Lean Manufacturing is a powerful tool for improving productivity in Manufacturing (actually for many other business areas too).
We’ve created a series of articles that taken together provide a Free Lean Manufacturing Mini-Course to give you the tools and principes you need to understand what Lean Manufacturing is, what it can do for you, and how to go about implementing it.
Table of Contents
What is Lean Manufacturing?
An overview of what Lean Manufacturing is and what are its key guiding principles.
5S: Organizing for Productivity the Lean Way
5S is all about the productivity implications of organization. A place for everything and everything in its place makes a big difference for manufacturing productivity.
Kaizen: Continuous Improvement the Lean Way
Kaizen is about enrolling everyone from CEO on down to the cleaning staff in continuously making good changes. It is Lean Manufacturing’s approach to Continuous Improvement.
Value Stream Mapping
Value Stream Mapping is a visual means of analyzing processes that makes it easier to find and eliminate the waste.
Standard Work and Takt Time
Standard Work, Standardized Work, and Standardized Work Instructions all refer to Lean Manufacturing’s approach to documenting and following Best Practices which are subject to continuous improvement as new ways to eliminate waste are discovered.
SMED: Lean Manufacturing’s Approach to Setup
SMED is all about tooling up to be able to change jobs quickly–essential for any modern Job Shop.
Kanban Visual Scheduling
Imagine being able to efficiently schedule the Shop Floor by playing a game of solitaire.
Lean Manufacturing for Job Shops
Turns out that Lean Manufacturing can be very helpful for High Mix Low Volume Job Shops.
Visual Factory
Reducing communication waste the lean way.
Cellular Manufacturing
Group facilities by similar part families to save the lean way.
Poka-Yoke
Mistake Proofing
DFMA
80% of available manufacturing cost savings must come at design time. DFMA (Design for Manufacture and Assembly) tells you how.
I’m retired now. I worked for a large jet engine manufacturer and we started this journey in the early 90’s and incorporated all of these tools in a culture changing program called ACE. (Achieving Competetive Excelence). For most of this journey, I was an Engineering manager that managed a team of people from all organizations in the company focused around an engine section from conceptual design until maturity in service. We used all of these tools and more to improve both manufacturing proesses and engineering processes as well. To make a long story short, after I retired and then quit drag racing I bought a HAAS MiniMill. Last summer I was making Torgque-flight transmission parts for a friend who specializes racing transmissions. After I made a few parts, I revised the process to achieve 1 piece Flow and and TAKT time of ~6 minutes. The message is. This stuff works
