CNC Dictionary: G12/G13 to Knee Mill
G12/G13 Circular Pocket Milling
G12 and G13 are G-Codes (see also G-Codes) in the part program that specify a circular pocket be milled. G12 causes the pocket to be milled in a clockwise direction while G13 mills counterclockwise. The radius of the circle is typically specified with an “I” command. For example “G12I5” specifies a pocket with a radius of 5 be cut in the clockwise direction. The cutter should be positioned to the center of the circular pocket using a move in a prior block or an X and Y command in the same block. The tool will return to center when the pocket is finished.
Clockwise and counterclockwise variants are provided so that the user may select climb versus conventional milling. For example, with clockwise spindle rotation, G12 (clockwise) results in conventional milling.
Note that with a suitable cutter, such as a woodruff key cutter (see also Woodruff Cutter), it is possible to use G12/G13 to cut grooves or slots in the pocket wall.
Circular pocket milling is how CNC’ers cut holes larger than their cutter. It is sometimes called spiral interpolation and sometimes helical interpolation. True helical interpolation involves a helix, while spiral interpolation keeps the entire cut in the same plane.
Gang Tooling
A type of tooling arrangement on lathes where multiple cutters are mounted on the cross slide which is repositioned to allow each tool to access the part. For example, it is common to mount the cutoff tool behind the part (and usually upside down unless the spindle is reversed when the rear tool is in use).
Gang tooling provides a simple way to employ multiple tools when a turret is not available.
Accuslide (now defunct) was a gang tooling option to retrofit a Hardinge manual lathe to CNC…
Gantry Mill
A gantry mill uses a bridge-like arrangement to support the Z-Axis, which travels across the bridge for Y-Axis motion. They are very common for router and plasma applications, and somewhat less so except for large configurations when milling steel.
Gas Spring
Similar to a gas strut, a gas spring may be used as a counterweight (See Also Counterweight) on a Z-Axis to improve performance.
G-Code
The generic slang term for the program that controls a CNC machine. The more proper term would be “Part Program” (see also).
Literally, a G-Code is the type of word in those programs that determines the type of operation the machine will do next. They were named “G” Codes for “Geometric” Code.
Try the CNCCookbook G-Code Reference for a sampling of g-codes. We also offer an Online G-Code Tutorial.
Here are some online references describing g-code:
There is a useful G-Code dictionary provided by CNC EZ Pro here.
The NIST G-Code definition, RS274/NGC, may be found here.
The Light Machines Manual has some excellent g-code documentation.
Mitsubishi Controls G-Code Documentation.
The Europeans go by DIN 66025 as a G-Code standard. See also RS274 for a discussion of G-Code standards.
Peter Schmid’s excellent, “CNC programming handbook” is the reference many classrooms use.
Then there are some unique sources, such as this PowerPoint slide show describing some of the G-codes that are special to Haas mills.
Gear Drive
Gear drives may be used to drive spindles or drive motors. They’re less common for drive motors because they typically involve backlash (See Also Backlash) unless very carefully designed. They’re convenient for spindles because a transmission can usually be incorporated that allows several speed ranges.
Gecko
A manufacturer of drive motor controllers or drivers or drivers for stepper motors and servos. Gecko also makes the G-Rex.
Geometric Dimensioning & Tolerancing (Abbreviated GD&T)
GD&T is a comprehensive set of conventions for efficiently and accurately communicating geometry requirements for features on components and assemblies. The appropriate standard defining GD&T is ASME Y14.5M – 1994. Some of the advantages of using GD&T include:
– It provides a clear and concise technique for defining a reference coordinate system and datums on a component or assembly that can be used throughout the manufacturing and inpsection processes.
– The practice closely parallels accepted practices used in the mechanical and manufacturing design disciplines.
– It reduces the need for drawing notes when describing complex geometries and does so in a standard way.
– GD&T can facilitate the design of check gages, fixtures, and jigs.
Gibs
Gibs, usually pronounced with a hard “G” sound, are pieces that fit in ways (See Also Dovetail Ways). They are used to provide adjustment for wear, tightness, and also as a means to lock an axis for greater rigidity while machining. There are two types of gib, straight gibs and tapered gibs:
Tapered and Straight Gibs
See also Tapered Gibs.
Gib Adjustment
This is a collection of notes on how to adjust your machine’s gibs that I’ve found all over the web. I’ve tried some, other’s have tried them, and people tell me they work. Before talking about their adjustment, and assuming we’re not talking about gibs meant to be locked and unlocked all the time, be sure you have some sort of locking mechanism so that you can maintain that adjustment despite machine vibration. My lathe has a jam nut that holds the gib adjustment, for example. Products like Loctite should also be considered.
The first question is, “How would I know whether I need to adjust my gibs?” Unfortunately, the best answer I have here is you won’t know if you don’t try. Be careful not to tighten them too much or you’ll really lock down the axis and generally make things worse. For some kinds of cutting you may find it advantageous to lock an axis in this way. I have seen the practice recommended, but the one time I tried it on my lathe the result was no improvement and a badly adjusted gib so I steer clear unless the machine comes with tapered gibs (See Also Tapered Gibs) and locking handles.
