Belt Grinder Ideas
Bill Pace grinder has been
made by several on
the HSM boards. Shows tracking mechanism at the top very well...
Platen inspired by Lane added
to Bill Pace's grinder...
More on the tracking mechanism
by George Barnes...
Lane over on HSM built one
along the same design...
Andrew
McLurkin's Bader III
is mounted on its side to make it easier for him to do fine work. Note
the very small wheels and wrap around tool rest so he can get inside tight
areas.
Dozier
makes some of the best grinders there are. This series shows off the
different accessory configurations they have available:
Here is the grinder. Note the
pneumatic tensioner.
3 Configurations, left to right:
the basic wheel, slack belt grinding, and a platen grinding setup...
Beaumont
Metalworks offer the excellent KMG grinder:
It would be knife to turn this
grinder horizontally like McLurkin shows at the top of this page and then
use this attachment with a rest that fit nicely. You could really get
into some tight spots with it!
Tooling arm rack is a clever
accessory that makes changing the configuration fast and easy.
Here is the grinder sporting
a platen attachment, and a rest on the lhs photo. Note the solid CNC construction.
Minimal welding. Picture on far right is the slack belt attachment.
Or, how about a rotary platen?
Seems like it could take the place of several of the other accessories.
The actual "platen" is a rotary belt under tension with rollers.
Here is a variable speed JL
grinder:
The venerable Bader III grinder
is well respected:
Big
Belt Grinder Links Page Best of Links:
Mike
Alexander's Belt Grinder: Easy to construct 3-wheeler
Grizzly's
10" Rubber Contact Wheel is $64.95
Nice
grinder by PTPiddler...
BurrKing's
Belt Grinder Tips Page
Emerald
Isle's KMG Copy...
Great
looking kit by Simplatic. Looks like a good plasma cutting job...
Fogg's
PDF Plans for a KMG Clone...
Ray
Clontz's clever design uses a piece of truck drive axle and it's U-Joint
as the pivot for the arm. Detail of the tracking adjustment on the right...
Talented
Frenchman builds a nice knife grinder. Plans are in English.
The Dream KMG Attachment:
Check out the "Dream" KMG attachment, pretty cool!
Wilmont's Cool 3 Attachment Grinder
The rest is slightly reminiscent of the "Dream" KMG rest shown above. The Wilmont is a nice variation on the KMG and the site includes plans for a home shop model you can build.
The Australian Radius Master Grinder
It has 5 interchangeable contact wheels that can be indexed into position--these 3 plus the other 2 corners of the triangle have larger wheels...
They also make a hollow grinding attachment that's pretty neat...
Knife Making Resources: Micarta
