Folks loved our recent post about making an engagement ring with CNC, so we thought we’d pass along this article from Cubify too.  I had to try the technique described, so here is what I did:
Start by taking a profile photo of your fiance:
fiancee profile
Take a profile shot of your fiancee, and use the profile as a form for the ring…
 I drew the red line freehand in Photoshop with the image magnified full screen so I would have something to go by.  I then loaded that image as a background image in my CAD program, Rhino3D.  A lot of CAD programs will do this to make it easy to trace things from images.  Once loaded, I took the spline (curve) tool and started dropping points along the profile outline to create a nice smooth curved that mirror’s the young lady’s profile:
fiancee profile spline
Here is the spline curve tracing in Rhino3D of the profile…
Next, I rotated the spline so it was vertical, and used the spline tool to draw the inside contour of the ring:
3D model cross section
3D cross section of the ring…
This left me with a 3D cross section of the ring.  I’m just blasting through this without much regard to scale or ring finger sizing, but you get the idea.  The last step is to rotate that cross section around an axis to produce a 3D model of the ring:
3D jewelry model
3D Model appears after rotating the cross section around the red axis…
That particular cross section came out a little too thick and industrial strength for the lovely piece of jewelry that the article is written about, but you get the idea.  To wind up with a ring, have the 3D model printed in wax and then the wax model can be cast in silver or gold.  Voila, you have a very unique, personalized, and memorable piece of jewelry!
Here is what the end result looked like:
3D printed wedding ring
The finished ring…
Wasn’t that a brilliant idea?  Lots of other cool stuff over on the Cubify blog.  This gives an idea of what’s possible when 3D printing.
I am also checking out their new $49 parametric 3D CAD program and will publish a review after I get more familiar with it.  Thanks to Robert over at GRZSoftare for putting me onto it!
