Optimized Feeds and Speeds for Your Manufacturing Needs
Optimize your Speeds and Feeds the easy way with G-Wizard.
“I’ve been asking for this for 30 years from the CAM guys. This program is the ‘go-to’ source for feeds and speeds” Ed
What would those kinds of improvements translate to
for your Manufacturing Business?
Higher Profitability. More Competitive Bids. Easier Wins.
That’s why so many World-Class Manufacturers use it daily.
The Easy Way.
Getting good Speeds and Feeds is quick and easy: Fill in the blanks left to right, top to bottom and G-Wizard instantly returns the best Spindle Speed and Feed Rate.
How do you know when you’ve got the best Cut Depth and Cut Width? These two parameters matter more than almost any other for best Speeds and Feeds. G-Wizard will find the best combination to keep tool deflection under control while maximizing Material Removal Rate. No other software can.
Adjusts to Your Needs
CADCAM Wizards will do that for you automatically in a matter of seconds and without asking too many questions. It’s like having a machining expert sitting at your shoulder telling you the right combination for the win–another G-Wizard first!
G-Wizard Calculator handles more different kinds of tooling than any other Speeds and Feeds Calculator. Import and Export tables from CSV files, use Manufacturer’s Recommended Data, define tool geometry, and use dozens of tool types for Mills, Routers (special router cutters handled) and Lathes. End Mill Speed and Feed: Coatings (including PCD) & Geometry (Ballnose, Upcut, Downcut, Compression, and more) Drill Feeds and Speeds: Carbide, HSS, and Parabolic Turning and Lathe Tools Reamers, Saws, Woodruff Cutters, Corner Rounders, Tapping, Thread Mills, and Boring Heads
High Speed Machining. It’s almost magic the way it increases productivity while saving tool life.
G-Wizard’s cutting physics engine considers nearly 60 variables. No chart will ever do that!
Giant Material Database
Expert Tips
Tame Chatter in Machining
Powerful for Experts
Integrated Job Quoting Software
The biggest problem with Job Quoting and Estimating Software today is that it often produces unrealistic numbers.
G-Wizard Estimator is different. It’s built with the G-Wizard Calculator Engine, so it gets the same answers as Calculator would.
Why wouldn’t you want to base your quotes on the Real World numbers you’d use to manufacture the parts?
Take the Tour
See Our Customer List
