GW Editor User Guide
GWE Home
Getting Started
Setup
Commands
Keyboard
Revisions
CNC Simulator
Wizards
Tool Data
Mill G-Codes
Lathe G-Codes
Sample G-Code Files
GWE Tips
GWE Change Log
GWE Install
Troubleshooting
User's Club
Bookmark and Share
Try G-Wizard
CNC Backplot Editor:
Throw out the old ideas for g-code simulation.
Build something new. Something better.
That's what we did with GWE.
Old School Machining
A CNC Backplot Editor for Experts and Beginners
Join Our Free Beta Test
Machinists need a second opinion on part programs. G-Code isn't exactly English, after all. Like they say, a picture is worth 1000 words, so one of the easiest ways to check your programs for bugs is to use a CNC Backplotter. With G-Wizard, we've built a real humdinger of a backplot editor:
- It has a sophisticated graphical backplot simulator so you can view your g-code toolpaths. Rotate, pan, and zoom them just like a CAD program. Check out what's going on in multiple views.
- Specialized views for milling and turning.
- It knows your controller using a "post" just like your CAM program.
- In-depth error checking.
- Out special "Hints" view gives you X-ray vision into what each block does to tell you even more about your part program. Think of it as having a g-code expert there to explain everything in simple language.
- Run your cnc backplot with fast or slow playback. Step ahead by g-code feature (next rapid, next macro, next toolchange, etc.) instead of one block at a time to get to the interesting parts faster.
- There's even a set of Wizards to streamline insertion of new g-codes, and there's full integration with our powerful G-Wizard Machinist's Calculator so you can edit your program.
GWE can make a faster g-code programmer out of any machinist, whether you're a g-code expert, or just getting started learning the g-codes. GWE has capabilities for every skill level.
Simulate. Edit. Revise. Debug. Power to the Machinist!
Check it out. We think you'll like GWE, the G-Wizard CNC Backplotter and G-Code Editor.
Name
Email
Note: Even if you registered for calculator, you still need to register for the Editor Beta!
Our Guarantee
We value your privacy, we do not spam, sell, or share your information.
But, we need a working email to activate your software!
Silky Smooth CNC Backplot
CNC Simulator
GWE CNC Backplot...
  • Multiple views including Top, Front, Right, and Perspective, just like your CAD/CAM program
  • Simulated 3D toolholder makes the action come alive
  • Plots the toolpath motions so you can view just what your g-code is doing
  • Panning, zooming, and rotation
  • Playback in the simulator with the familiar Cycle Start, Feedhold, Single Block, and Rewind commands
  • Variable playback speed from 0 - 100%. Move quickly to get to the part that's interesting and then slow it down to understand what's happening
  • Graphical backplot viewer animates during playback so you can keep track of where you are
  • Detailed feedback of coordinates, spindle rpm, feedrate, and coolant status during playback, just like on your CNC machine
  • Detailed feedback of g-code modes at each step during playback, such as whether G17, G18, or G19 plane is selected
  • Work offsets G54-59 all the way through extended work offsets G54.1 P1 - P300
  • G52 Local Work Shift
  • G92 Coordinate System Setting
  • G51 Coordinate Scaling
Everything you need to verify your g-code part program is doing the right thing is right there when you need it.
See All of G-Wizard Backplot Editor's Other Features
Improve Your Feeds and Speeds Today!
Join the G-Wizard Calculator 30-day trial, no credit card required.
Start My Free Trial
G-Wizard works on PC's, Macs, and Linux machines. It requires an Internet connection once every 2 weeks. Detailed System Requirements available here, but for most people it just works.
Blog
     Business
     Products
     G-Wizard Calculator
          User Guide
          Tips
          Change Log
          User Guide
          Change Log
     Gearotic Gear Designer
     Troubleshooting
     User's Club
     Beginners: Soon!
          G-Code: Soon!
          CAD/CAM: Soon!
          Other Software: Soon!
     Machining: Soon!
     CNC Tech: Soon!
     Idea Notebooks: Soon!
     Completed
     Simple Wish List
     Model Wish List
     Rash Ideas
Machines
     Lathe: Soon!
     Mill: Soon!
     Router: Soon!
     3D Printer: Soon!
     Other Machines