Some folks limit gib adjustment entirely to a degree of tightness for the slide. They back off all screws and start on the centers, tightening just enough to create a slight drag on the slide when there are no leadscrews attached. A similar approach involves tightening that center screw until it is “just snug” and then following up with the ends. The latter is an approach I used with some success on my Lathemaster lathe.
I have seen one source that recommends lapping the gibs, as they are often of somewhat poor or rough finish. CNC machines make gib adjustment a little more difficult.
Without handwheels, you can’t really feel how tight they are. Commercial CNC machines make the adjustment by measurement how much amperage is drawn by the motor during traversal. One account I read indicated the gibs should be adjusted until they are about 30% to 50% of the maximum rated amperage for the motor on the same axis as the gib.
An approach that is more analytical can be used for both manual and CNC machines. This is supposedly the factory procedure used by Bridgeport to set them. Use a 0.0001 reading indicator and measure the slop in the slide. Example: For the X axis, place the mag base on the end of the saddle and put the stylus on the table. At that end of the table push and release. Then pull and release. The differance is the amount of clearance in the slide. Repeat at the other end of the saddle. Adjust gib in a like new machine with little wear to give a reading of 0.0005. A machine with more wear will have to be checked with the table closer to the end of travel. The same procedure is used to set the saddle to knee gib. There must be some clearance for the oil film and that film also helps dampen vibration. On a machine with hardened and ground box ways and turcite on the moving member the procedure is to set the clearance to almost nil. 0.0001 is a good number.
Another approach was based on trying to minimize backlash by making the gibs as tight as possible. In this case, it was advocated to overtighten the gibs until backlash due to flexure against a locked table was measurable, and then gradually back off in ¼ turn increments until that backlash was minimized.
G-Rex or GRex or G101
The G-Rex is sort of a super breakout board (See Also Breakout Board) that uses a LAN or USB connection back to the computer. It provides a large number of inputs and outputs as well as control of up to 6 axes. The G-Rex incorporates a dedicated microprocessor to run the innermost motion control loops. This tremendously lightens the load on the PC running the CNC control software and allows for much higher performance.
Hall Effect Sensor or Switch
Hall Effect sensor works by detecting the presence of a small magnet or moving ferrous metal nearby. They’re often used as home or limit switches and as spindle index sensors. See Also “Home Switch”, “Limit Switch”, and “Spindle Index Sensor”.
Handwheels
Handwheels are used to manually operate the axis of a CNC machine. They are generally connected to an electronic device called an MPG (See Also MPG) that sends signals through the CNC controller to the drive motors rather than directly moving the machinery via a leadscrew.
Hardness
Hardness is a material’s resistance to plastic deformation and scratching. It is a measure of how difficult it is for the cutting tool to cut the material. Knowing the hardness of a material is helpful in deciding how to go about machining it, particularly for materials like steel where there are many different alloys and heat treatments (See Also Heat Treatment) that lead to a wide range of hardnesses.
There are a variety of scales used to measure hardness, including Rockwell, Brinell, Vickers, and Knoop. Testers are also available that can determine the hardness of a material in various ways. If you know what allow you are using, Machinery’s Handbook and other reference sources will have hardness information.
Harmonic Drive
A harmonic drive is a gear drive of novel design that offers minimal backlash. As such they are ideal reduction drives to go between stepper or servo motors and the machine axis.
Heat Treatment
Heat Treatment is the process of using heat in very controlled ways to change the properties of a material. For example, heat treatment may be used to harden certain alloys of steel.
Helical Beam Coupler
A type of shaft coupler that has a helical slot cut through the middle. This allows the coupler to flex which enables coupling of shafts that are not quite true to one another. Helical Beam Couplers are a popular way to couple stepper and servo shafts to the reduction drive.
A Helical Beam Coupler…
Helical Interpolation
A coordinated motion in x, y, and z axes that causes the tool to follow a helix. Helical interpolation is useful for a variety of operations, including ramping and thread milling. See also “Ramping” and “Thread Milling”.
Helix Angle
The helix angle is a characteristic of an endmill that is the angle from the vertical of the helical flutes. The most common helix angle is 30 degrees because it offers the broadest range of usability. Increased machine rigidity and solid carbide endmills argue that a 45 degree helix angle may be a better choice. The greater the angle, the faster the helix.
High Speed Machining or HSM
Using smaller cutters at much faster spindle speeds and feed rates to make many lighter cuts that take the place of deeper slower cuts with larger cutters in conventional machining.
If the speed is high enough, and the chips are evacuated well enough due to the high speeds and perhaps an air jet, coolant may not be necessary or may even be detrimental as the chips carry away most of the heat. Higher feed rates really facilitate this.
