Special Deal from Alibre:
Get CNCCookbook’s G-Wizard Feeds and Speeds Calculator for 15% Off
CUSTOMER SUCCESS
Stop Guessing and Master Your Feeds & Speeds!
It took years, we analyzed data from over 250 tooling catalogs, we built a powerful cutting-edge physics engine with advanced algorithms that consider almost 60 different variables, we added AI Machine Learning algorithms, and we worked with over 100,000 CNC’ers like yourself to make sure you’d have better Tool Life, Surface Finish, and MRR with G-Wizard.
Leave behind outdated rules of thumb and broken tools and see the power of the world’s most advanced CNC software! Explore how our software can improve the efficiency of your machines.
Essential Software for Improving CNC Programming
“I'm absolutely thrilled to have discovered G-Wizard while working at my first job as a CNC programmer. It's incredibly useful for taking the theoretical structure of milling work and producing effective, efficient, engineered feeds and speeds that REALLY help me get things done properly on the first try instead of guess-and-check manual adjustments based on oversimplified rules of thumb. Seems like an essential piece of kit for any programmer who wants to be taken seriously, or just doesn't have the budget to be breaking tools while flailing around with new challenges.”
Based on 73 reviews
Instant Download! No Credit Card Required!
G-Wizard Calculator Free Trial
56% Longer Tool Life - 46% Faster Cutting Speed - 94% Time Saved
Master your Feeds and Speeds in 5 Minutes or Less with G-Wizard
FEATURED ARTICLES
Easy Guide to Threadmills
Calculator, Speeds/Feeds & Programming
Threadmills are cutters used in CNC millling machines to cut internal and external threads. The process is called “CNC Thread Milling.” The other threading process for CNC Mills is Tapping. On lathes, single point threading (turned threads) and taps are used. The popularity of these methods is Tapping, Single Point Threading, and Thread Milling.
Turret Lathe or Gang Tooling for CNC?
Swiss Lathes
This is one of the many topics that seems to engender religious fervor from one side versus the other. I personally went through several hundred online articles and correspondences I’ve had with our G-Wizard customers about this choice.
