G-Wizard CNC Speeds and Feeds Calculator for Milling Machines
Last modified: July 24, 2024
CNCCookbook.com logo with green and orange "CNC" text and tagline "Be a Better CNC'er" on light gray.
Back to Home
CNCCookbook.com website logo with "CNC Cookbook" in green and orange letters and a registered trademark symbol.
PRICING
Get Better Feeds and Speeds
Instantly
Man sitting at desk in front of computer monitors, focused on graphic with text, wearing casual clothing.
and we worked with over 100,000 CNC'ers
like yourself to make sure you'd have
Here's How:
Spindle Speed and Feed Rate.
G-Wizard Feeds and Speeds Calculator software screenshot in web browser window.
Computer screen displaying "Cut Optimizer" tool interface with black background and white text.
Adjusts to Your Needs
White tortoise with ball on stick, chased by white hare.
Computer-aided design CAD program for machining and metal fabrication.
Turning and Lathe Tools
G-Wizard is truly a full-featured Machining Feeds And Speeds Calculator!
Screenshot of CNCCookbook.com's Tool Crib calculator interface with fields and dropdown menus for creating custom tools.
HSM Advisor software settings in machining context.
Feeds and Speeds for HSM are easy. Chip Thinning, Adaptive Clearing, and Trochoidal Milling are covered.
Flute plastic cutting end mill machining chart with material speeds and feeds.
Material database search results on CNCCookbook.com.
Giant Material Database
Expert Tips
Machining expert tips cheat sheet with climb milling highlighted.
Cutting tool input form with fields for rating, material and machining settings.
Tame Chatter in Machining
CNC machine gauge with JOG FEED RATE indicator set to approximately 100%.
High-pressure through spindle coolant system with cylindrical nozzle.
Powerful for Experts
The CNC Business can be tough. Get every advantage you can. For example, you paid extra for those special machine options. Programmable Coolant Nozzles. Through Spindle Coolant. High Pressure Coolant.  And G-Wizard will take advantage of those powerful coolant options.  Why use a Calculator that wouldn't?
Geometric threads with 3D models, CAD screenshots, and technical drawings.
Take the Tour White arrow on green background.
"I'm in my 27th year and seen my share of ‘machinist aid' software and this BY FAR packs the most punch for the dollar. Shop owners would be fools not having a copy." Michael
"I'm a total Newbie on hobby mill and had the crazy idea to jump right in on some plasma cut hardened steel. WOW! I did it and could not have done it without G-Wizard. I completed our very first EVER customer part in about 1 hour." Jeffrey
"I am amazed at all the data that is available when using the G-Wizard. I've been in the business for 43 years and sure wish something like this was around back in the day." Michael
Customer review summary graph showing 5-star ratings and percentages based on 55 CNCCookbook.com user reviews.
have used our software.  We hope you will too.
See Our Customer List
Our frustration free CNC Calculator is guaranteed to make your Speeds and Feeds easier
