I-Beam and Steel Sizes Chart with Free Calculator
Last modified: June 20, 2026
Introduction
Structural Steel is available in a variety of standard sizes. You'll find the dimensions for those sizes in our handy tables below, grouped by structural shape. In addition, there is helpful information on the applicable standards and other basics.
Structural Steel is generally referred to by its profile (for example "I-Beams") and its size. Sizes are determined by standards which are described in the sections for each shape below.
One goal of Structural Steel that goes to determining the shape is that it have high second moments of area, which make them very stiff in respect to their cross-sectional area. This makes them strong relative to the amount of material and weight that must be used in their construction.
Structural steel components: beams, channels, angles, and plates depicted in simple, detailed icons on a white background.
Common Structural Steel Shapes By William Perry of Mercury Business Development - https://commons.wikimedia.org/w/index.php?curid=5326461...
If you want to learn more about the properties of the different types of steel used in Structural Steel, check out our handy article on types of metals.
Free Steel Size and Weight Calculator
All the data you're seeking on Standard Steel Sizes is available below in tabular form, but why use tables when our free calculator has all the same information and will also help you calculate weight, volume, and costs for job quoting?
Our Steel Beam & Structural Shape Calculator does it all right in your browser—no signup and nothing to download. Pick a shape (Wide-Flange or American-Standard I-beams, channel, angle, or HSS tubing), choose a standard size, and enter a length to get the weight, volume, and material cost instantly. You can toggle between imperial and metric units and change the material to estimate weights for aluminum, stainless, and more.
Ready to crunch the numbers? Open the free calculator—weight, volume & cost, right in your browser.
Open the Steel Beam Calculator →
Grab a steel beam price list from your favorite supplier and you can figure your raw material costs too!
Steel I-Beam Sizes (Steel Beam Dimensions and Weights)
I-Beams are also known as H-Beams, W-Beams (for "wide flange"), Universal Beams (UB), Rolled Steel Joists (RSJ) or Double-T. I-Beams have an I, or if you rotate it, an H-shaped cross-section. The horizontal elements of the "I" are called "flanges", while the vertical elements are the "web." I-Beams are one of several standard structural shapes for steel, and they are commonly used in construction and civil engineering projects.
The shape of the I-Beam provides versatile strength with a minimum of weight. The web resists shear forces while the flanges resist the bending moment experienced by the beam. Thus I-Beams are very efficient for carrying bending and shear loads in the plane of the web. The weakness of the shape is that it doesn't resist torsional forces nor does it have much capacity in the transverse direction. If strengths in those areas are needed, hollow structural sections (HSS) are preferred.
Steel I-Beams are typically produced by a rolling process that was invented in 1849 by Alphonse Halbou in France. The use of rolled I-Beams was common into the mid-20th century. Today, fabricated I-Beams, which are produced by welding together the flanges and web are also common.
US Standards
In the US, the Wide Flange (W-Beams) are the most common. These beams have flanges which are almost parallel. Relevant standards with yield strengths are:
A992 has generally replaced the older A572 and A36 standards.
The American Institute of Steel Construction (AISC) publishes the Steel Construction Manual for designing structures of various shapes. It documents the common approaches, Allowable Stress Design (ASD) and Load and Resistance Factor Design (LRFD), (starting with 13th ed.) to create such designs.
Euronorms
Other Standards
Steel I-Beam Sizes (Wide Flange)
Technical illustration of I-beam dimensions.
