Improve My CNC Mill Speeds and Feeds
We obsessed over
It took years, we analyzed data from over 250 tooling catalogs, we built a powerful cutting physics engine with advanced algorithms that consider almost 60 different variables.
We added AI Machine Learning algorithms, and we worked with over 100,000 CNC’ers like yourself to make sure you’d have:
Here’s How:
Spindle Speed and Feed Rate.
Feeds and Speeds Calculator
Adjusts to Your Needs
Turning and Lathe Tools
high speed machining calculator hsm advisor
speeds and feeds chart pdf
tungsten feeds and speeds cobalt chrome graphite
Giant Material Database
Expert Tips
cnc machining tips and techniques
machine tool chatter in machining
Tame Chatter in Machining
high pressure through spindle coolant feeds and speeds
Powerful for Experts
The CNC Business can be tough. Get every advantage you can. For example, you paid extra for those special machine options. Programmable Coolant Nozzles. Through Spindle Coolant. High Pressure Coolant.  And G-Wizard will take advantage of those powerful coolant options.  Why use a Calculator that wouldn't?
Learn More
CUSTOMER SUCCESS
TRUSTED BY INDUSTRY LEADERS
  Start Now, It’s Free!
Show me how to improve feeds and speeds for:
You need G-Wizard Calculator!
