7 Handy Tools You Didn't Know You Needed
Last modified: March 1, 2024
I must admit, I am quite the Tool Enthusiast and Gadget Junkie. When I stumble upon a novel and interesting item, I feel the need to possess it. Here are the recent additions I've been wanting to incorporate into my tool collection:
Small and Handy LED Flashlights
Machinists are often poking around in dark corners, trying to see what's going on.  Having a small handy flashlight can really help.  I am reminded of this time and again working with others who have a plethora of lights and always one ready for the task at hand.  I favor small flashlights and especially LED lights that are brighter and last longer.  I want something small enough it is always handy and could be held in the teeth in a pinch.  Of the ones I have tried, I particularly like Fenix's E01 and E05 models:
Black flashlight with Fenix E01 branding and textured grip.
The E01 is smaller and cheaper-keychain sized and way under $20.  While the E05 is a little brighter and a little more money-right at $20.  While the E05 is nicer, the E01 often suffices.  Good enough is good enough where these little utility lights are concerned.  I'd almost rather buy two E01's for the price of an E05, but many do prefer the higher performance light.
Cheater Bar for Wrenches
If it helps me get into a tight spot or exert more force on a stubborn fastener, I automatically want one.  A pipe is the usual solution when you need leverage, but I like this elegant alternative I found on ToolGuy's column:
A silver metal wrench extender or cheater bar with a flat end, long handle, and "WRENCH" text.
Wrench extender with rare-earth magnets on end of arms.
It definitely looks handy and the magnets are icing on the cake.
Olfa Rotary Cutter
I had not ever seen a rotary cutter but many swear they're far better than a razor blade for precision cutting of the sorts of materials you'd cut with a razor blade.  The Olfa's look pretty nice:
Rotary cutter with yellow and black handle, silver blade, and red button.
The Olfa Rotary Cutter...
Hat tip to Cool Tools for putting me on to these things.
Nicer Crescent Wrenches
Let's face it, the homely Crescent Wrench is a compromise at best.  You use it when you don't have a proper wrench or socket that fits.  It's generally not a great tool to use, and it often has so much slop that it next seems to be adjusted correctly.  What if you could get a nicer version of the classic?  That was my reaction when I saw the Channel-Lock Extra Slim Adjustable Wrench:
Blue handled Channellock Xtra Slim Jaw Adjustable Wrench.
Padded handle, a more machined and less cast look, calibrations (!), fits in narrower spaces-heck, maybe this is a better tool.
Compound Action Pliers
Man, I need to get some of these.  For all those times when I'm trying to cut piano wire or something else that's a little too thick, too tough, or just plain too ornery for my regular pliers, these would've been great.  I came across two varieties.
Speaking of Crescent, they make a nice pair:
Crescent Diagonal Nose Pivot Pliers with red and black handles.
Stanley also makes them, in even greater variety:
Dark gray Stanley pliers cutters with yellow stripes.
Apparently, the Stanley pliers are not yet available in the US, so you'll have to order via the Internet rather than visiting your local Big Box DIY Store.
Adhesive Rulers
A person uses a ruler to measure a cardboard box on a teal table.
These are just stick-on rules that can be bought by the roll.  No biggie, but sure seems like they'd be handy to have on a lot of surfaces around the shop.
Klein Rapi-Drive Screwdriver
Okay, last one.  I love the speed brace for sockets.  Not as much as my air ratchet wrench, but it is handy.  Here's the moral equivalent for screwdriver, the Klein Rapi-Drive:
A Klein Rapi-Driv screwdriver with interchangeable tip and black handle.
Flip tip to switch from standard to Philips...
Again, not going to replace your impact driver or other screwdriver power tool, but I can see where they'd be handy.  Incidentally, we have an entire article on the World's Best Screwdriver Sets and Klein is there as is the Rapi-Drive.