Name Depth (in) Width (in) Web Thickness (in) Flange Thickness (in) Sectional Area (in²) Weight (lb/ft)
W 27 x 178 27.8 14.09 0.725 1.19 52.3 178
W 27 x 161 27.6 14.02 0.66 1.08 47.4 161
W 27 x 146 27.4 14 0.605 0.975 42.9 146
W 27 x 114 27.3 10.07 0.57 0.93 33.5 114
W 27 x 102 27.1 10.02 0.515 0.83 30 102
W 27 x 94 26.9 10 0.49 0.745 27.7 94
W 27 x 84 26.7 9.96 0.46 0.64 24.8 84
W 24 x 162 25 13 0.705 1.22 47.7 162
W 24 x 146 24.7 12.9 0.65 1.09 43 146
W 24 x 131 24.5 12.9 0.605 0.96 38.5 131
W 24 x 117 24.3 12.8 0.55 0.85 34.4 117
W 24 x 104 24.1 12.75 0.5 0.75 30.6 104
W 24 x 94 24.1 9.07 0.515 0.875 27.7 94
W 24 x 84 24.1 9.02 0.47 0.77 24.7 84
W 24 x 76 23.9 9 0.44 0.68 22.4 76
W 24 x 68 23.7 8.97 0.415 0.585 20.1 68
W 24 x 62 23.7 7.04 0.43 0.59 18.2 62
W 24 x 55 23.6 7.01 0.395 0.505 16.2 55
W 21 x 147 22.1 12.51 0.72 1.15 43.2 147
W 21 x 132 21.8 12.44 0.65 1.035 38.8 132
W 21 x 122 21.7 12.39 0.6 0.96 35.9 122
W 21 x 111 21.5 12.34 0.55 0.875 32.7 111
W 21 x 101 21.4 12.29 0.5 0.8 29.8 101
W 21 x 93 21.6 8.42 0.58 0.93 27.3 93
W 21 x 83 21.4 8.36 0.515 0.835 24.3 83
W 21 x 73 21.2 8.3 0.455 0.74 21.5 73
W 21 x 68 21.1 8.27 0.43 0.685 20 68
W 21 x 62 21 8.24 0.4 0.615 18.3 62
W 21 x 57 21.1 6.56 0.405 0.65 16.7 57
W 21 x 50 20.8 6.53 0.38 0.535 14.7 50
W 21 x 44 20.7 6.5 0.35 0.45 13 44
W 18 x 119 19 11.27 0.655 1.06 35.1 119
W 18 x 106 18.7 11.2 0.59 0.94 31.1 106
W 18 x 97 18.6 11.15 0.535 0.87 28.5 97
W 18 x 86 18.4 11.09 0.48 0.77 25.3 86
W 18 x 76 18.2 11.04 0.425 0.68 22.3 76
W 18 x 71 18.5 7.64 0.495 0.81 20.8 71
W 18 x 65 18.4 7.59 0.45 0.75 19.1 65
W 18 x 60 18.2 7.56 0.415 0.695 17.6 60
W 18 x 55 18.1 7.53 0.39 0.63 16.2 55
W 18 x 50 18 7.5 0.355 0.57 14.7 50
W 18 x 46 18.1 6.06 0.36 0.605 13.5 46
W 18 x 40 17.9 6.02 0.315 0.525 11.8 40
W 18 x 35 17.7 6 0.3 0.425 10.3 35
W 16 x 100 16.97 10.425 0.585 0.985 29.4 100
W 16 x 89 16.75 10.365 0.525 0.875 26.2 89
W 16 x 77 16.52 10.295 0.455 0.76 22.6 77
W 16 x 67 16.33 10.235 0.395 0.665 19.7 67
W 16 x 57 16.43 7.12 0.43 0.715 16.8 57
W 16 x 50 16.26 7.07 0.38 0.63 14.7 50
W 16 x 45 16.13 7.035 0.345 0.565 13.3 45
W 16 x 40 16.01 6.995 0.305 0.505 11.8 40
W 16 x 36 15.86 6.985 0.295 0.43 10.6 36
W 16 x 31 15.88 5.525 0.275 0.44 9.12 31
W 16 x 26 15.69 5.5 0.25 0.345 7.68 26
W 14 x 132 14.66 14.725 0.645 1.03 38.8 132
W 14 x 120 14.48 14.67 0.59 0.94 35.3 120
W 14 x 109 14.32 14.605 0.525 0.86 32 109
W 14 x 99 14.16 14.565 0.485 0.78 29.1 99
W 14 x 90 14.02 14.52 0.44 0.71 26.5 90
W 14 x 82 14.31 10.13 0.51 0.855 24.1 82
W 14 x 74 14.17 10.07 0.45 0.785 21.8 74
W 14 x 68 14.04 10.035 0.415 0.72 20 68
W 14 x 61 13.89 9.995 0.375 0.645 17.9 61
W 14 x 53 13.92 8.06 0.37 0.66 15.6 53
W 14 x 48 13.79 8.03 0.34 0.595 14.1 48
W 14 x 43 13.66 7.995 0.305 0.53 12.6 43
W 14 x 38 14.1 6.77 0.31 0.515 11.2 38
W 14 x 34 13.98 6.745 0.285 0.455 10 34
