Awesome! You've found not one but two Free Online Speeds and Feeds Calculators on this page.
We offer both a free online feeds and speeds calculator using simple shop formulas, and also a free (for a limited time) full-featured calculator that is the industry leading speeds and feeds calculator. It’s used daily by thousands of the world’s best manufacturers.
They know what they’re doing and wouldn’t waste time or money if the software didn’t work.
The thing is, why use the simple free calculator when you could grab our full-featured G-Wizard Feeds and Speeds Calculator completely free for 30-days?
It takes just 37 seconds to download and start using G-Wizard. It costs you nothing and you can get great feeds and speeds from it for the next 30 days. If you want to go back to our free online calculator after that, no worries.
You may as well drive the high-performance model as long as it’s free, right?
Get the High-Performance Model: G-Wizard, Free for 30 Days
Or, just use our simple online cutting feeds and speeds calculator below:
Milling Speed and Feeds Calculator
Spindle Speed Calculator
Tool Diameter
inches
Spindle Speed:
RPM
Feed/Tooth (Chipload):
IPT (inches / tooth)
Number of Flutes (Teeth):
Feed Rate:
IPM (inches / minute)
Material
Surface Speed (SFM)
Aluminum - Wrought (6061)
250
Brass
200
Cast Iron - Ductile
90
Cast Iron - Gray
100
Copper Alloy - Wrought
120
Magnesium Alloy
250
Stainless Steel
30
Steel - Mild
110
Steel - Hard Alloy
60
Steel - Tool
60
500
Material
Surface Speed (SFM)
250
Brass
200
Cast Iron - Ductile
80
Cast Iron - Gray
120
70
Magnesium Alloy
250
Stainless Steel
30
Steel - Mild
110
Steel - Hard Alloy
60
Steel - Tool
60
Material
Chipload (IPT)
0.005 - 0.010
Brass
0.005 - 0.010
Cast Iron - Ductile
0.004 - 0.008
Cast Iron - Gray
0.002 - 0.006
0.004 - 0.008
Magnesium Alloy
0.005 - 0.010
Stainless Steel
0.002 - 0.006
Steel - Mild
0.002 - 0.010
Steel - Hard Alloy
0.002 - 0.006
Steel - Tool
0.002 - 0.006
CNC Feeds and SPeeds Chart Wood
Hang on: You Deserve Better!
Software that makes anyone a better CNC'er... Even beginners:
we built a powerful cutting physics engine with advanced algorithms
that considers almost 60 different variables,
and we worked with over 50,000 CNC'ers
like yourself to make sure you'd have
How to Calculate Material Remove Rate for Milling?
Generally, you want to find the highest Material Removal Rate that will keep reasonable tool life. Our G-Wizard Calculator automates much of that process. But, if you are using the free calculator above, you may want to click through this article to find the Material Removal Rate Formula.
How to Calculate Feed Rate for Milling?
Wondering how to calculate feed rate for milling? Perhaps so you can create your own spreadsheet?
The basic feed rate formulas for milling are simple, but getting real-world feeds and speeds are quite a bit harder. We give you all the basic formulas in our free online Feeds and Speeds Course.
Milling Speeds and Feeds Calculator
CNC Feed Rate Calculator
Chip Load Calculator
Simple Feeds and Speeds Calculator
Tapping Feeds and Speeds Calculator
Master Feeds and Speeds Calculator List
