Need a New
Machining Calculator?
Times Have Changed. Thousands of machinists from over 500 companies have adopted G-Wizard to save time.
Get Some New Technology for Your Shop.
Powerful for Experts, Simple for Beginners |
Start Your Free 30-day Trial |
Better Feeds and Speeds
Chip Thinning, Ballnose Compensation, HSM, Drilling, Turning, Milling, Tool Engagement Angle, Materials DB, Micro-Milling, and More. Maximize Material Removal Rates (MRR). G-Wizard considers nearly 50 variables for its recommendations.
Subscriptions Include G-Wizard Lite Free
Perfect for smaller machines and home shops.
All the features of G-Wizard, but limited to maximum of 1 HP / 735W cuts.
Our Guarantee
After purchase, if you're not completely satisfied, tell us within 30 days for a full refund. |
Cut Optimizer Maximizes Surface Finish, Accuracy, and Tool Life
Cut Optimizer chooses stepover and level depths for pocketing and profiling that minimize deflection to improve surface finish, increase tool life, and produce more accurate cuts.
Feeds & Speeds Knowledge Base Captures Best Practices
Knowledge-Based Machining via Cut KB gives you a custom feeds and speeds database, online access to Manufacturer's recommended surface speed and chipload, data import/export, and integration API's for other software.
Wide Range of Tooling
Turning Feeds and Speeds, Milling Feeds and Speeds, Carbide or HSS, Indexable Tooling, Face Mills, Twist Drills, TiN/TiAlN Coatings, Spot Drills, Spade Drills, Gun Drills, Reamers, Form Taps, Cutting Taps, Boring Heads, Saws and Woodruff Cutters
Quick Reference Information At Your Fingertips
Fasteners, Threads, G-Codes, M-Codes, Weights and Volumes, Sheet Metal Gauges, and Thermal Expansion, Drill Index, Unified Threads, ISO Threads, Pipe Threads, Ohm's Law, Resistor Color Codes, Hardness, and Rigidity
Improve Your Feeds and Speeds Today!
Join the G-Wizard Machining Calculator 30-day trial, no credit card required. |
G-Wizard works on PC's, Macs, and Linux machines. It requires an Internet connection once every 2 weeks. Detailed System Requirements available here, but for most people it just works.