W 14 x 30 13.84 6.73 0.27 0.385 8.85 30
W 14 x 26 13.91 5.025 0.255 0.42 7.69 26
W 14 x 22 13.74 5 0.23 0.335 6.49 22
W 12 x 136 13.41 12.4 0.79 1.25 39.9 136
W 12 x 120 13.12 12.32 0.71 1.105 35.3 120
W 12 x 106 12.89 12.22 0.61 0.99 31.2 106
W 12 x 96 12.71 12.16 0.55 0.9 28.2 96
W 12 x 87 12.53 12.125 0.515 0.81 25.6 87
W 12 x 79 12.38 12.08 0.47 0.735 23.2 79
W 12 x 72 12.25 12.04 0.43 0.67 21.1 72
W 12 x 65 12.12 12 0.39 0.605 19.1 65
W 12 x 58 12.19 10.01 0.36 0.64 17 58
W 12 x 53 12.06 9.995 0.345 0.575 15.6 53
W 12 x 50 12.19 8.08 0.37 0.64 14.7 50
W 12 x 45 12.06 8.045 0.335 0.575 13.2 45
W 12 x 40 11.94 8.005 0.295 0.515 11.8 40
W 12 x 35 12.5 6.56 0.3 0.52 10.3 35
W 12 x 30 12.34 6.52 0.26 0.44 8.8 30
W 12 x 26 12.22 6.49 0.23 0.38 7.7 26
W 12 x 22 12.31 4.03 0.26 0.425 6.5 22
W 12 x 19 12.16 4.005 0.235 0.35 5.6 19
W 12 x 16 11.99 3.99 0.22 0.265 4.7 16
W 12 x 14 11.91 3.97 0.2 0.225 4.2 14
W 10 x 112 11.36 10.415 0.755 1.25 32.9 112
W 10 x 100 11.1 10.34 0.68 1.112 29.4 100
W 10 x 88 10.84 10.265 0.605 0.99 25.9 88
W 10 x 77 10.6 10.19 0.53 0.87 22.6 77
W 10 x 68 10.4 10.13 0.47 0.77 20 68
W 10 x 60 10.22 10.08 0.42 0.68 17.6 60
W 10 x 54 10.09 10.03 0.37 0.615 15.8 54
W 10 x 49 9.98 10 0.34 0.56 14.4 49
W 10 x 45 10.1 8.02 0.35 0.62 13.3 45
W 10 x 39 9.92 7.985 0.315 0.53 11.5 39
W 10 x 33 9.73 7.96 0.29 0.435 9.71 33
W 10 x 30 10.47 5.81 0.3 0.51 8.84 30
W 10 x 26 10.33 5.77 0.26 0.44 7.6 26
W 10 x 22 10.17 5.75 0.24 0.36 6.5 22
W 10 x 19 10.24 4.02 0.25 0.395 5.6 19
W 10 x 17 10.11 4.01 0.24 0.33 5 17
W 10 x 15 9.99 4 0.23 0.27 4.4 15
W 10 x 12 9.87 3.96 0.19 0.21 3.5 12
W 8 x 67 9 8.28 0.57 0.935 19.7 67
W 8 x 58 8.75 8.22 0.51 0.81 17.1 58
W 8 x 48 8.5 8.11 0.4 0.685 14.1 48
W 8 x 40 8.25 8.07 0.36 0.56 11.7 40
W 8 x 35 8.12 8.02 0.31 0.495 10.3 35
W 8 x 31 8 7.995 0.285 0.435 9.1 31
W 8 x 28 8.06 6.535 0.285 0.465 8.3 28
W 8 x 24 7.93 6.495 0.245 0.4 7.1 24
W 8 x 21 8.28 5.27 0.25 0.4 6.2 21
W 8 x 18 8.14 5.25 0.23 0.33 5.3 18
W 8 x 15 8.11 4.015 0.245 0.315 4.4 15
W 8 x 13 7.99 4 0.23 0.255 3.8 13
W 8 x 10 7.89 3.94 0.17 0.205 2.9 10
W 6 x 25 6.38 6.08 0.32 0.455 7.3 25
W 6 x 20 6.2 6.02 0.26 0.365 5.9 20
W 6 x 16 6.28 4.03 0.26 0.405 4.7 16
W 6 x 15 5.99 5.99 0.23 0.26 4.4 15
W 6 x 12 6.03 4 0.23 0.28 3.6 12
W 6 x 9 5.9 3.94 0.17 0.215 2.7 9
W 5 x 19 5.15 5.03 0.27 0.43 5.5 19
W 5 x 16 5.01 5 0.24 0.36 4.7 16
W 4 x 13 4.16 4.06 0.28 0.345 3.8 13
Steel I-Beam Sizes (S)
Name Depth (in) Width (in) Web Thickness (in) Sectional Area (in²) Weight (lb/ft)
S 24 x 121 24.5 8.05 0.8 35.6 121
S 24 x 106 24.5 7.78 0.62 31.2 106
S 24 x 100 24 7.425 0.745 29.3 100
S 24 x 90 24 7.125 0.625 26.5 90
S 24 x 80 24 7 0.5 23.5 80
S 20 x 96 20.3 7.2 0.8 28.2 96
S 20 x 86 20.3 7.06 0.66 25.3 86
S 20 x 75 20 6.385 0.635 22 75
S 20 x 66 20 6.255 0.505 19.4 66
