Still Figuring Feeds and Speeds the Old Way?
Times Have Changed. Thousands of machinists from over 500 companies have used G-Wizard to save time.
Get a New Milling Speeds and Feeds Calculator
for Your Shop.
Powerful for Experts, Simple for Beginners |
Start Your Free 30-day Trial |
Get Milling Speeds and Feeds With Less Effort
Chip Thinning, Ballnose Compensation, HSM, Drilling, Turning, Milling, Tool Engagement Angle, Materials DB, Micro-Milling, and More. Maximize Material Removal Rates (MRR).
Subscriptions Include G-Wizard Lite Free
The Milling Speeds and Feeds Calculator for smaller machines and home shops.
All the features of G-Wizard, but limited to maximum of 1 HP / 735W cuts.
Our Guarantee
After purchase, if you're not completely satisfied, tell us within 30 days for a full refund. |
Improve Surface Finish, Accuracy, and Tool Life with Cut Optimizer
Cut Optimizer chooses stepover and level depths for pocketing and profiling that minimize deflection to improve surface finish, increase tool life, and produce more accurate cuts.
Capture Best Practices With the Feeds & Speeds Knowledge Base
Knowledge-Based Machining via Cut KB gives you a custom feeds and speeds database, online access to Manufacturer's recommended surface speed and chipload, data import/export, and integration API's for other software.
Save Time Figuring Shop Geometry Problems
Trig, chamfers, countersinking, dovetails, tapers, bolt circles, and circle chords
Find Important Quick Reference Information Quickly
Fasteners, Threads, G-Codes, Weights and Volumes, and Thermal Expansion at your fingertips
What the Machinists Using G-Wizard Say |
Your product already paid for itself the first time I used it.
G-Wizard does a better job than lots of packages including OneCNC and Mastercam.
I installed the Gwizard, Its a cool tool!
Great job! This is the all in one kind of solution that I was looking for.
That is one slick looking program.
Thanks & keep up the good work.
It looks great. I like the layout and it's pretty easy to navigate. Again, great job.
Thanks for the nice tool! This is handy to say the least.
Looks like this is exactly the program I've been looking for!
I used a similar program but yours has more options, and overall a better look!
Nice application, great work!
Wow this thing is TOO COOL! It's a really really slick program
You've literally taken all the annoying little calculations and figured them out from every single angle, just brilliant.
Every time I run your app, I find something new. |
Awesome tool Bob.
Wow! This is really quite a piece of work you’ve accomplished. Kudos!
I’m truly impressed with your software. Keep up the great work!
Bob, thanks for the software i really like it!!
Very nice package, sure make speeds and feeds much easier.
I love what you have done, it has been a good resource for me.
G-Wizard is indispensable, I'll be following its progress.
G-Wizard is great!
I just surfed thru some of the pages and all I can say is FANTASTIC. Thanks again for all the hard work.
It is the single most useful thing I have added to my shop since the mill! I go to G-wizard first for all the feeds, speeds, tapping info and I also used the geometry page!
It will be a valuable asset for many shops.
The program is very nice, and will be a real boon, to both beginners and experienced folk. |
Improve Your Feeds and Speeds Today!
Join the G-Wizard 30-day trial, no credit card required. |
Calculator
Compensation for radial chip
thinning, lead angle, depth of cut, and ballnosed cutters.
"Gas Pedal" slider specifies how conservative or aggressive to make the cut. Emphasize surface finish and tool life or material removal rate. |
Chatter calculator identifies optimal spindle rpm ranges to minimize chatter. |
HSM Feeds and Speeds + Tool Engagement Angle Calculator |
Deep hole drilling recommendations
including support for parabolic drills, when to peck, and when to drill a pilot hole. |
Reamer hole size recommendations. RA and RMS surface finish (scallop height) calculator for turning and ballnose endmills. |
Conventional vs Climb
milling recommendations. Endmill plunge rate and plunge milling feeds and speeds. |
Micro-cutter Feed and
Speed compensation for cutters less than 1/16" in diameter. |
Compensation for small machines (Rigidity compensation). |
Integrated with the Tool Crib and Machine Profiles. Customize for your tools and machine HP, spindle rpm, and feedrates. |
Integrated with G-Wizard G-Code Editor. Calculate feeds and speeds and directly output g-codes. |
Tooling: End mills, turning tools, indexable, face mill, reamers, spot drills, twist drills, gun drills, spade drills, spot drills, slitting saws, woodruff cutters, and taps |
Material Database: Aluminum, Steel, Stainless, Titanium, Plastics, & Wood, Alloys and Material Conditions |
See Our Full Feature List |
G-Wizard works on PC's, Macs, and Linux machines. It requires an Internet connection once every 2 weeks. Detailed System Requirements available here, but for most people it just works.
