G-Wizard Conversational CNC
Last modified: December 10, 2023
Is Manual Machining Faster Than CNC For Simple Parts?
Not With Conversational Programming!
With G-Wizard Editor's exclusive Conversational Programming, you can use simple point and shoot Wizards to generate quick G-code.
No CAD drawings, no CAM, no complex G-code programming-perfect for quick projects.
Conversational CNC Milling Wizards tool on CNCCookbook.com website with menu options for machining operations and a warning message.
Conversational Programming is Built Into
Every Copy of G-Wizard Editor.
Click to download your free trial copy of GW Editor with Conversational Programming.
Quick setup. Full power free for 30-days
CAM isn't always the best answer
Sometimes you need a faster, simpler solution
Sometimes you need Conversational Programming Software
Look, CAM is indispensible, but for some simple jobs it's overkill.  Here's what's wrong with using CAM for every CNC programming task:
CAM needs a drawing to start from. With CAM, there's no working from the back of the envelope.
CAM needs a lot of detail to support all the fancy things it can do. But if you're not doing anything fancy, why provide all the detail?
CAM is expensive and not everyone has a seat. How can knowledgeable machinists be productive without CAM?
CAM has a steep learning curve. How do manual machinists leverage their considerable knowledge to be productive right away?
CADCAM is powerful but slow. You can't do complex jobs without it. But why be slow on simple jobs?
Conversational Programming can help with all these problems.
Conversational Programming is a Built-in Module of G-Wizard Editor that's Free!
Here's How it Works:
Start Simple: Pick an Operation
Choose the Conversational Wizard for your task:
There are simple Wizards for most common tasks by machine. Mills and Routers get the Wizards shown above. Lathes get their own Wizards:
Grey computer screen displaying a conversational CNC machining software interface.
You couldn't ask for easier cnc lathe programming software.
Fill in the Blanks
A popup appears giving you a simple set of inputs to fill in:
Machining software Conversational CNC Milling Wizard interface screenshot.
Easy to Access Power
It's easy to fill in the blanks, but they give you easy access to power. Each Wizard has been designed with an eye towards what real world machining situations need.
Here are just a few of the power features available:
Add Conversational CNC to Your Toolbox
Everyone should have a little Conversational CNC Programming power in their Toolbox. It doesn't replace CAM, but it sure is handy for a lot of jobs.
The best thing is it comes with a radically easier way to deal with all G-code because it is a free built-in module of our powerful G-Wizard Editor and G-code Simulator.
No need to buy an expensive stand-alone Conversational package or machine option. Just get a copy of G-Wizard Editor, and you'll instantly have access to Conversational CNC.
Give Conversational CNC a Try-It'll Save You Time