S 18 x 70 18 6.251 0.711 20.6 70
S 18 x 54.7 18 6.001 0.461 16.1 54.7
S 15 x 50 15 5.64 0.55 14.7 50
S 15 x 42.9 15 5.501 0.411 12.6 42.9
S 12 x 50 12 5.477 0.687 14.7 50
S 12 x 40.8 12 5.252 0.462 12 40.8
S 12 x 35 12 5.078 0.428 10.3 35
S 12 x 31.8 12 5 0.35 9.35 31.8
S 10 x 35 10 4.944 0.594 10.3 35
S 10 x 25.4 10 4.661 0.311 7.46 25.4
S 8 x 23 8 4.171 0.441 6.77 23
S 8 x 18.4 8 4.001 0.271 5.41 18.4
S 7 x 20 7 3.86 0.45 5.88 20
S 7 x 15.3 7 3.662 0.252 4.5 15.3
S 6 x 17.25 6 3.565 0.465 5.07 17.25
S 6 x 12.5 6 3.332 0.232 3.67 12.5
S 5 x 14.75 5 3.284 0.494 4.34 14.75
S 5 x 10 5 3.004 0.214 2.94 10
S 4 x 9.5 4 2.796 0.326 2.79 9.5
S 4 x 7.7 4 2.663 0.193 2.26 7.7
S 3 x 7.5 3 2.509 0.349 2.21 7.5
S 3 x 5.7 3 2.33 0.17 1.67 5.7
Steel Channel Sizes
Structural Channel is also know as C-beam. It's a type of structural steel beam used primarily in building construction and civil engineering. Channel cross section is "C" shaped and consists of a wide web (usually oriented vertically in use) and two "flanges" at the top and bottom of the web.
C-Beams are not symmetrical (at least when used vertically) like I-Beams, which means the bending axis is not centered on the width of the flanges. If we apply a load to the top of a flange, the beam will try to twist away from the web. This may not be a problem for some designs, but it results in channels being less commonly used than I-Beams for structural purposes.
Instead, they are most often used where the large flat web will either be mounted to another flat surface for maximum contact area, or will face outward to hide the flanges for aesthetic reasons.
The applicable US standard for Steel used in Channel is ASTM A-36, which specifies a yield point of 36,000 psi minimum.
Steel Channel Size Chart
Gray grid with labeled dimensions: Width, Depth, Web Thickness.
Name Depth (in) Width (in) Web Thickness (in) Weight (lb/ft)
C 15 x 50 15 3.716 0.716 50
C 15 x 40 15 3.52 0.52 40
C 15 x 33.9 15 3.4 0.4 33.9
C 12 x 30 12 3.17 0.51 30
C 12 x 25 12 3.047 0.387 25
C 12 x 20.7 12 2.942 0.282 20.7
C 10 x 30 10 3.033 0.673 30
C 10 x 25 10 2.886 0.526 25
C 10 x 20 10 2.739 0.379 20
C 10 x 15.3 10 2.6 0.24 15.3
C 9 x 20 9 2.648 0.448 20
C 9 x 15 9 2.485 0.285 15
C 9 x 13.4 9 2.433 0.233 13.4
C 8 x 18.75 8 2.527 0.487 18.75
C 8 x 13.75 8 2.343 0.303 13.75
C 8 x 11.5 8 2.26 0.22 11.5
C 7 x 14.75 7 2.299 0.419 14.75
C 7 x 12.25 7 2.194 0.314 12.25
C 7 x 9.8 7 2.09 0.21 9.8
C 6 x 13 6 2.157 0.437 13
C 6 x 10.5 6 2.034 0.314 10.5
C 6 x 8.2 6 1.92 0.2 8.2
C 5 x 9 5 1.885 0.325 9
C 5 x 6.7 5 1.75 0.19 6.7
C 4 x 7.25 4 1.721 0.321 7.25
C 4 x 5.4 4 1.584 0.184 5.4
C 3 x 6 3 1.596 0.356 6
C 3 x 5 3 1.498 0.258 5
C 3 x 4.1 3 1.41 0.17 4.1
Steel Angle Sizes
Steel Angle is another Structural Steel shape that's commonly available. Angle typically has an L-shaped cross section.
