Stirling Engine Plans and Models
Last modified: March 18, 2024
This page is largely links and pictures of model Stirling engines I've collected. Stirlings are fascinating "external" combustion engines that can be powered from a variety of heat sources. The "Low Temperature Differential" (LTD) Stirlings will run from the heat of the palm of your hand if they're made well enough, and by sitting atop a steaming mug of coffee if they're less efficient. Fascinating devices, no?
To build one that makes any power requires a fair amount of precision. I rate Stirlings as harder than steam engines, but MUCH easier than model turbines!
Here is a Rhombic driven Stirling:
Beta Stirling TG4 engine, closed-cycle external combustion engine with oscillating piston and displacer, showing cylinders, pistons, and displacers.
I'm also interested in larger Stirling designs for the production of electricity from solar power. See my page on that for more.
My Stirling Engine Models
Jaxa Low Temperature Differential Free Piston Stirling
This was a kit that required no machine work, but it was fun anyway. It runs on a cup of coffee:
Cardboard box with Japanese packaging text.
The box came straight from Japan via eBay…
Metal components, tools, and accessories on a surface with safety glasses nearby.
Pretty simple set of parts. The celluloid plastic are “springs”…
Metal device with metal cylindrical stem on top of white coffee mug.
It was running, but the camera stopped it. Click for a QuickTime movie…
If you want one, search for Free Piston Stirling on this eBay Store
Great Primer on How the Stirling Works
Nice spreadsheet walkthrough on how to design a Stirling engine
Excellent Schematic Overview of Various Stirling Configurations
Quirky Engines: Theory, various projects, and models you can order.
Wonderful Stirling Engine Animations
Stirling Engine Forums
Great Collection of Stirling Articles Reprinted
Ivan's Practical Tips for Building a Stirling
Koichi Hirata's Model Stirling Pages: Theory, free plans, and a lot more
UK Stirling Engines Organization
A 3D CAD model of a mechanical device with a cylindrical body, yellow ring and red components.
Typical layout for a model Stirling. This is the classic Kouhoupt model...
Stirling-powered Robot Fish : Interesting Japanese project. Nice scale of Stirling.
Coffee Table Stirling Engines: Nice collection of photos.
Jon Bondy: Has built several model Stirlings, has a Stirling design program on the site, and keeps octopus and cuttlefish as pets. How do you go wrong with that?
Low Temperature Difference Stirling: Run a Stirling just by setting it on top of a steaming mug of coffee.
Steele Stirling Engine Plans: A 4-cylinder design capable of claimed 40 watts. It's about the size of a big model airplane engine.
A Tin Can Stirling: You can build a Stirling out of most anything, and need not even have machine tools.
Roy UK's Stirlings: Several to choose from made from simple materials.
Logic System Technology: Several interesting designs including a super low temperature differential Stirling that runs just from the heat of you palm.
Stirling South: Nicely made CNC Stirlings from some college professors. Here is the main Stirling page. The rest of the site is also quite fun!
Wonktoys: Another "no machine work" site.
Edward Bashauer: I love his Stirling Airplane Engine!
Alphonse Vassalo: Many finely crafted Stirling models including a 4-cylinder.
Bill Sondagh: Talented Netherlands builder has several nice models on display.
Daniel Lyonnet: Has built a number of Stirling models.
See-Saw Stirling: Not sure what one would use this for, but it would make for an interesting outdoor sculpture. A really novel Stirling design.
John Horne's Stirling Tractor: A museum quality Stirling-powered steam-style tractor model.
Barry Dunman: His "coffee table" Stirling is a delight.
John Hastings: Some nice LTD Stirling work!
Test Tube Stirling: Test Tube Stirlings may be the simplest way to play with a Stirling. This site has a nice one and a movie of it running.
Syl's Hobby Page: Lots of engines and other HSM projects.
Jos de Vink: Many beautiful engines styled in an old time Brass 17-1800's style.
Jan Ridder's Modelbouw: Many interesting engines on display, and he will send you plans too!
