Materials,
Finishes, and Treatments |
This
page contains my notes on the materials I've machined, how I found them,
and on some finishes and treatments I've experimented with.
Materials |
I
started out mostly acquiring my machining stock on eBay.
There's a bunch of it up there, the only question is price. My approach
was to look for auctions nobody was bidding on, and go look up the
price of something similar from one of the online suppliers. If
I could bid half what the online supplier offered at, I would try
to take the material.
You'd
be surprised at how often this works. A lot of the material on eBay
is coming from machine shops who can't use the material, so anything
they get for it is gravy. Beware the shipping--that's how they make
sure you don't get too good a deal. The best opportunities are small
pieces that are the scraps left over from some small production
run. These pieces turn out to be perfectly sized in many cases for
our small home machine tools and projects anyway.
One
of the really nice things about buying in this way is that you actually
know what alloy you are getting, unlike scrounging metal from old
machines and junkyards. The problem with the latter is that a lot
of metal has very poor machining properties. Machine shops will
order very little of that!
Spark
Testing: This is an important help in identifying what kind
of material you are working with. It is a comparative test, so its
helpful to have some known quantities available to compare to. I
have found pictures are not the same as seeing it yourself with
this test. It's hard for the pictures to control for variables like
the angle and pressure against the grinding wheel. Nevertheless,
get thee to thy Internet and read up. Try to compare what you think
you have with a known quantity.
Stainless Steel |
Identification:
If it looks like steel, weighs like steel, but is non-magnetic,
that's a pretty sure indicator. I keep a welding magnet near my
material storage area just for
checking as I inventory the material. Sparking will be similar to
mild steel, as there is very little carbon in most stainless. The
exception is that there are stainless tool steels (4xx allow family)
that respond to heat treatment. These would be rare to find unless
you paid a premium, however.
Hardening and Heat
Treatment: Most stainless will work harden, which means it gets
tougher the more you work it. If you do wind up work hardening a
piece, you'll have to anneal it to relieve the hardening so you
can go on working it. I have not yet seen the work hardening effect
turning and machining stainless. If you heat treat most 3xx stainless
alloys they do the opposite and become softer.
303:
I did my first cuts on the lathe on a little piece of 303. That
original piece lives on today in the adapter
I made for my Quick Change Toolpost. This is nice stuff to cut
on the lathe, and finishes real nice too, although not as nice as
12L14. Some use of a finer grit sandpaper such as 1200 grit will
develop a finer finish.
Other Stainless:
I've got a fair amount of unidentified stainless. Most of it does
not cut as nicely as the 303, and some is just darned ornery. You
can't get away from a grooved finish on it no matter what I do,
so I am left to file it if I want a nice finish.
Mild Steel |
Identification:
If it looks like steel, weighs like steel, but is magnetic, you're
down to whether you have mild steel or a harder steel. On the spark
test look for longer streamers from the wheel with fewer sparkles.
Hardening and Heat
Treatment: Mild steel does not have enough carbon to respond
strongly to heat treating, but it will respond a bit by becoming
slightly harder. It is probably not worth your trouble to try to
harden mild steel unless you do so by case hardening which involves
providing additional carbon the part is packed in.
12L14: Following
closely on the heels of my stainless experience was some 12L14 mild
steel. I got a little more ambitous with this, and turned some hex
stock to make a tailstock die
holder. This material is a little softer than the 303 stainless
was, but I don't think it produces quite as shiny a surface finish
with my carbide insert tooling. Nevertheless, a fine finish is possible,
and the material cuts very quickly and with almost no chatter. This
is a nearly perfect steel for the home machinist to fool around
with early in their career.
Hard Steels |
Identification:
test, the sparks will tend to end closer to the wheel, and the more
carbon (i.e. the harder the material), the more sparkles you'll
see. A noticeably different spark, perhaps with unusual colors and
shapes implies an alloy steel of some kind.
Hardening and Heat
Treatment: Most hard steels respond well to heat treatment by
becoming very hard. Experience dealing with hardening, tempering,
and annealing will be a requirement to successfully manage these
steels.
No experience here
yet!
Internet Notes:
O6: Recommended
by Evan on the HSM board, O6 is an oil hardening tool steel with
120% machinability.
D2:
Air hardening. Designed to reach the upper 50's and low 60's on
hardness. When you look at a hardness
vs tempering temperature curve, you'll likely find D2's hardness
will drop 15 or more points in a range of less than 100*F when you're
shooting for hardness in the mid 40's. Accurate tempering becomes
difficult if not impossible. Most of the high chrome air hardening
tool steels are secondary hardening steels as well. The hardness
drops initially, and then begins to increase again, usually peaking
in the 900 to 1000*F range. Once you pass that peak, the hardness
drops like a rock with increased temperature, hence the difficulty
of accurately tempering to hardness lower than the steel was designed
for.