Size (in) Depth (in) Thickness (in) Weight (lb/ft)
12 x 12 12 1 3/8 105
12 x 12 12 1 1/4 96.4
12 x 12 12 1 1/8 87.2
12 x 12 12 1 77.8
10 x 10 10 1 3/8 87.1
10 x 10 10 1 1/4 79.9
10 x 10 10 1 1/8 72.3
10 x 10 10 1 64.7
10 x 10 10 7/8 56.9
10 x 10 10 3/4 49.1
8 x 8 8 1 1/8 56.9
8 x 8 8 1 51
8 x 8 8 7/8 45
8 x 8 8 3/4 38.9
8 x 8 8 5/8 32.7
8 x 8 8 9/16 29.6
8 x 8 8 1/2 26.4
6 x 6 6 1 37.4
6 x 6 6 7/8 33.1
6 x 6 6 3/4 28.7
6 x 6 6 5/8 24.2
6 x 6 6 9/16 21.9
6 x 6 6 1/2 19.6
6 x 6 6 7/16 17.2
6 x 6 6 3/8 14.9
6 x 6 6 5/16 12.4
5 x 5 5 7/8 27.2
5 x 5 5 3/4 23.6
5 x 5 5 5/8 20
5 x 5 5 1/2 16.2
5 x 5 5 7/16 14.3
5 x 5 5 3/8 12.3
5 x 5 5 5/16 10.3
4 x 4 4 3/4 18.5
4 x 4 4 5/8 15.7
4 x 4 4 1/2 12.8
4 x 4 4 7/16 11.3
4 x 4 4 3/8 9.8
4 x 4 4 5/16 8.2
4 x 4 4 1/4 6.6
3 1/2 x 3 1/2 3 1/2 1/2 11.1
3 1/2 x 3 1/2 3 1/2 7/16 9.8
3 1/2 x 3 1/2 3 1/2 3/8 8.5
3 1/2 x 3 1/2 3 1/2 5/16 7.2
3 1/2 x 3 1/2 3 1/2 1/4 5.8
3 x 3 3 1/2 9.4
3 x 3 3 7/16 8.3
3 x 3 3 3/8 7.2
3 x 3 3 5/16 6.1
3 x 3 3 1/4 4.9
3 x 3 3 3/16 3.7
2 1/2 x 2 1/2 2 1/2 1/2 7.7
2 1/2 x 2 1/2 2 1/2 3/8 5.9
2 1/2 x 2 1/2 2 1/2 5/16 5
2 1/2 x 2 1/2 2 1/2 1/4 4.1
2 1/2 x 2 1/2 2 1/2 3/16 3.1
2 x 2 2 3/8 4.7
2 x 2 2 5/16 3.9
2 x 2 2 1/4 3.2
2 x 2 2 3/16 2.4
2 x 2 2 1/8 1.7
Hollow Structural Section (HSS) Sizes
Hollow Structural Sections (HSS) are one of the standard structural steel shapes. HSS sections are profiles with a hollow tubular cross section that is typically square or rectangular, although circular and elliptical setions are also available. These sections are also commonly called tube steel or structural tubing, and they are sometimes mistakenly called "Hollow Structural Steel." Circular sections are sometimes mistakenly called "Steel Pipe" rather than tubing although true steel pipe is dimensioned and classed differently from HSS.
HSS is a term used in the US and other countries that follow US construction and engineering terminology. In the UK, the term HSS is not used. Rather, the basic shapes are referred to as CHS (Circular Hollow Section), SHS (Square Hollow Section), and RHS (Rectangular Hollow Section).
HSS is commonly used in welded steel frames whose members experience loading in multiple directions. Square and circular HSS are very efficient shapes for multi-axis loading because of their uniform geometry along two or more cross-sectional axes. Typically, HSS is available in mild steel such as A500 grade C or grade B.
