G-Wizard Machinist's Calculator: Geometry
G-Wizard's Geometry tab contains
a variety of calculators designed to solve trigonometry and geometry problems
common to machinist's.
Right Triangle
The Right Triangle
calculator solves problems involving triangles that have a 90 degree angle.
Just enter any two lengths or any length and any angle and press the "Calc"
button. G-Wizard will figure out all the remaining lengths and angles.
To try a different set of parameters press the "Clear" button
and start over. You can't just change values once you have calculated
without starting again with "Clear".
Sine Bar
It's very easy
to use the Right Triangle calculator to do sine bar calculations. The
following diagram shows how:
Calculate the
angle based on the sine bar length and stack height
This one is easy:
1. Enter the sine
bar length as the hypotenuse of the triangle. You can see the outline
of the triangle on the sine bar diagram. The hypotenuse is the diagonal
length opposite the 90 degree angle.
2. Enter the Stack
Height in the length on the left.
3. Press "Calc"
and you'll have the angle of the sine bar in the Angle indicator on the
lower right.
Calculate the
stack height needed to set the sine bar to a particular angle
Suppose you need
to figure out what stack height is needed to set your sine bar to a particular
angle.
1. Enter the sine
2. Enter the angle
in the lower right.
3. Press "Calc"
and you can read off the other parameters.
For example, a
5" sine bar set to 30 degrees requires a 2.500" stack height.
Oblique Triangle
If your triangle
has no 90 degree angle in it, you want the Oblique Triangle calculator.
You have three choices to figure out all the parameters of an oblique
triangle:
1. Enter one length
and any 2 angles.
2. Enter two lengths
and the included angle (the angle between the two lengths you specify).
3. Enter all three
lengths and G-Wizard will figure out all of the angle.
When you've entered
the parameters, press the "Calc" button to see the answers.
Just like the Right Triangle, you'll need to press "Clear" and
re-enter your parameters to try new values.
Bolt Circle
The Bolt Circle
calculator will provide a table of the X and Y coordinates for the bolt
centers. Start by entering number of bolts and circle radius. You can
leave the other values as 0's and just press "Calculate" for
a simple bolt circle centered at X=0, Y=0.
If the bolt circle's
first bolt is not aligned on the X-axis from the origin, you can enter
the angle off 0 for that first bolt. Lastly, you can enter a different
Circle X and Circle Y to move the bolt circle off the 0,0 origin.
Press "Calculate"
and the X and Y coordinates for the bolt centers will appear in the table.
Press "Clear" to start a new bolt circle.
Dovetails
The Dovetail calculator
lets you figure out the dimensions for male and female dovetails. Note
that the two are independent (some have suggested they be made dependent),
so you must enter parameters for both to see both sets of dimensions.
To use the calculator, fill in the fields marked "Required"
or "Red'd" and press the "Calc" button. To try a different
set of parameters you'll need to press "Clear" and try again.
Tapers
To use the Taper
calculator you have several choices:
1. Choose one
of the standard tapers by pressing the button. Standard tapers include
MT (Morse Tapers), JT, Brown & Sharpe, and Jarno.
2. Enter a length,
big diameter, and small diameter
3. Enter an angle,
length, and either the big or small diameter.
Once you've entered
the parameters, press "Calc" to see the rest of the dimensions
filled out. To enter parameters for a new taper, press "Clear"
first.
Chamfer/Drill
The Chamfer and
Drilling calculator provides functions for a variety of tools including
spot drills, center drills, twist drills, and countersinks.
To use the Center
Drill calculator, choose a center drill from the list. That will determine
the drill's Body Diameter, Pilot Diameter, and Pilot Length as well as
the Minimum and Maximum recommended Chamfers that can be achieved. Next,
enter the desired Chamfer Diameter and the calculator will figure the
depth needed to achieve that Chamfer Diameter. Or, enter a depth and the
calculator will determine the Chamfer Diameter that results from that
depth.
To use the Spot
Drill calculator, enter the Drill's Diameter and Included Angle. That
will determine the Minimum and Maximum Chamfers possible with that spot
drill. Next, enter the desired Chamfer Diameter and the calculator will
figure the depth needed to achieve that Chamfer Diameter. Or, enter a
depth and the calculator will determine the Chamfer Diameter that results
from that depth.
The Twist Drill
calculator is useful for determining how deeply you must drill to full
break through the hole or to reach a particular blind depth to full drill
diameter. To use it, enter the Drill's Diameter and the Drill Angle (if
it differs from the 100 degree default).
Now you can enter
Hole Depth (the depth for full diameter) and see how much deeper the tip
of the drill goes in Drill Depth. Or, enter a Drill Depth and see in Hole
Depth the maximum depth that is the drill's full diameter.
To use the Countersink
calculator, enter the Included Angle of the countersink, and either the
Chamfer Diameter or the Depth.
Chords
To use the Chord
Calculator, simply enter any two of the five parameters and press "Calc".
To try different values, press "Clear" first.
True Position
True Position
(also called Position Tolerance) is a concept from Geometric Dimensioning
and Tolerancing. It quantifies how far off a point in space is from its
theoretically exact position. To use it, simply enter the error in X,
Y, and Z and the True Position will be calculated in both Diametral and Radial forms. If the type of True Position is not specified, people almost always mean the Diametral form.
Points
The Points calculator
is handy for all sorts of problems involving CNC or a DRO. Enter the coordinates
for 2 points and it will tell you the angle from P1 to P2 in the various
planes. It will also tell you the distance between the points, including
the amount of distance along X (DX), Y (DY), and Z (DY).
Turner's Cube Calculator
The Turner's Cube Calculator is accessed using the "Cube" tab. It makes it super easy to figure out the dimensions for Turner's Cubes. Just enter your desired face width and the necessary hole diameters and depths will be calculated.
Geometry Examples
How Much Error is Introduced if My DRO isn't Mounted Parallel to the Travel?
This is a common question. Most DRO's want you to take great care to mount your DRO exactly parallel to the travel. Consider the long travel of the X-axis on a mill. The longer the travel, the more an error in parallelism is magnified. Assume we have 30" of travel and wonder how far off the DRO can be for an accuracy of 0.001". Here's how to set that problem up in G-Wizard's right triangle calculator:
What's the allowable error in parallelism for a 30" long DRO travel to get 0.001" of accuracy?
Think of the bottom length of the triangle as being the actual machine tool axis, so we mark its length as 30". The top length is the DRO, which is cocked up at an angle because we didn't mount it parallel. Since we're looking at a maximum error of 0.001", we set its length as 30.001". Now the vertical length is telling us how far off the left end of the DRO can be relative to the place where it would be parallel. It's quite a lot for an error of a thousandth--almost a quarter inch.
Why then do the DRO manufacturers insist on their scales being mounted much more parallel? The answer is interference of the reader head. It can't afford to move around too much relative to the scale or something will get broken. It may also affect the head's ability to read the scale accurately. So, the mounting requirements have more to do with not breaking the DRO and letting it work right than minimizing geometric errors.