W1 Drill Rod:
Water hardening. Supposed to be hard to get a good finish. Prefers
HSS to carbide. Particularly sensitive to machine rigidity. Some
Asian lathe owners suggest you have to machine it with a plinth
(no compound slide) to have much success. For carbide inserts, CCMT
inserts are suggested at higher rpm (actually, pretty high--1200-1800
rpm for 3/4"). Lubricant beneficial: cutting fluid or oil.
Resistant to shallow cuts (e.g. less than 0.010"), so finishing
cuts will leave a rough finish. Prefer O1 for a better finish.
4130 and 4140: Ideal for making
toolholders and the like. Designed to harden to the 40's. Easily
tempered.
L6: L6 is a good choice if
you need hardness in the mid 50's along with excellent toughness.
Its not nearly so highly alloyed as the D's or A's, and heat treats
more like common alloys than like tool steels. Costs a bunch less
than A's or D's as well.
Cast Iron |
Identification:
Heavy like steel, and magnetic. Grey cast iron is usually a lot
darker color than steel as it arrives, but after machining, it looks
about the same as un-machined steel. You will note the tons of graphite
(carbon) powder that goes everywhere when you machine cast iron.
On the spark test, cast iron produces relatively few sparkles, and
long dull reddish sparks compared to the colors and other characteristics
of steel.
Hardening and Heat
Treatment: I understand you can harden grey cast iron by heat
treating but that there is so much carbon the material becomes so
brittle as to be almost useless. Doubtless there is a process that
works great if you can track down the secret!
Grey Cast Iron:
I ordered a big chunk (too big!) of grey cast iron when it came
time to make a backplate for my Buck 6-Jaw
Chuck. What a project! The piece was right at the limits of
what my lathe would machine, so there was lots of chatter to deal
with. I am unsure whether this is a function of the cast iron itself
or just the size of the piece I worked. Cast iron is also incredibly
messy! It contains a tremendous amount of carbon which is trapped
between the iron crystals and comes out as graphite dust when you
cut swarf. To make matters worse, all that carbon leads to iron
carbides, so there is a lot of abrasive potential in the dust. Be
sure to clean your machine thoroughly when done! With that said,
the grey cast iron machines easily (similar to the 12L14) and develops
a nice surface finish (when you wipe away the gray dust). It is
also very hard. I dropped my backplate off the table and a sharp
edge hit directly on the concrete floor. It knocked a groove into
the concrete but I couldn't even find a scratch on the backplate!
Aluminum |
Identification:
Very light weight compared to steel and a little different, whiter,
shinier color usually reveals you're dealing with aluminum.
Hardening and Heat
Treatment: There are a number of heat treatments for aluminum
that are mostly designed to relieve work hardening and other undesirable
characteristics. It's unlikely you'll be doing any aluminum heat
treatments in the home shop, the material is typically purchased
in a particular heat treated state.
General Remarks:
I did my first milling on the lathe on a piece of aluminum to make
a saddle lock body. The stuff
cuts very easily and wants pretty high spindle rpms to even begin
to have a decent finish compared to the mild steel. A big disadvantage
is aluminum is soft enough that virtually everything leaves ugly
marks on it. If you don't care about appearance, no problem. If
you do, get ready for extra work. Note that aluminum gums up grinders.
It also seems to clog drill bits. Long streamers of swarf literally
cocoon the bit until it quits cutting. Higher speeds will tend to
make for shorter streamers, but you really have to crank it up.
Back out often to clear those chips! OTOH, it threaded real nice
and easy for the saddle lock project. We'll see how well those threads
hold in aluminum.
Relevant Threads:
Discussion
of bead blast finishing
Finishes |
Files, Sanding, and Hand Grinding |
Filing is my first
choice for quick finishing on the lathe, as it turns the file into
a power tool <G>. While on the subject of files, a couple
of thoughts:
- Nicholsons are recognized as the best, although there are some
European brands that are just as good.
- Keep them chalked with railroad chalk (available from Enco and
many other places), which helps keep them from getting clogged.
I also find heavy sulfurized cutting oil works well, but it can
be messy, so I general only use it on the lathe.
- Learn how to drawfile. I won't attempt to explain here.
- Keep a file card/file brush combination handy and clean the
file often so it doesn't fill up.
- I understand you can sharpen a file by soaking it in vinegar.
I haven't tried it, but would do some more web research before
trusting your file to it.
If not on the lathe,
I use a right angle air grinder with a fiberglass reinforced cutoff
wheel as a quick deburring tool.
Scale Removal |
If you are working
with cast parts, or want to remove scale from forged or hot rolled
steel before machining, a variety of pickling treatments are well
suited to the task. Look for names like Safe-T-Pickle and Sparex
which are quite common. Note that virtually all dry pickling agents
like Sparex are simply expensive trade names for a very inexpensive
chemical compound called sodium bisulfate.
In some cases, sand
blasting can also be an effective mechanism for scale removal.
Sand and Bead Blasting |
I picked up a very
inexpensive blasting cabinet off eBay. It looks identical to the
ones sold by Harbor Freight, but was cheaper at $89. I'm very satisfied
with it. I loaded it with glass beads, which leave a finer finish
than sand. In practice it leaves a nice satin finish on surfaces.
