Still Using Feeds and Speeds Charts the Old Way?
Thousands of machinists from over 500 companies have used G-Wizard for their Feeds and Speeds.
Try G-Wizard Free for Accurate Feeds and Speeds.
Feeds and Speeds for Beginners and Experts |
Start Your Free 30-day Trial |
Get Better Feeds and Speeds With Less Effort
Chip Thinning, Ballnose Compensation, HSM, Drilling, Turning, Milling, Tool Engagement Angle, Materials DB, Micro-Milling, and More. Maximize Material Removal Rates (MRR).
Subscriptions Include G-Wizard Lite Free
Perfect for smaller machines and home shops.
All the features of G-Wizard, but limited to maximum of 1 HP / 735W cuts.
Our Guarantee
After purchase, if you're not completely satisfied, tell us within 30 days for a full refund. |
Improve Surface Finish, Accuracy, and Tool Life with Cut Optimizer
Cut Optimizer chooses stepover and level depths for pocketing and profiling that minimize deflection to improve surface finish, increase tool life, and produce more accurate cuts.
Capture Best Practices With the Feeds & Speeds Knowledge Base
Knowledge-Based Machining via Cut KB gives you a custom feeds and speeds database, online access to Manufacturer's recommended surface speed and chipload, data import/export, and integration API's for other software.
Improve Your Feeds and Speeds Today!
Join the G-Wizard 30-day trial, no credit card required. |
G-Wizard works on PC's, Macs, and Linux machines. It requires an Internet connection once every 2 weeks. Detailed System Requirements available here, but for most people it just works.
