16 hours by cncdivi
Little Machine Shop Feeds and Speeds Calculator vs G-Wizard
Here is a feature comparison chart that shows the relative functionality of Little Machine Shop vs G-Wizard Feeds and Speeds Calculator:
Feature | G-Wizard | Little Machine Shop |
Machine Types | ||
Mill | Y | Y |
Lathe | Y | Y |
CNC Router | Y | |
Metric and Imperial Units, Selectable by Field | Y | |
FEEDS & SPEEDS FEATURES | ||
Automatic Tool Selection for CAM op | Y | |
Automatic Tool Selection for CAM op using Tool Tables | Y | |
Optimized Cut Depth for MRR | Y | |
Optimized Cut Width for MRR | Y | |
Optimal Combination of Cut Width and Cut Depth | Y | |
Tool Rubbing Warning | Y | |
Compute Slowest Feeds and Speeds without Rubbing | Y | |
Chip Thinning Compensation | Y | |
Calculates both Roughing and Finishing Passes | Y | |
Slider Adjustment from Roughing to Finishing | Y | |
Recommends Entry Method for CAM Toolpath (Plunge, Ramp, Helix) | Y | |
Computes Entry Method Feeds & Speeds (Plunge Ramp Helix) | Y | |
Recommends Coolant or Mist by Material | Y | |
Automatically Scales Back if you exceed machine HP limits | Y | |
Can adjust to a spindle power curve | Y | |
Can optimize to a spindle power curve | Y | |
Can automatically scale back if you exceed machine’s rigidity limits | Y | |
Can automatically scale back if you exceed machine’s max feedrate | Y | |
Adjusts for Material Alloy and Condition | Y | |
Material DB Entries | 1232 | |
Can Calculate a Chamfer Pass | Y | |
Can Optimize to Control Tool Deflection | Y | |
Cut Width | Y | |
Cut Depth | Y | |
Stickout | Y | |
Tortoise Hare Slider | Y | |
Will recommend stickout and warn of excessive stickout | Y | |
Cut Depth warning when too deep for slitting saws | Y | |
Can adjust Feeds and Speeds for Helical and Circular holes and bosses | Y | |
Can adjust Feeds and Speeds for Ramping | Y | |
Can adjust feedrate to minimize vacuum pop-off | Y | |
Can compensate for HSM and Trochoidal tool paths | Y | |
Can adjust for Through Spindle, High Pressure, and Programmable Coolant Nozzles | Y | |
Cheat Sheet will recommend which parameters to change to achive desired outcome | Y | |
Will tell you whether to use Climb Milling or Conventional Milling | Y | |
Will warn if your spindle’s minimum rpm is too high for the cut and will suggest work arounds to the problem. | Y | |
Wiill tell you when you need a peck cycle or parabolic drill based on hole depth. | Y | |
Will tell you the best twist drill point angle for your material | Y | |
Will tell you if the material is not compatible with PCD tooling | Y | |
Will tell you when you should drill a pilot hole | Y | |
Will tell you when material is too hard to form tap | Y | |
Will recommend a peck depth | Y | |
Will tell the best drill size for a reamer | Y | |
Will warn when you should’nt use the centerline of your cutter | Y | |
Will warn to use less than 4 flutes in non-ferrous metals | Y | |
Will compensate for effective diameter on ball noses and such. | Y | |
Will compute Feeds & Speeds for Plunge Roughing | Y | |
TOOL TYPES | ||
Carbide Tools | Y | Y |
HSS Tools | Y | Y |
Cobalt Tools | Y | |
PCD Tools | Y | |
Tool Coatings Handled | 9 | |
End Mill Tip Types | ||
Normal | Y | Y |
Serrated (Corncob) Rougher | Y | |
Ballnose End Mills | Y | |
Lolipop End Mills | Y | |
Chamfers and Countersinks | Y | |
Corner Rounders | Y | |
V-Bits | Y | |
Dovetails | Y | |
Router Downcut End mIlls | Y | |
Router Compression End mIlls | Y | |
Router Straight Flute End mIlls | Y | |
Indexable Mill Tip Types | ||
Normal | Y | |
V-Bits | Y | |
Dovetails | Y | |
Twist Drills | Y | Y |
Parabolic Drills | Y | |
Indexable Drills | Y | |
Spot Drills | Y | |
Center Drills | Y | |
Spade Drills | Y | |
Gun Drills | Y | |
Reamers | Y | |
Form Taps | Y | |
Cutting Taps | Y | |
Thread Mills | Y | |
Boring Bars | Y | |
Saws & Woodruff Cutters | Y | |
Annular Cutters (Rotabroach) | Y | |
Turning Tools | ||
OD Turning | Y | |
Boring Bar for ID Turning | Y | |
Parting Off | Y | |
Single-Point Threading | Y | |
Grooving Tools | Y | |
THREAD CALCULATOR | ||
Includes Full Featured Thread Calculations and Data for UN and ISO Threads | Y | |
Optional Full-Featured Thread Calculator that adds many more thread families | Y | |
Tap Drill Sizes by Thread % | Y | |
OTHER FEATURES | ||
Includes Tool Inventory management features | Y | |
Will manage your ToDo list for you using Pomodoro time management | Y | |
Includes a full range of Geometry Calculators | ||
Right Triangle | Y | |
Oblique Triangle | Y | |
Bolt Circles | Y | |
Dovetails: Measurement with pins | Y | |
Tapers: Includes a list of standard tapers you can plug in | Y | |
Chamfer/Drill: With special calculators for center drill, spot drill, twist drill, and countersink | Y | |
Circle Chords | Y | |
GD&T True Position | Y | |
Distance Between Points | Y | |
Polar / Rectangular Coordinate Conversion | Y | |
Turner’s Cube Dimensions: Fun one! | Y | |
Fits and Tolerances: Sliding Fits, Press Fits, and all the rest. | Y | |
Gage Block / Sine Bar: Tells which blocks from the set make up a given size. And for the sine bar, what is the length and gage bar stack up to make that length. | Y | |
Ball Gages: Calculate all sorts of interesting things when you drop a ball bearing into a hole. | Y | |
Includes Many Quick Reference Resources for Machinist | ||
Drill Chart showing all the standard sizes of Twist Drills and End Mills. | Y | |
Fasteners Chart with data on Socket Head Cap Screws, 82 Degree Flat Head Cap Screws, 100 Degree Flat Head Cap Screws, and Metric Flat Head Cap Screws. | Y | |
Weights and Volumes for all standard sizes of structural steel. You can choose the material as well as add cost information to calculate price quotes. | Y | |
Thermal Expansion Calculator | Y | |
Electrical Page with Ohms Law Calculator and Resistor Color Codes chart. | Y | |
Servo and Stepper Motor Sizing Calculations for DIY CNC’ers. | Y | |
G and M-Codes | Y | |
Hardness Calculator with conversions between all standard hardness measures. | Y | |
Tool Rigidity Calculator | Y | |
Chatter Calculator: Can you tell you what spindle rpms will minimize the chatter. | Y | |
GD&T symbol reference | Y | |
Notebook so you can add web pages to your reference materials | Y | |
Full-Featured Scientific Calculator with Fractions and Unit Conversion | Y |
Recently updated on April 26th, 2024 at 05:35 am