The beads are not a very effective way to clean, however, as they're
a little to fine in their action. Beads produce more of a polishing
action. A coarser grit will work better for cleaning or coarse work.
Carborundum grain, pumice, and sand are all common media for the
purpose. It's easy to swap grits. The grits sit in the bottom of
the cabinet and there is a door that will release them into a bucket
below. Dump the old grit, pour in the new, and you're ready to go.
Be sure to run the gun a bit between grits to clear any residue.
Note that blasting
can also produce hardening of the surface by work hardening it,
often called "peening". Blast
cabinets are cheap and any shop with room for one ought to have
one.
Polishing |
Lots of polishing
methods are available ranging from hand polishing on buffs to vibratory
polishing. The latter is a fast way to deburr and polish small to
large production runs of parts, depending on the capacity of your
vibratory polisher.
There is lots of good
material on hand polishing from the gunsmithing and knife making
fraternities, as they obviously value a very fine finish.
For vibratory finishing,
Shor has some of the best information available. For example, this
page on media.
See also my CNCCookbook
page on Vibratory Deburring and Polishing.
Anodizing |
Anodizing uses electricity
to open up pores on aluminum and deposit a pigment inside those
pores. It also hardens the surface of the aluminum. It is a process
that is fairly straightforward to do at home. I recommend a book
by Ron
Newman as your bible for anodizing at home. I haven't tried
the process yet, but the book is very comprehensive and Ron seems
to get good results for his own business using these techniques:
Ron
Newman Anodizing...
Anodizing's
hardening properties can also be quite helpful in making aluminum
more durable.
Cold Bluing |
Cold bluing uses acids
to put an oxidized finish on steel at room temperatures, or close
to it. They're very easy to apply, requiring only a thorough degreasing
before application. For fun I compared the finish from two Brownell's
cold bluing products:
Dicropan T-4 and Oxpho-Blue Creme Cold Bluing
Test
Both
the Dicropan T-4 and the Oxpho-Blue Creme came as creams, which
made them easier to apply. To perform the test, I took the spacers
I had made for my new 6-jaw chuck backplate and compared the results.
I simply cleaned them in some mineral spirits and then applied the
compounds with a folded paper towel. Do this wearing gloves as the
chemicals are fairly nasty. The steel turns blue quickly, after
which you rinse it in cold water to remove and neutralize the chemicals.
I then oiled the parts with Break Free, which is also an excellent
anti-corrosive. The oil helps bring out the blue a bit more.
My conclusion
was that the Dicropan looked darker, almost black, and seemed to
go on more evenly. On the other hand, the Oxpho-Blue showed more
blues and was a prettier finish despite it being less even. All
things considered, I decided I preferred the Oxpho-Blue look. I'm
not sure I'd want to do a whole firearm in it, but it's excellent
for making tools look better.
Rear three: Oxpho-Blue. Front spacer: Dicropan
T-4.
Hot Oil |
Here is a machinist's jack finished with a hot oil treatment:
I like
the look of the finish, though I don't know how protective or durable
it may be. It was done by Dave
Hylands who states that he simply "cooked" the jacks
in his BBQ for 30 minutes and then plunged them into some 20W-50
motor oil.
Parkerizing |
Parkerizing is a very
durable treatment often used on firearms. It's pretty straightforward
to set up a Parkerizing process in a small shop. Here are some picks
from an
HSM thread:
Stand
for a Parkerizing tank is just welded from angle iron...
Shopmade
propane burner...
Tank needs
to be stainless. This one was purchased from eBay for $99...
Chemicals
are from Lauer
Custom Weaponry. 1 Gallon is $29 and will last a long time!
Mixing
chemicals up in a big container like this is very convenient. Strain
through a coffee filter and return to the container when finished...
"Cooking"
a firearm in the solution. Rinse with clean water then apply the
Lauer Post Treatment solution. When that's all done, a little oil
and you have a military-grade nearly rust-proof finish!
Hot Bluing |
Treatments (i.e.
Heat Treatment, etc.) |
This is definitely
an area I'm very interested in experimenting with, both for the
hardening properties afforded heat treated steel as well as the
awesome temper colors that can be produced.
I have been interested
in heat treating metals for a long time, and finally sat down to
do a little web research on how to build a heat treat furnace. Industrial
PID controllers are readily available on eBay cheap, and the rest
of the materials required are not expensive either. I'm adding something
like this to my "someday"
project wish list:
Home-built
Heat Treat Oven...
Links about making
your own furnace:
The
Home-built Heat Treat Oven Pictured Above: A nice project
with lots of photos.
http://www.knifeforums.com/forums/showtopic.php?tid/752668/post/775813/hl//:
Not much on pix, but some good tips and techniques. For example,
there is a high temperature mortar/calk available at Home Depot
to seal the bricks that is good to 2000 degrees. You want a "K"
type thermocouple for this kind of project.
Back to Machine Shop Home
Page...
