G-Wizard CNC Router
Feeds and Speeds Calculator
we built a powerful cutting physics engine with advanced algorithms that consider almost 60 different variables,
and we worked with over 50,000 CNC'ers
like yourself to build the world's first
CNC Router Feeds and Speeds Calculator
Master your CNC Router Speeds and Feeds
the easy way with G-Wizard.
"I've been asking for this for 30 years from the CAM guys. This program is the 'go-to' source for feeds and speeds" Ed
How much do you spend on cutters in a year? If each one lasted 56% longer, you'd save 56% of that. Plus what's the value of your time saved and time saved on jobs?
G-Wizard pays for itself very quickly--you'll see in the 30-day Free Trial.
CNC Router Features:
G-Wizard instantly returns the best Speeds and Feeds. Super simple for Beginners, powerful and flexible for Pros. Plus, the best free training
materials anywhere with the product.
Feeds and Speeds for Wood
G-Wizard has over 1000 materials in its Materials Database, including hundreds of species of wood. It individually adjusts feeds and speeds for each wood species you select to get the best results.
CNC Router Feeds and Speeds for Wood
CNC Router Cutter Bit Types and Feeds and Speeds
Tool Types Especially for CNC Routers
G-Wizard handles more tool types than other software can. Best of all, it has built-in support for the special cutter bits common to CNC Routers such as Downcut, Compression, and Straight Flute cutters.
Adjusts to Your Needs
Get Expert Advice on Every Cut
G-Wizard Calculator includes a unique "Tips" window that offers expert tips tuned to the unique cutting situation you're figuring feeds and speeds on. Wondering whether to climb or conventional mill? Wonder what to do if your spindle won't go slow enough for the recommended spindle speed? All that and much more is covered by the Tips Expert.
CNC Router Vacuum Table
Stop Part Pop Off from Vacuum Tables
If you use a vacuum table you know what a pain it is when your parts pop off the table. G-Wizard has the ability to provide feeds and speeds that limit cutting forces based on your part so it won't pop off.
Quit scrapping parts because they pop off your vacuum table!
G-Wizard Can Adjust to Your Smaller CNC Router
G-Wizard Calculator has machine profiles for the Carbide3D Nomad and Shapeoko already built-in. You can modify
these for the specs of your own CNC Router--even
DIY Routers. Plus G-Wizard will adjust feeds
and speeds to account for the rigidity of
your machine.
No more one size fits all feeds and speeds!.
G-Wizard works for Mills, Lathes, and Routers.
Take the Tour
"I'm in my 27th year and seen my share of 'machinist aid' software and this BY FAR packs the most punch for the dollar. Shop owners would be fools not having a copy." Michael
"I'm a total Newbie on hobby mill and had the crazy idea to jump right in on some plasma cut hardened steel. WOW! I did it and could not have done it without G-Wizard. I completed our very first EVER customer part in about 1 hour." Jeffrey
"I am amazed at all the data that is available when using the G-Wizard. I've been in the business for 43 years and sure wish something like this was around back in the day." Michael
Over 60,000 machinists from hundreds of companies
G-Wizard Customers
See our Customer List
Our frustration free software is guaranteed to make your Speeds and Feeds easier