The advantages of HSM include higher accuracy, faster cycle times, and more accurate parts. Cutting forces are diminished in HSM, which can even result in greater tool life. Positive rake tooling also reduces cutting forces, and is desirable for HSM.
HSM requires the ability for the CNC machine axes to accelerate, decelerate, and move very quickly in order to make up for the time lost in making much lighter cuts.
The easiest way for the Home Shop Machinist to embrace high speed machining is often to attach a small high speed spindle such as a die grinder or laminate router to their existing mill head. Such spindles are self-contained with motor and run at speeds of 20,000 rpm and up. With a 1/8″ or smaller endmill, they are well into the realm of HSM, especially for aluminum.
High Speed Steel or HSS
High Speed Steel, abbreviated HSS, refers to steel used to make cutters. It is called “high speed” because it is an alloy designed to withstand the heat of cutting better than milder steels. In the pantheon of cutter materials, HSS is one of the more common and plebian varieties. Carbide (See Also Carbide) is harder, more rigid, and withstands higher temperatures, although it is also more costly and more brittle on the downside.
HMC: See “Horizontal Machining Center”
Holding Torque (see also “Torque”)
The maximum torque that can be applied to an energized but stopped motor (especially a stepper motor) without moving it.
Home Position: See Machine Zero
Home Switch
A position sensor that is used to establish a reference position for an axis. There is typically one per axis. On many CNC machines, one of the two limit switches serves double duty as a home switch. When the machine is commanded to home, it simply moves in the defined direction until the limit switch is triggered.
See also “Limit Switch”
A machining center (See Also Machining Center) whose spindle is horizontal. Roughly analogous to a very sophisticated horizontal mill.
HSM: See High Speed Machining, also, an abbreviation for “Home Shop Machinist”
HSS: See High Speed Steel
Hybrid Stepper Motor
A hybrid stepper motor is a DC brushless permanent magnet motor with a wound stator. It is designed to move discrete increments or steps by sequencing the current to the windings.
I-Beam
A type of structural steel whose cross-section looks like the letter “I”. I-Beams are available in standard sizes.
Idle Current Reduction
A driver feature that reduces current to the motor when it is not turning in order to reduce heating and conserve power.
IGES or Initial Graphic Exchange Specification
A vendor independent standard for exchanging CAD information or files. A CAD program file format.
IGS (see also “IGES”): The file extension for IGES files.
Inches Per Minute
A measure of feedrate. See Also Feedrate.
Inches Per Tooth (see also Chip Load)
The distance covered (feed rate) as each tooth engages the workpiece. A measurement of Chip Load.
Incremental Coordinates & Positioning: See Relative Coordinates
Index Pulse
A pulse usually associated with spindle indexing that determines when a point on a rotating shaft has been passed. See also Spindle Indexing.
Indexable Tooling
Indexable tooling uses carbide inserts (See Also Carbide Insert) as the cutting edges. When the insert dulls or chips, it can easily be replaced with a new one for a fraction of the cost of replacing the whole tool.
Insert
An easily changeable cutting surface that may be used with indexable tooling (See Also Indexable Tooling). Inserts are generally very cheap compared to the cost of replacing the entire cutting tool, and so provide an economical way to use carbide (See Also Carbide or Carbide Insert) for high performance cutting in machine tools.
Inserts can be carbide, diamond, ceramic, or various other materials.
A typical insert…
Indexable Tooling for a Lathe Uses Carbide Inserts…
Shop Made Indexable Dovetail Cutter for Milling Dovetail Slots…
Insert Drill
A type of indexable tooling that uses a carbide insert to bore a hole. Each drill is designed for a specific size hole. Often, insert drills will have coolant passages to allow coolant to be pumped through the drill and down to the very bottom of the hole.
Interpolation: See Linear Interpolation or Circular Interpolation
Inverter: See VFD
IPAC (see “Keyboard Emulator”)
IPM: See Inches Per Minute
Jig
Generically jigs and fixtures are used to guide and hold the workpiece. A jig may also guide the tool, while a fixture does not.
Jog, Jogging, and Jog Mode
Jogging is the operation of manually causing an axis to move under power. It is often convenient to jog using a handheld pendant control (See Also Pendant). A mechanism is usually provided to control the speed of jogging.
Keyboard Emulator
A keyboard emulator is an electronic circuit that accepts a number of inputs and converts them to keystrokes which are fed into the PC’s keyboard input. This is a convenient way to add additional control panel inputs on systems that use a parallel breakout board (See Also Breakout Board) because it conserves scarce input lines on the parallel port. IPAC is one example of a keyboard emulator board.
Knee Mill
Knee mills support the table, X, and Y axes on a knee and raise the table up and down whereas a bed mill (See Also Bed Mill) moves the spindle up and down. The Bridgeport manual mills were classic knee mills, but most modern CNC vertical machining centers are bed mills.
Gang Tooling to Knee Mill | Prev | Next |
Back to CNC Dictionary Home…
Recently updated on February 20th, 2024 at 10:41 am
