells which blocks from the set make up a given size.  And for the sine bar, what is the length and gage bar stack up to make that length.
Y
Ball Gages:  Calculate all sorts of interesting things when you drop a ball bearing into a hole.
Y
Includes Many Quick Reference Resources for Machinist
Drill Chart showing all the standard sizes of Twist Drills and End Mills.
Y
Fasteners Chart with data on Socket Head Cap Screws, 82 Degree Flat Head Cap Screws, 100 Degree Flat Head Cap Screws, and Metric Flat Head Cap Screws.
Y
Weights and Volumes for all standard sizes of structural steel.  You can choose the material as well as add cost information to calculate price quotes.
Y
Thermal Expansion Calculator
Y
Electrical Page with Ohms Law Calculator and Resistor Color Codes chart.
Y
Servo and Stepper Motor Sizing Calculations for DIY CNC’ers.
Y
G and M-Codes
Y
Hardness Calculator with conversions between all standard hardness measures.
Y
Tool Rigidity Calculator
Y
Chatter Calculator:  Can you tell you what spindle rpms will minimize the chatter.
Y
GD&T symbol reference
Y
Notebook so you can add web pages to your reference materials
Y
Full-Featured Scientific Calculator with Fractions and Unit Conversion
Y