Boyd's Tin Can Stirlings
LTD Striling Plans: Plans for a relatively easy to build LTD.
Free Piston Stirling from Japan that'll run on a cup of coffee. Made by a company called JAXA. Here is a gallery of pix building one.
The Hermit's Machine Shop: A few Stirlings similar to Rudy Kouhoupt's including a Stirling fan.
Gold Stirling: Plans available, plus some gorgeous pictures of models.
Airpots: Marv Klotz says airpots/dashpots make great Stirling cylinders if you don't want to fuss with making one yourself. This company sells airpots ready to go.
Thoughts on Stirling Engine Models
The purpose of making the heater chamber longer than the cooler was to maximize the temperature differential between the two. Use of thin wall tubing and making the chamber walls out of something that doesn't conduct heat so well (although it has to conduct the heat into the chamber, just not along the chamber longitudinaly) is also helpful.
Photos of Stirlings I particularly liked. These all came from sites in the links above.
Early 20th-century steam engine-powered tractor internal mechanics.
John Horne's Stirling Tractor...
Four silver metal cylinders with copper wires.
4-Cylinder Stirling by Alphonse Vassalo
Small airplane model with propeller and wing next to a coin.
Edward Bashauer's Stirling Airplane Engine
A bald-headed man in glasses examining a large parabolic solar reflector.
Alphonse Vassalo's Solar Stirling with an 18" Mirror
Industrial device with copper tubing and black component on metal plate over cylindrical object.
Alphonse Vassalo's "Backwards" Stirling has the hot section in the middle...
Small cylindrical metal device with central hole and ridged surface on a base plate.
"Blazer" is a Duclos-designed Flame Licker by Roy Rice...
Antique telegraph key with moving balls on rods for sending Morse code messages.
Barry Dunman's "coffee table" Stirling is a delight. It's amazing what can be done with test tubes and marbles!
Small metal devices with coils and wires displayed on wood.
Bill Sondagh of the Netherlands has a fine collection of Stirlings he has built...
Vintage brass-handled tap wrench for metalworking.
Aquatap is a Ringbom Stirling by Roy Rice at Stirling South. The Ringbom requires no mechanical linkage between the two chambers.
Metal device with cylindrical component and attached spherical elements.
Closeup of the gimbals and mechanisms on Barry Dunham's Test Tube Stirling. I still can't quite make out how the displacer end works...
Silver metal gear system on glass base.
Roy Rice's Rhombic driven test tube Stirling is way cool!
Silver metal gear mechanism on clear acrylic base with interlocking teeth.
Detail of Rice's Rhombic drive...
Antique Stirling engine
Chuck Fellows built this very nice vertical Stirling...
Small intricately designed metal mechanism on a wooden platform amidst lush greenery.
An interesting and attractive Stirling that reuses an old OS model airplane motor...
Circular plastic or acrylic wheel with four spokes on a cylindrical stand submerged in shallow water.
Syl's Miser is an LTD with nice details...
Intricately designed mechanical device with rotating parts.
"Beamer" is another nicely detailed engine by Syl...
Silver metal device with blue tape on wooden table.
A 3-Phase LTD Stirling built as a research project at UC Berkeley...
A small metal device with spiral-shaped mechanism and cylindrical component sits atop a light-colored stone surface on a rectangular wooden base inscribed "Stirling Engine".
Classic Stirling Design...
Mechanical device on wooden base with metallic composition featuring gold and silver hues.
Nice looking Stirling, apparently from a kit sold by Forrest Classics and made by Bohm. I like the styling...
Antique Stirling engine with intricate metalwork.
Another ridiculously cool Bohm model! Looks like it took some waterjet or laser and CNC to make it. You gotta love the Steampunk + Raygun motif...
Antique drill press in glass display case with wooden base and metal components, large wheel on right side, smaller wheel on left.
"Vickie" is my favorite Syl Stirling...
Brass clock with glass cylinders and wooden base.
Jos de Vink's Beautiful "Kathedraal"
