I got a nice note from Carlos the other day mentioning how much G-Wizard Calculator had helped him on his CNC Router projects.  I always like to run articles about what customers are doing, and in this case, Carlos has a fascinating project.
He talks about how wood and brass clocks have a hard time being accurate as the materials are subject to changing dimensions as the humidity and temperatures change in the room they’re in.  His solution was to create a microprocessor controlled escapement mechanism.  This lets the electronics adjust the timing of clock to keep it accurate.
here is a 3D rendering of the clock:
CarlosZilzerPythagoras1
The Pythagoras Clocl…
He calls the design “Pythagoras” due to the triangular framework used to mount the gears.  He has a multi-part series on the clock on his blog, including a very nice mention of G-Wizard Calculator.
Here is a shot of the current state of the clock:
CarlosZilzerPythagoras2
It’s not quite done yet, but definitely taking shape.  I would very much like to do an ornate wooden clock at some point, and I also have designs on a fancy astronomical orrery clock that I have done some design work on.
Great project Carlos, thanks for sharing it!
