Great! G-Wizard Calculator should be downloading.
Recommended: Uninstall G-Wizard with Windows Control Panel
before installing a new version.
Look where your browser normally shows downloads, and
Run or Open the install file to finish up.
If your download didn’t start, click here:
Download G-Wizard Calculator v5.51 (Latest Version) for PCs
You're just minutes away from Great Feeds and Speeds!
Next Steps:
If it asks you to download a newer version of AIR, you can download AIR via:https://airsdk.harman.com/runtime
Watch this video while G-Wizard downloads. It takes you through the whole G-Wizard setup:
Once the download finishes, run the file to install. You must be logged in as an Administrator or the install will fail.
When G-Wizard comes up, login with your email. It must be the same one you used to register or purchase.
You'll get an email shortly that fills you in on all the details of how to run G-Wizard.
If you get a "Certificate Error", the fix is easy. For Windows, uninstall using the Windows Control Panel and rerun the install.
Having install issues? Visit our Troubleshooting page for help.