Hollow Structural Section (HSS) Size Table
Size (in) Weight (lb/ft) Wall Thickness (in)
32 x 32 x 5/8 259.83 0.625
32 x 32 x 1/2 210.72 0.5
32 x 32 x 3/8 159.37 0.375
30 x 30 x 5/8 242.82 0.625
30 x 30 x 1/2 197.11 0.5
30 x 30 x 3/8 149.16 0.375
28 x 28 x 5/8 225.8 0.625
28 x 28 x 1/2 183.5 0.5
28 x 28 x 3/8 138.95 0.375
26 x 26 x 5/8 208.79 0.625
26 x 26 x 1/2 169.89 0.5
26 x 26 x 3/8 128.74 0.375
24 x 24 x 5/8 191.78 0.625
24 x 24 x 1/2 156.28 0.5
24 x 24 x 3/8 118.53 0.375
22 x 22 x 5/8 174.76 0.625
22 x 22 x 1/2 142.67 0.5
22 x 22 x 3/8 108.32 0.375
20 x 20 x 5/8 157.75 0.625
20 x 20 x 1/2 129.06 0.5
20 x 20 x 3/8 98.12 0.375
18 x 18 x 5/8 140.73 0.625
18 x 18 x 1/2 115.45 0.5
18 x 18 x 3/8 87.91 0.375
16 x 16 x 5/8 127.37 0.581
16 x 16 x 1/2 103.3 0.465
16 x 16 x 3/8 78.52 0.349
16 x 16 x 5/16 65.87 0.291
14 x 14 x 5/8 110.36 0.581
14 x 14 x 1/2 89.68 0.465
14 x 14 x 3/8 68.31 0.349
14 x 14 x 5/16 57.36 0.291
12 x 12 x 5/8 93.34 0.581
12 x 12 x 1/2 76.07 0.465
12 x 12 x 3/8 58.1 0.349
12 x 12 x 5/16 48.86 0.291
12 x 12 x 1/4 39.43 0.233
10 x 10 x 5/8 76.33 0.581
10 x 10 x 1/2 62.46 0.465
10 x 10 x 3/8 47.9 0.349
10 x 10 x 5/16 40.35 0.291
10 x 10 x 1/4 32.63 0.233
10 x 10 x 3/16 24.73 0.174
9 x 9 x 1/2 55.66 0.465
9 x 9 x 3/8 42.79 0.349
9 x 9 x 5/16 36.1 0.291
9 x 9 x 1/4 29.23 0.233
9 x 9 x 3/16 22.18 0.174
8 x 8 x 5/8 59.32 0.581
8 x 8 x 1/2 48.85 0.465
8 x 8 x 3/8 37.69 0.349
8 x 8 x 5/16 31.84 0.291
8 x 8 x 1/4 25.82 0.233
8 x 8 x 3/16 19.63 0.174
7 x 7 x 5/8 50.81 0.581
7 x 7 x 1/2 42.05 0.465
7 x 7 x 3/8 32.58 0.349
7 x 7 x 5/16 27.59 0.291
7 x 7 x 1/4 22.42 0.233
7 x 7 x 3/16 17.08 0.174
6 x 6 x 5/8 42.3 0.581
6 x 6 x 1/2 35.24 0.465
6 x 6 x 3/8 27.48 0.349
6 x 6 x 5/16 23.34 0.291
6 x 6 x 1/4 19.02 0.233
6 x 6 x 3/16 14.53 0.174
6 x 6 x 1/8 9.86 0.116
5-1/2 x 5-1/2 x 3/8 24.93 0.349
5-1/2 x 5-1/2 x 5/16 21.21 0.291
5-1/2 x 5-1/2 x 1/4 17.32 0.233
5-1/2 x 5-1/2 x 3/16 13.25 0.174
5-1/2 x 5-1/2 x 1/8 9.01 0.116
5 x 5 x 1/2 28.43 0.465
5 x 5 x 3/8 22.37 0.349
5 x 5 x 5/16 19.08 0.291
5 x 5 x 1/4 15.62 0.233
5 x 5 x 3/16 11.97 0.174
5 x 5 x 1/8 8.16 0.116
4-1/2 x 4-1/2 x 1/2 25.03 0.465
4-1/2 x 4-1/2 x 3/8 19.82 0.349
4-1/2 x 4-1/2 x 5/16 16.96 0.291
4-1/2 x 4-1/2 x 1/4 13.91 0.233
4-1/2 x 4-1/2 x 3/16 10.7 0.174
4-1/2 x 4-1/2 x 1/8 7.31 0.116
4 x 4 x 1/2 21.63 0.465
4 x 4 x 3/8 17.27 0.349
4 x 4 x 5/16 14.83 0.291
4 x 4 x 1/4 12.21 0.233
4 x 4 x 3/16 9.42 0.174
