User's Guide
User's Club
Pricing & FAQ
Bookmark and Share
Got a CNC Calculator?
Why use Manual Feeds and Speeds Technology in a CNC World? Thousands of machinists from over 500 companies have adopted G-Wizard to save time.
Get Some New Technology for Your Shop.
old school lathe
Powerful for Experts, Simple for Beginners
Start Your Free 30-day Trial
Better Feeds and Speeds for your CNC
Chip Thinning, Ballnose Compensation, HSM, Drilling, Turning, Milling, Tool Engagement Angle, Materials DB, Micro-Milling, and More. Maximize Material Removal Rates (MRR). G-Wizard considers nearly 50 variables for its recommendations including the latest CNC toolpaths such as plunge milling and constant engagement angles.
Name:
Email:
We value your privacy, we do not spam, sell, or share your information.
But, we need a working email to activate your software!
Subscriptions Include G-Wizard Lite Free
Perfect for smaller machines and home shops.
All the features of G-Wizard, but limited to maximum of 1 HP / 735W cuts.
More Information
Our Guarantee
After purchase, if you're not completely satisfied, tell us within 30 days for a full refund.
Cut Optimizer Maximizes Surface Finish, Accuracy, and Tool Life for CNC Jobs
Cut Optimizer chooses stepover and level depths for pocketing and profiling that minimize deflection to improve surface finish, increase tool life, and produce more accurate cuts.
Feeds & Speeds Knowledge Base Captures Your CNC Best Practices
Knowledge-Based Machining via Cut KB gives you a custom feeds and speeds database, online access to Manufacturer's recommended surface speed and chipload, data import/export, and integration API's for other software. It tunes your Feeds and Speeds to your Machines, Tooling, and Best Practices.
Supports Most CNC Tooling
Turning Feeds and Speeds, Milling Feeds and Speeds, Carbide or HSS, Indexable Tooling, Face Mills, Twist Drills, TiN/TiAlN Coatings, Spot Drills, Spade Drills, Gun Drills, Reamers, Form Taps, Cutting Taps, Boring Heads, Saws and Woodruff Cutters
Handy Quick Reference Information
Fasteners, Threads, G-Codes, M-Codes, Weights and Volumes, Sheet Metal Gauges, and Thermal Expansion, Drill Index, Unified Threads, ISO Threads, Pipe Threads, Ohm's Law, Resistor Color Codes, Hardness, and Rigidity
Improve Your CNC Feeds and Speeds Today!
Join the G-Wizard Machining Calculator 30-day trial, no credit card required.
Start My Free Trial
G-Wizard works on PC's, Macs, and Linux machines. It requires an Internet connection once every 2 weeks. Detailed System Requirements available here, but for most people it just works.
Blog
     Business
     Products
     G-Wizard Calculator
          User Guide
          Tips
          Change Log
          User Guide
          Change Log
     Gearotic Gear Designer
     Troubleshooting
     User's Club
     Beginners: Soon!
          G-Code: Soon!
          CAD/CAM: Soon!
          Other Software: Soon!
     Machining: Soon!
     CNC Tech: Soon!
     Idea Notebooks: Soon!
     Completed
     Simple Wish List
     Model Wish List
     Rash Ideas
Machines
     Lathe: Soon!
     Mill: Soon!
     Router: Soon!
     3D Printer: Soon!
     Other Machines
Privacy Site Map About