4 x 4 x 1/8 6.46 0.116
3-1/2 x 3-1/2 x 3/8 14.72 0.349
3-1/2 x 3-1/2 x 5/16 12.7 0.291
3-1/2 x 3-1/2 x 1/4 10.51 0.233
3-1/2 x 3-1/2 x 3/16 8.15 0.174
3-1/2 x 3-1/2 x 1/8 5.61 0.116
3 x 3 x 3/8 12.17 0.349
3 x 3 x 5/16 10.58 0.291
3 x 3 x 1/4 8.81 0.233
3 x 3 x 3/16 6.87 0.174
3 x 3 x 1/8 4.75 0.116
2-1/2 x 2-1/2 x 5/16 8.45 0.291
2-1/2 x 2-1/2 x 1/4 7.11 0.233
2-1/2 x 2-1/2 x 3/16 5.59 0.174
2-1/2 x 2-1/2 x 1/8 3.9 0.116
2-1/4 x 2-1/4 x 1/4 6.26 0.233
2-1/4 x 2-1/4 x 3/16 4.96 0.174
2-1/4 x 2-1/4 x 1/8 3.48 0.116
2 x 2 x 1/4 5.41 0.233
2 x 2 x 3/16 4.32 0.174
2 x 2 x 1/8 3.05 0.116
1-3/4 x 1-3/4 x 3/16 3.68 0.174
1-5/8 x 1-5/8 x 3/16 3.36 0.174
1-5/8 x 1-5/8 x 1/8 2.42 0.116
1-1/2 x 1-1/2 x 3/16 3.04 0.174
1-1/2 x 1-1/2 x 1/8 2.2 0.116
1-1/4 x 1-1/4 x 3/16 2.4 0.174
1-1/4 x 1-1/4 x 1/8 1.78 0.116
Angle Iron Span Chart
The table below lists the maximum Allowable Concentrated Load (lbs) a single angle, single channel, or double channel can carry when the load is applied at the center of the span. The numeric columns are span lengths in feet (3–8 ft); a dash (—) means no rating is published for that span.
Type Member Space Between Double Channel 3 ft 4 ft 5 ft 6 ft 7 ft 8 ft
Single Angle 3" x 3" x 1/4" — 1290 970 770 645 555 485
Single Angle 4" x 3" x 3/8" — 3330 2500 2000 1670 1430 1250
Single Angle 5" x 3" x 3/8" — 4900 3660 2930 2440 2100 1830
Single Angle 6" x 4" x 3/8" — 7350 5500 4400 3670 3140 2750
Single Channel 4" @ 5.4 # — 4220 3170 2540 2060 1510 1160
Single Channel 5" @ 6.7 # — 6670 5000 4000 3120 2290 1750
Single Channel 6" @ 8.2 # — 9560 7170 5740 4370 3220 2460
Single Channel 7" @ 9.8 # — 13300 10000 8000 6050 4450 3420
Single Channel 8" @ 11.5 # — 18000 13500 10800 8300 6050 4650
Single Channel 9" @ 13.4 # — 23300 17500 14000 10800 8000 6080
Single Channel 10" @ 15.3 # — 29800 22400 17900 14100 10300 7900
Double Channel 4" @ 5.4 # 2" 8440 6340 5080 4220 3620 3170
Double Channel 5" @ 6.7 # 2-1/2" 13340 10000 8000 6660 5720 5000
Double Channel 6" @ 8.2 # 2-1/2" 19120 14340 11480 9580 8200 7180
Double Channel 7" @ 9.8 # 3" 26600 20000 16000 13300 11440 10000
Double Channel 8" @ 11.5 # 3" 36000 27000 21600 18000 15440 13500
Double Channel 9" @ 13.4 # 3-1/2" — 35000 28000 23300 20000 17500
Double Channel 10" @ 15.3 # 3-1/2" — — 35800 29800 25600 22400
Machining resources with a table of allowable concentrated loads in lbs for metal fabrication channels.
